Projects The Drury, Fowler, Holmes and Kugel belly tank Lakester Rebuild
Discussion in 'The Hokey Ass Message Board' started by Marcia, Sep 6, 2023.
  1. HEMI32
    HEMI32
    @Marcia - My research indicates that Ron Benham {i.e., not Bedham} ran:
    • The #98 "Master Washer & Stamping Co. Special" CX / Modified Roadster (with a 204.5 c.i. Pontiac Tempest engine) at the 1961 Bonneville National Speed Trials:
    Ron Benham's #98 Master Washer & Stamping Co. Special CX -  Modified Roadster - 1961.jpg
    • The #72 "Benham Hurley Wooley" E / Lakester (with a 181 c.i. Pontiac Tempest engine) at the 1962 Bonneville National Speed Trials:
    • The #34 "Blair's Speed Shop" E / Lakester (with a 181 c.i. super-charged Pontiac Tempest engine) at the 1963 Bonneville National Speed Trials:
    Burke LeSage piloted Ron Benham's #34 Blair's Speed Shop 'Baby Whale' E-Lakester - 1963.jpg
    5' 2" Burke LeSage {i.e., not LePage} piloted the "Baby Whale"
    Burke LeSage on course in Ron Benham's #34 Blair's Speed Shop 'Baby Whale' E-Lakester - 1963.jpg
    The "Baby Whale" on its record setting run
    Ron Benham with his record setting "Baby Whale" E / Lakester​
    That all stated, I'm not sure if Mr. Benham constructed his E cl*** Belly Tank Lakester ch***is from scratch . . . or if he fabricated them from a Belly Tank with previous Dry Lakes history . . . ???
  2. Marcia
    Marcia
    The tin seems quite thin to be belly tank material. The nose and tail are one piece, not split in half like a tank would be.
    Jerry said Ron built it. I would like to know what year.
  3. HEMI32
    HEMI32
    I'd guess Mr. Benham started building it in late 1961 or early 1962 (since it first appeared at the '62 B'ville Nats).
    @Dean Lowe knew Ron well.
    Perhaps Dean can shed some light on what year Benham fabricated his "Baby Whale" E-cl*** (181ci Pontiac Tempest powered) Lakester . . . which ran as the #72 "Benham Hurley Wooley" entry in '62 and as the #34 "Blair's Speed Shop" entry in '63 (when it bumped the E/L record up to 213.747mph).
    Okie Pete, lothiandon1940 and Stogy like this.
  4. Marcia
    Marcia
    PXL_20231007_172532580.MP.jpg PXL_20231011_175209792.MP~2.jpg Frank built a new frame piece to add some support. Then he drilled out the water drains on the block and rethreaded them.. View attachment 5866316
  5. Marcia
    Marcia
  6. Marcia
    Marcia
    PXL_20231021_130222608.MP.jpg Hand lettered by Wild Willy Witman!
    Great job!!
  7. Marcia
    Marcia
    PXL_20231022_153617863.jpg PXL_20231022_153721401.jpg PXL_20231022_153706301.jpg We took it to the drag track and got some nice pictures. The big lesson we learned was that we shouldn't try to race it without trying to get it higher in the air. It drags to much and I don't want to beat it up anymore. 5502~2.jpeg think 5501.jpeg
  8. Stogy
    Stogy
    Congrats on the Milestone @Marcia drags as in to low to the ground? Were you the Pilot?
  9. Past using taller tires that could get really involved I suspect.
    Stogy likes this.
  10. Stogy
    Stogy
    Dang ****py roadways...back to the salt! Are the tires the size from the good ole days?
    @Marcia were the original panels under there all s****ed up?
    Pist-n-Broke likes this.
  11. [​IMG]
    Hay, where did that Red Mustang go?
    Marcia and Stogy like this.
  12. Marcia
    Marcia
    Yes, I'm the driver. In the garage it looks like we have about 2.5" clearance but it flexes, up and down under speed.
    Okie Pete and lothiandon1940 like this.
  13. Stogy
    Stogy
    Would it have done that in the past...or did some support get removed...
    heavier engine have something to do with...it sure isn't you...;)
    I guess you can add structure selectively...
    brady1929 and lothiandon1940 like this.
  14. Marcia
    Marcia
    We're not sure of their tire size but we can certainly put taller tires on it.
    The body panels were in green primer when we got them. No s****e marks.
  15. Marcia
    Marcia
    Drury stretched it 2 feet in 1964. We added more support, we're using the same engine. We're just not going to race it anymore. We're going to try something with the suspension. As long as I can cruise around the parking lot, I'll be happy.
  16. Stogy
    Stogy
    Mods can have dramatic effects...I understand,,,hopefully what you're proposing gives it enough that you can run it as you were trying to...
    brady1929 and Marcia like this.
  17. Marcia
    Marcia
    Here's some more pictures from 1964. The young fella is Jerry Kugel.Jim Taylor holding the canopy. FB_IMG_1697584918463.jpg Screenshot_20231012-123454~2.png Screenshot_20221129-082844.png received_509505957810526.jpg
    The 39 guy, das858, Okie Pete and 8 others like this.
  18. Marcia
    Marcia
    Screenshot_20231031-190437.png I wrote up a timeline for the 260 Lakester. We know where its been it's entire life.
    HEMI32, Okie Pete, elgringo71 and 7 others like this.
  19. Marcia
    Marcia
    PXL_20231031_164424827~2.jpg PXL_20231031_164351393.jpg We put the taller tires on the back. That looks better!
  20. Marcia
    Marcia
    We worked on the parachute mount. I think we're ready to display at Bruce Larson's open house on the 11th. Of November. PXL_20231103_185003356.jpg PXL_20231103_184835198~2.jpg PXL_20231103_144854986.MP.jpg
  21. Marcia
    Marcia
    The Lakester was a big hit at Bruce Larson's open house. We talked for 8 hours straight, about Bonneville, Landspeed racing and the history of racing in general. We have a few more shows in January, can't wait! PXL_20231111_153527486.jpg PXL_20231111_133611456.jpg PXL_20231110_174926671.jpg
    Okie Pete, Stogy, catdad49 and 8 others like this.
  22. Marcia
    Marcia
    We made up few Vintage T shirts to celebrate the Belly Tank going back to Bonneville after 60 years.
    The white Bonneville Nationals or the gray distressed Flying Seven Vintage racing.
    Men's or Women's V neck.
    Send me a private message.
  23. thebearded1!
    thebearded1!
    from Maryland
    Here is a video I took of Marcia running the car at the 2023 Harvest Event at Loring. Unfortunately it was very windy so the audio isn't the best.
  24. Marcia
    Marcia
    PXL_20240106_143705332.jpg We're at the Dragfest expo in Lebanon, PA. There's a lot of people that are excited to see a Bonneville Lakester. Another great weekend, talking about old cars and speed.
  25. loveoftiki
    loveoftiki
    from Livonia,Mi
    How was the event? Would love to see some coverage
    Stogy likes this.
  26. Marcia
    Marcia
    If you go to Facebook, Dragfest - Indoor Drag Racing Showcase, there are lota of pictures. I didn't take many.
    Stogy and lothiandon1940 like this.
  27. Marcia
    Marcia
    FB_IMG_1705250262145.jpg FB_IMG_1705250169967.jpg The Motorsports show starts the 19th, this Friday. It's in Oaks PA.
    The Piston Powered Autorama is the Cleveland the first weekend in April. We'll have the Belly Dancer at both of these shows.
    Stogy, 41 GMC K-18 and lothiandon1940 like this.
  28. Marcia, fantastic work! Glad you restored 260! Hugh Drury is my father. I have more photos, his helmet, and the trophy. Drop me a line!
    Stogy, Marcia and loudbang like this.
  29. Marcia
    Marcia
    I sent you a private message. I would love to talk to you on the phone.
    Stogy likes this.
  30. Marcia
    Marcia
    6395.jpeg 6410.jpeg 6404.jpeg 6394.jpeg EJ found some old pictures on line.
    Stogy, HEMI32, das858 and 1 other person like this.
