Projects 1939 Ford convertible mild custom.
Discussion in 'Traditional Customs' started by John 79, Sep 13, 2023.
  1. John 79
    John 79
    from Sweden
    Soory folks, no updates. Bought a 49 Ford from a friend that i am workin on right now but soon the 39 will get some attention so stay tuned!
  2. John 79
    John 79
    from Sweden
    Got lucky and found a new 39-40 coupe tool box compartment, i had to place it in the trunk before i fitted the tail pan because it was to tight to get it in place after the tail pan was mounted. The mounts/reinforcments for the trunk lid was in the way.
    This made it quite tricky to get it in the right spot, got the two mounting bolts in and a couple of spot welds was done.
    Alot of welding left but i think i at least got it in the right location.
    395288714_296801176550720_7412597059350057882_n.jpg 395269201_1124511851853233_3601254363453418859_n.jpg 395149351_1409557119963633_5432233886028433803_n.jpg 395027083_1590622921751660_4471113184648978572_n.jpg
  3. GordonC
    GordonC
    Nice work!
    Stogy and John 79 like this.
  4. John 79
    John 79
    from Sweden
    Got the tool box compartment done today, now the rear body is stiffer and doesen't sag any more.
  5. ronzmtrwrx
    ronzmtrwrx
    Nicely done sir.
  6. And the beat goes on… nice work!
  7. Great project and nice work so far. Keep the updates coming.
  8. John 79
    John 79
    from Sweden
    Some minor update.
    Got the front end out and the wishbone is ready for a split.
    But first the old trans mount has to go.
  9. chiro
    chiro
    Keep it up but get yourself some proper jack stands bro! ^^^:eek:
    Andy
    aussie57wag and RAJO like this.
  10. John 79
    John 79
    from Sweden
    Got the wishbone split and welded.
    Started to heat and get the shackle mounts in the right angle after the split but ran out of gas and could only do one side.
    Kinda hard to do this by yourself, would be nicer to have one guy heating and one bending.
    v-stag kapat.jpg v-stag svetsmutter.jpg v-stag färdigt.jpg inte böjd.jpg böjd rätt.jpg
  11. John 79
    John 79
    from Sweden
    Got the front end back on the car, the rear mount for the wishbones is not bolted to place yet. I want to test with engine/trans first to see where everything ends up. Also there is holes in the wishbone mount for a th350 transmission mount that i will use if i can.
  12. John 79
    John 79
    from Sweden
    I got a th350 delivered from a friend this weekend so i decided to bolt it to a empty 283 block and put it in the 39 just to test how it would fit.
    As i said before the wishbone mount had holes for a th350 trans mount that i wanted to use if i could.
    I had two types of front engine mounts, one old Hurst thar ive borrowed from a friend and one new aftermarket.
    Sadly the old Hurst mount hit the timing cover and needed a spacer between the block and mount and that made it to far away from the holes in the frame to use.
    Had to cut some in the center section of the frame to get clearance for the transmission but after that i got it bolted to the holes in the wishbone mount.
    Gladly the transmission dident hit the floor so i dont have to change the front floor or anything like that.
    The motor mount dident quite line up with the holes in the frame (yes its reversed) so im going to drill new holes for the transmission mount to move everyting a little bit towards the front.
    Also tested the oilpan for clearance, over all im pleased and dident have to much problems. motor utanför bil.jpg original kryss.jpg urkapat kryss.jpg golvplåt över lådan.jpg växellådsfäste.jpg oljetråg.jpg motorfäste framifrån.jpg Motorfäste offset.jpg
  13. alchemy
    alchemy
    Make sure to check with water pump and fan for clearance to the radiator.
    Outback and Jacksmith like this.
  14. Jacksmith
    Jacksmith
    from Aridzona
    The SBC fits well in the '39 engine bay, but it's a tad snug. Definitely check your clearance, Clarence! I put mine together without a shroud because I wanted to get it back together quickly... "I'll figure the shroud out later"... But it has never overheated as is, with the high volume water pump and 4 core copper radiator, so it is what it is. (Results may vary) Note the 4 blade fan... can't believe it works!!
  15. John 79
    John 79
    from Sweden
    Yep, already did that. I got all the stuff for the engine so i can test fitment.
  16. John 79
    John 79
    from Sweden
    I tested with a original 4 blade fan and clearance was not a problem but the fan sits high, originally the flathead fan is mounted on the crankshaft. Looks good on your car.
  17. jhexide
    jhexide
    could you not turn that front engine mount around ? perhaps the holes would line up..!
    Moriarity likes this.
  18. The 39 guy
    The 39 guy
    Small block chevy's were made for 39-40 fords :) and after almost 70 years of use in them I consider them traditional. A word of caution for you on that cast aluminum pan, If you are going to be running your car with low ground clearance you need to consider that they do not bend or dent when hit, but crack and leak at leak oil at the very least. I would consider a chrome plated steel oil pan if you need some shiny stuff under you car.
    I am enjoying your build posts!
  19. The world needs more tail draggers.
    cool ride
    John 79 and Jacksmith like this.
  20. John 79
    John 79
    from Sweden
    No then the holes will sit to far to the front instead, if you look att the pic the part of the engine mount thats bolted to the block is directly over the holes in the frame. So if i flip it i need to move the engine back instead and the gearbox will hit the floor and there might be tight for the dist.
  21. John 79
    John 79
    from Sweden
    It sits kinda high so i dont think that will be a problem. Im not a big flathead fan, ive had a couple of them but its just not for me. I want more power and be able to drive it with low rpm at higher speeds, also i think a 283 is a great engine.
    Barn Hunter and simplestone like this.
  22. aussie57wag
    aussie57wag
    from australia
    Such a cool car. Such a shame you took out the way cool flathead and fitted a boring sbc and auto like every other budget built modified car. Certainly a step down in the cool factor. There are a lot of other cool old time options that would be so uninteresting and generic. Pity you couldn't afford to step up a bit.
  23. John 79
    John 79
    from Sweden
    Nah, i think a 283 is a cool old hot-rod engine and i dont want a flathead. Also want a auto so my wife can drive it, so a 283 and th350 is my choice.
  24. Didn’t take long before someone complained about a traditional engine swap.
    Just swapped out a flatty for a 283.
    Easiest swap I’ve ever done. Cool factor?
    That problem belongs to the viewer not the owner.
  25. Jacksmith
    Jacksmith
    from Aridzona
    That's your opinion, which you are certainly en***led to... Here's mine: The SBC (a**** many others) has been swapped into these cars for nearly 70 years... that's pretty traditional; His car, his choice.
  26. aussie57wag
    aussie57wag
    from australia
    Each to there own. I would off gone with an overdrive auto though like a t700.
    6sally6 likes this.
  27. John 79
    John 79
    from Sweden
    The 700 auto is bigger than a th350 so you have to cut and rebuild the center frame alot. With a th350 you only have to remove the original transmount and some cutting in the center reinforcment for clearence.
    anthony myrick and aussie57wag like this.
  28. aussie57wag
    aussie57wag
    from australia
    That's true. But the prevalence of them today takes away the old school cool look as there is very little difference visually between a 283 and a new 350. So it doesn't shout old school as most other motors of that time do. They just shout cheapest and easiest.
    Okie Pete likes this.
  29. John 79
    John 79
    from Sweden
    Ok, now we know your opinion about chevy s/b. If you wanna debate that subject please do, but not in this thread.
    klicker, Just Gary, Jrs50 and 15 others like this.
  30. John 79
    John 79
    from Sweden
    Got the new holes drilled for the trans mount, got the engine alittle bit further and now the motormount fits.
    GordonC, Just Gary, mvee33 and 5 others like this.
