Technical 1956 354 Hemi
Discussion in 'The Hokey Ass Message Board' started by jrvariel48, Sep 19, 2023.
  1. George
    George
    E Bay probably had bigger following
  2. nochop
    nochop
    from norcal
  3. 49ratfink
    49ratfink
  4. tubman
    tubman
    HOLY ****!:eek: I think my "Library" is about to become seriously depleted!:D
  5. 73RR
    73RR
    Just thought I'd post this photo for those interested in lifters. The location of the groove is important.
  6. jrvariel48
    jrvariel48
    from New Jersey
    Can someone tell me which SBC bellhousing I should be looking for with the Hot Heads adapter?
    I'd like to put a TKX behind the 354, I think it'll work well with the 4:11 rear.
    I see there's a bunch of options to go with. Stock build, so is original GM better or worse that aftermarket?
    Thanks
  7. Hot heads sells adapters for Mopar transmission applications as well .
    Mopar had an excellent manual transmission,,,,,,they hold up very well behind a strong engine,,,,,especially a Hemi !
    Tommy
  8. 73RR
    73RR
    Have you asked them?
  9. jrvariel48
    jrvariel48
    from New Jersey
    I did not. At the time, I guess I thought it would be simple to find, but as I searched, I found out way too much information!! Probably best to ask them.
    Thanks
  10. jrvariel48
    jrvariel48
    from New Jersey
    Any thing in a 5 speed? Also the shifter location will play a big part.
    Thanks
  11. dart4forte
    dart4forte
    from Mesa, AZ
    Pretty popular conversion is the Ford T-5 5 speed. HHS sells an adapter for that. As far as the crossover I had to cut the crossover away from the WP housing then weld the bottom of the crossover. I have a 241 Dodge.
  12. 73RR
    73RR
  13. jrvariel48
    jrvariel48
    from New Jersey
    I have a T5 behind my flathead now. It's a little tired after being beat up a bit and the ratio's are not the best.
    I got some prices on rebuilding it and changing gear sets but it's almost the same price to buy a new TKX when all's said and done. I'll spring for the extra dough knowing I have a trans I can grow with.
  14. jrvariel48
    jrvariel48
    from New Jersey
  15. sunbeam
    sunbeam
