Projects '61 Falcon Street/Strip Gasser Build
Discussion in 'The Hokey Ass Message Board' started by brianf31, Nov 14, 2019.
  1. loveoftiki
    loveoftiki
    from Livonia,Mi
    Those look great!! Any plans for collectors or will this be strictly open headers?
  2. brianf31
    brianf31
    Thanks. I'll terminate the 3 1/2" collector right at the edge of the front door. I'll have a 3-bolt collector ring and hook up to a 3 1/2-to-3" reducer leading to 3" Porter steel-packs. If I rig it up right, I'll be able to unbolt the 3" exhaust at the track and add a turn-out to the collector.
  3. loveoftiki
    loveoftiki
    from Livonia,Mi
    Check out powerstick mufflers. I run em on my car, very easy to work with, simple to fab up, made in USA, and sound amazing…
    https://www.cl***icchambered.com/
  4. brianf31
    brianf31
    I switched to Lexan on the side gl*** and dumped the window mechanisms. Vintage seat belts were re***igned to window lifting duty. Total weight savings is around 25 pounds.
  5. Just Gary
    Just Gary
    Those headers look awesome.
    But they'd look awesomer if they were white!:):cool:
    mad mikey, brEad, 427 sleeper and 2 others like this.
  6. loveoftiki
    loveoftiki
    from Livonia,Mi
    Nice..some engine turned aluminum door panels sure would look killer
  7. brianf31
    brianf31
    If I don't hurry up and paint 'em white, they will be brown before long!
    mad mikey, 427 sleeper, Thor1 and 2 others like this.
  8. RmK57
    RmK57
    Wow! Those headers look slick.
    427 sleeper and brianf31 like this.
  9. 6sally6
    6sally6
    I think.........Georgia Cracker (with a crack'in bullwhip under/or over the name) would be really slick!
    Too bad Georgia Shaker is already used and is still real prominent...
    Ya could write the name and have it sitting on a saltine cracker! That would be different!
    BITD my little 64 Sprint had little Frankenstein Man with GROUND SHAKER under him drawing !
    6sally6
    PS The saltine cracker idea I like better & better :D:D
    brianf31 likes this.
  10. brianf31
    brianf31
    Dad will sketch it up on paper so we can hang it and ruminate before applying the paint.
    I'm not much on trim or flash, so we'll keep the lettering kind small and on the quarter panels. I mean, a G***er needs some kinda lettering!
    bchctybob, Thor1, lumpy 63 and 2 others like this.
  11. seb fontana
    seb fontana
    from ct
    Georgia Bird
  12. AmishMike
    AmishMike
    How about “ the hummmmm ing bird “ with appropriate picture of roaring tiny bird
  13. GordonC
    GordonC
    I'd figure with a color like that "Mint Julep" would be a natural choice for a Southern car!:D
  14. RmK57
    RmK57
    A 100 years ago there was a 66 Falcon race car in the northwest called the “Absurd Bird”
    Hand painted small letters on the trunk lid it had “ Just another Falcon Ford”.
  15. loudbang
    Flying Falcon :)
  16. brianf31
    brianf31
    I'm thinking Flyin' Brian on the roof over the door.
  17. brianf31
    brianf31
    We're thinking "Fulwood's Speed Shop Fort Valley, GA" in small lettering on the trunk lid.
    Deuces, Just Gary and RmK57 like this.
  18. lumpy 63
    lumpy 63
    The Peregrine Falcon is a small FAST agile hunter.....How about Peregreen Falcon?
  19. SS327
    SS327
    What about “Shake And Bake”?
  20. seb fontana
    seb fontana
    from ct
    Smooth Move'r
  21. seb fontana
    seb fontana
    from ct
    Nothing to Crow About.
  22. seb fontana
    seb fontana
    from ct
    Handler's Choice
    Neat little car, miss my Falcon.
    Deuces, mad mikey, Oneball and 5 others like this.
  24. brianf31
    brianf31
    I sanded and painted the bumper and added a vintage '61 tag. It was originally issued in Bibb, the county I grew up in.
    In Georgia, you can register and run these. The tag has to match the year of the car. You still have to buy a new tag and keep it in the car.
    Here's a little trivia. In Georgia, the tags used to start with the county number, ***igned according to population. Bibb County was the 5th most populous, so Bibb tags always started with the number 5. If you had a truck, the second character was an "R".
    bchctybob, brEad, FoMoCoMoFo and 7 others like this.
  25. DDDenny
    In the early 70's I knew a guy that had a 61 Falcon, a real frumpy dark green thing.
    It was plane as Jane could be visually, black steel wheels, stock(ish) ride height, nothing flashy but it had a nasty 221, a T-10 and a nine inch with old school style rect. tube traction bars welded to the rearend.
    He would side step the clutch and the car would do this weird squat and hop thing.
    I always called it Kermit.
    mad mikey, brEad, lumpy 63 and 4 others like this.
  26. brianf31
    brianf31
    Haha, that's a good story, Denny!
  27. sidewayzz69
    sidewayzz69
    Good job on your build.Great looking car.
  28. brianf31
    brianf31
    Thanks!
  29. brianf31
    brianf31
    The '60-61 Falcon took styling cues from post-war fighter jets such as the F-86 Sabre. It seemed fitting to make an aircraft type part.
    The removable trans tunnel is made from 2024T4 Alclad aluminum with AN470A-4-4 bucked rivets. I think I'll leave it unpainted.
    Deuces, bchctybob, 51504bat and 12 others like this.
  30. brianf31
    brianf31
    I forgot how long it takes to finish-weld headers. One side down, one to go.
    I've found that VHT paint will adhere well if you follow the instructions closely and use their primer. Nevertheless, they will be scratched and stained in no time.
