1955 ford customline. 302/c6 10.5:1 compression, solid lift cam, new fuel system including tank all the way to the carb. All done with 6an hard and braided line. New radiator and electric fan. HEI distributor. One wire alternator. C/6 has shift kit and mild stall. Most of the body work has been done. Need rocker repair on drivers side. Interior is complete.minus headliner and in pretty good shape. Brakes are new. For the right trade or sale price I can include a Lincoln Versailles disc brake rear-end, Versailles front disc spindles, new Aerostar coil springs, and a dual pot master cylinder and prop valve. New front and back glass included just incase bad things happen if you decide to paint it. You can email me at matt.s.williamson1979@gmail.com or text me at 918-500-0103. I work third shift. If you text me I'll text you back when I'm awake.
