Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. RodStRace
    RodStRace
    I spy both front brake hoses connected to the frame and wrapped in a protective sheath.
    Amazed you haven't found a local artist to paint and stripe the jackstands, though! ;)
    J.Ukrop, Stogy, chryslerfan55 and 2 others like this.
  2. Six Ball
    Six Ball
    from Nevada
    There are lots of kinds of progress. I'm making a lot of progress but none of it is on my roadster. :(
    Stogy, Outback and chryslerfan55 like this.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks Tim!
    I was on the fence about it at first, but from what I can tell it's far easier to work with than the steel I used for the fuel lines.
    I love your perspective. They're all part of the build, and they're all parts of my world. One day I'll have a spotless garage with the finished roadster sitting on the painted concrete floor, but we have a lot to do between now and then. I'm enjoying the now.
    Funny that you mention the dustpan. That was a gift I received on TRJ's last day in South San Francisco. It had been in one of my co-worker's families for years. And when we swept up the last of the dust and debris from moving more than two decades worth of magazines, it was mine. I still think of those days whenever I use it.
    I'm with you on that. Everything has soul. It's up to us to make sure they live on—these cars are a prime example of that!
    Ragged Edge, Tim, RodStRace and 4 others like this.
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So true! All we can do is keep moving.
    Love the art. Nick's roadster is a huge inspiration. I love his thread, and the fact that he puts tons of miles on the car.
    Hell yeah! Work all day, then come back home and work deep into the night. If that's not traditional, I don't know what is.
    You and I both. It's going to be a big day when the pieces come together.
    Great eye. I should break out the brushes and take a stab at striping them myself!
    Tim, RodStRace, Stogy and 1 other person like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Note: There are a few pieces of this update, some of which will be told in non-chronological order. Please bear with me.
    I'll start things off with this picture of Yama and I. Old bike, old car, old friends. Even with the modern background, it has the feel of the snapshots we always used to publish in TRJ from back in the day. I'll share more about this day in a future Jalopy Journal column.
    enloe, Nobey, Ragged Edge and 6 others like this.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 110: Welcome to Welding (Or Not)
    My building is old. One hundred and one years old, to be exact. Living here at the end of Loyola Terrace has more advantages than one could imagine. There's the lack of traffic, the citrus trees in the back yard, the Edwardian architecture, and Roarie and Pukka—the dynamic duo of calicos—who spend their days roaming the grounds in search of snacks (and sometimes belly rubs).
    What the old building lacks, however, is a strong electrical system. When you walk through the dining room, the lights flicker. In the fuse panel, you'll find hand-labeled gl*** fuses. Although it's great for old San Francisco charm, it's not all that conducive to welding. Nonetheless, I decided to finally give it a try—at home.
    Before I could even think about welding, I had to figure out exactly what I was doing. So, I rolled the car out, jacked up the front end and prepared to get to work.
  7. Budget36
    Budget36
    Don’t tax 100 YO wiring, nor trust if it’s Ben upgraded, etc, unless you can verify/have it verified.
    Unless added, you are probably working with 120vac, and not 240?
    So if your welder is 120, I’d play it safe and get a generator (I asked about running a 120vac welder on a generator a bit back-all was good).
    See even back in the 60’s/70’s aluminum wire was used. I still shudder when I rewired a house I had that was done in 1941 with Al knob and tube. The singed wood near the tubes had me wondering why the place didn’t burn down.
    Just suggesting you play it safe:)
  8. 51504bat
    51504bat
    Not just the wiring. Years ago a buddy got a new plasma cutter. First time he fired it up the transformer on the power pole on the street went boom and everyone on the block went dark. SoCal Edison wasn't happy.
  9. Stogy
    Stogy
    Sheesh it's fall there too...that stuff gets around eh...:)
    Outback likes this.
  10. Tim
    Tim
    from KCMO
    Hmm need to get my welder plug wired in the garage before winter sets in. Thanks for the reminder :)
    Stogy and Outback like this.
  11. RodStRace
    RodStRace
    It's the season when electrical loads go up. Most power companies will come out and inspect heaters for people at no charge, it's easier to check and repair before it goes up in smoke. Call the local Co. and ask if they can check your garage. Explain what you want to do, have a fire extinguisher or two around and show you are a responsible person. They probably have a way to load test circuits. PG&E doesn't have the best reputation, so I'd push the safety angle.
    https://www.pgecorp.com/corp/news-d...-3659-43f8-bfd9-4fe88aebca12&ts=1697643470694
    Stogy, 41 GMC K-18, Six Ball and 2 others like this.
  12. Jeff34
    Jeff34
    Agreed on wiring. If you can, upgrade the panel (in the garage?) with a breaker panel and run a dedicated line for the welder with Romex. I've replaced as much of the knob and tube in my 120 year old hose as I can, but there's still some in tough locations that I haven't replaced. I make sure not to put large loads on those circuits (portable heaters, A/C units, etc.). I put a 50A sub-panel in the garage and upgraded ALL the wiring before I rocked the walls. I also upgraded my main panel (was Zinsco) to a new 200A panel.
    I like the thought of a generator, but with neighbors that close, I think it would be frowned upon.
    Keep on keepin' on Joey!
    Stogy, 41 GMC K-18 and Six Ball like this.
  13. Six Ball
    Six Ball
    from Nevada
    The guy that comes may be the kind that will find lots of code violations and cause your landlord to bring the whole building up to code.
    My son & I blew a breaker in a motel in Lubbock when we plugged in a little watchmakers lathe he had just bought at a pawn shop. When the manager knocked on the door we thought we were busted. She didn't seem to notice the cloud of smoke that rolled past her when I opened the door or the burnt wiring smell and just told us there was a problem with the power and it should be back on soon. :eek:
    Woogeroo, Stogy, J.Ukrop and 4 others like this.
  14. Tim
    Tim
    from KCMO
    If he plugs into plug that is already being used for a laundry machine regularly would
    You figure he’d be in the clear?
    Stogy, Six Ball and Jeff34 like this.
  15. Beanscoot
    Beanscoot
    My house has only a 60 amp breaker / fuse panel.
    I've run my MIG welder for years through the dryer plug, with no problems.
    Stogy likes this.
  16. Six Ball
    Six Ball
    from Nevada
    Is your welder 110 or 220 ? If there is a 220 plug in the shop it is probably new enough to be safe. Is there an electric dryer somewhere near? You don't want to piss off the neighbors by making the lights flicker or screwing up their electronics.
    Stogy and J.Ukrop like this.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Great welding and shop advice. Many of the questions will be answered in this next segment.
    Picking up where I left off:
    Before I could weld anything, I needed to figure out what and where I would be focusing on. The task? Tack these brake tabs to the frame.
    In order to do so, I had to determine their location. Too far forward and they would hit the tie rod. Too far back and they would make the hose rub on the wheel at full lock. On a warm San Francisco afternoon, I rolled out the ch***is and positioned it on jackstands. Intrigued by the process, my six and 11-year-old neighbors came over to help.
    We turned the wheels full-lock left and full-lock right, strategically clamping each hose to the frame with Vise-Grips. IMG_7935.jpg By this point, I was ready to weld. The cul-de-sac, however, had other plans.
    As I mentioned earlier, it was a warm night in San Francisco. That meant I wasn't the only one outside taking advantage of the weather. Neighbors walked down front steps and opened up garages. Dogs chased tennis balls as kids practiced pitching for their upcoming baseball games. Toddlers waddled as Fleetwood Mac echoed from an upstairs window.
    I looked around and decided welding could wait. So it did. For the next hour or so, I worked on tidying up the shop and chatting with friends. Finally, when the sun began to set, people started going inside. It was my chance. I grabbed a flashlight from the hall closet and bounded down the stairs.
    I positioned the gun in my hands. I was losing daylight fast. Gloves on. Welding hood down. Pssspsptput. Smoke. Sparks. A poorly aimed tack. Pssssput. More of the same—except this time I had hit my target. Success!
    As soon as I did, I heard someone walk up behind me. "Do you really think that's a good idea?" she said, staring at me lying on my back on the driveway. "I don't want to see you get hurt." It was my upstairs neighbor and her daughter. "I'll be okay!" I replied with a smile. When I went to get up, I knocked my flashlight and the light went out. That concluded welding for the night.
  18. Tim
    Tim
    from KCMO
    Pssssput
    perfect.
    enloe, Six Ball, Outback and 2 others like this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I have a number of updates from this weekend, but check out what showed up in the mail today!
    While I was working on the car, our very own @41 GMC K-18 was working his magic. He captured Version 2.0 in the garage like never before. The closer you look at his drawing, the more you see, from the filled Deuce shell and King Bee lights (a gift from @nickthebandit) to the dropped axle and striped cable covers. I love the textures and all the details. Check out the "GROCERY" sign leaning against the door on the left, the chrome backing plates and the Hudson steering wheel awaiting its turn.
    What a treasure. Thank you, Dennis. I can't wait to hang it up!
    The H.A.M.B. is an amazing place. I'm so grateful to be here.
  20. Joey, thanks for mentioning me. I didn't do anything special, just helping a young fellow hot rodder with his project.
    enloe, Stogy, J.Ukrop and 6 others like this.
  21. Tim
    Tim
    from KCMO
  22. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    So glad that the mystery surprise package found its way to "LOYOLA TERRACE"
    I would have loved to have been a fly on the wall, watching you trying to be delicate, so as to save the cool white butcher paper / wrapping paper.
    There was a dual purpose for the creation of that piece of artwork.
    First of all, I needed a subject for a new piece of art for the weekly "FAS".
    It ****s to re-post older pieces of art, so I got motivated.
    Second reason and probably the most important reason, is this.
    When I saw the very cool ceramic cup that your mother created, I was deeply impressed at her skills and the focus of that project !
    Indeed, it should be your most favorite cup !
    Then I thought to myself, I am going to throw in several copies of the "LOYOLA TERRACE" place mats, so that at least one of these copies is sent to Joey's Mother, so that she can have it on her table top or wall or where ever she see's fit to have it or to use it !
    I figure that is a fair trade and a cool response, to her kick *** ceramic cup that she made for you!
    That industrial strength mailing tube, is easily re-usable, just sayin!
    Have fun with the place-mats, and if at all possible, if you would give me a 100% positive rating in the feedback stats on my profile, that would be greatly appreciated !
    Spread mirth and joy, where ever you go !
    Sincerely,
    J. Dennis Hicklin
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Dennis, my mom was so happy to hear about the artwork. I’ll be sending her her copy soon!
    Lately, I’ve been busy on all fronts. I have, however, worked to return to my original pace of working on the car a little bit each day. Even if that means hunting for parts, studying manuals, or researching the next steps. I’m heading to the East Coast this weekend, but I figure I’ll post a few photos before my flight takes off. IMG_7996.jpeg
    Double-detent prep in my state-of-the-art paint booth.
    Side-shift x top-loader combo.
    David at work.
    That’s all for now. Details to follow!
    enloe, Ragged Edge, Stogy and 14 others like this.
  24. dirt car
    dirt car
    from nebraska
    Good pun regarding the artwork & the Hudson steering wheel " awaiting its turn"
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Let’s rewind a little bit back to the welding:
    Despite the abrupt ending, I was feeling good about having one tab secured. I clipped on the hose and proceeded to turn the wheels. Not surprisingly, my single tack snapped under pressure. The welder is 110, and I was welding upside down in the dark. "No problem," I said. "I'll try again tomorrow.”
    On Monday, I got home from work around 6 p.m. That ultimately gave me 30 minutes before the sun went down. Wasting little time, I threw on my shop clothes and rolled the ch***is out in the driveway. Rear wheels chocked. Car on jack stands. Frame surface prepped. Welder on. It was time to make it happen.
    Before I could lower my hood, my neighbor Ben came over with his one-year-old son. As we talked, his son danced, played and looked at everything as if it were his first time seeing it. It was all new to him—a new world. He especially liked my motorcycle, with its old chrome and cracked blue paint. The whole scene made my heart happy.
    Lying on my back in the driveway, I looked up at the sky. The air was calm. “One day, I’ll have a space where I can really do this right,” I said to Ben.
    “You will,” he said. “I’m sure of it.”
  26. Tim
    Tim
    from KCMO
    And sometimes you’ll still do it in the driveway anyways haha
  27. dirt car
    dirt car
    from nebraska
    Thats right Tim, I've found at times the lighting when under a project is best in the driveway .
  28. RodStRace
    RodStRace
    Marking this point in the tale, because I'm sure within a year that father and son will get a ride in Version 2.0 and it will mark a high point in both their lives.
  29. Six Ball
    Six Ball
    from Nevada
    I have a nice little well equipped shop that is so full of "treasures" that I do mist of mt work in the gravel drive out front.
    Your wiring is surely fine for your 110 welder. 110v is fine for most car stiff but all the prep is x2.
    Outback, J.Ukrop and 41 GMC K-18 like this.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I love that thought. We'll get there!
    It's all about making it work. The pool where we used to swim back in Michigan had a gravel parking lot. Not fun to walk across those rocks barefoot in the summertime!
    Six Ball, 41 GMC K-18, Tim and 2 others like this.
