Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. A Boner
    A Boner
    Slick!
  2. NealinCA
    NealinCA
    Got the rear end back from my friend JR that set up the new 3.54 gears
    And put the mockup engine back in so I could work on exhaust and a few other details before it comes apart for paint
  3. Outback
    Outback
    from NE Vic, Oz
    Looking good!
    Stogy likes this.
  4. Tim
    Tim
    from KCMO
    Looks awesome!
    Stogy likes this.
  5. You're going to be limited to driving this on those rare cloudy California days!
    porkshop and Stogy like this.
  6. -Brent-
    -Brent-
    Looking fantastic! This project is moving fast!
    Stogy likes this.
  7. Bad Bob
    Bad Bob
    from O.C. Baby
    Don't know who your chrome plating guy is, but, here in SoCal, it's almost impossible to get it done. I remember taking stuff to get chromed in Bell Gardens, and picking it up the next day, back when I was restoring VW's. 40yrs ago.
    Stogy, Outback and -Brent- like this.
  8. -Brent-
    -Brent-
    Stogy likes this.
  9. NealinCA
    NealinCA
    For the new plating, yes, Mike at New Age, but a good majority of the plating on this car is old, swap meet chrome.
    The front axle, perches, front and rear springs, U-bolts, wishbone, front and rear backing plates, shocks, steering box, pitman arm, starter, generator, idler, fan, timing cover, carbs, air cleaners, oil filter, fuel pump and stand, voltage regulator, transmission case and shift top are all old 50's chrome. I have been collecting old chrome for a lot longer than I have owned this car. I am now just filling in with new plating when I can't find old to keep the project moving along.
    Major pieces of new plating are the rear banjo, axle bells and radius rods, oil pan and at the chrome shop now are the chopped windshield frame and garnish moldings.
    Maybe I should name it "The Olde Chrome Coupe"...
    porkshop, bchctybob, Stogy and 10 others like this.
  10. NealinCA
    NealinCA
    One of my favorite 32 5w's, Don Van Hoff's. The caption below the engine pic made me laugh.
    "Don has $90 worth of chrome in front of the firewall and it all shows."
    Neal has $90 worth of chrome in a few nuts and bolts and none of it shows...haha
  11. brEad
    brEad
    Stogy likes this.
  12. hotrodA
    hotrodA
    That’s a great tip! THANKS!
    What did you do with the step/jog in the fender flange where it meets the frame at the running board?
    Hammer it in further up the flange?
    Cut it out and weld it in further up the flange?
    Pic from the net for reference.
    Stogy, Outback and A Boner like this.
  13. dirt car
    dirt car
    from nebraska
    I'm ***uming a much easier means by which to achieve the likes of bobbing the rear.
    Stogy likes this.
  14. NealinCA
    NealinCA
    I put the mockup engine back in the car to sort out the exhaust. I am headed towards some variation of these, 4 flared pipes out under the axle.
    I started working on some hangers
    And added a few shiny bits to the real engine. I just need to decide on the color and get the block painted.
    31chevymike, porkshop, rpm56 and 21 others like this.
  15. pprather
    pprather
    Will those short tailpipes that you are considering, reverberate through the p***enger compartment when cruising at constant highway speed?
  16. NealinCA
    NealinCA
    I've run similar pipes on 2 other cars, and it's not been an issue.
    Aaron J, porkshop, Outback and 3 others like this.
  17. How are you splitting the exhaust? No mufflers, after the mufflers, from side to side?
    Stogy likes this.
  18. NealinCA
    NealinCA
    Tune into our next episode. I plan to get things tacked up this week and will post pics.
    Outback, Stogy, brEad and 2 others like this.
  19. NealinCA
    NealinCA
    A little update for the 5 guys following this build. I had some 1-3/4" tube bent up to extend the Red's Headers back past the K-member. This is the third set I have done like this, as I like having the flange further back. This worked especially well on this car, as I am running straight Scavenger Pipes.
    I slid the chrome rear end under. The torque tube will get plated, but I need to weld some tabs for an E-brake cable before that happens.
    The pipes split using this long radius U-bend after the header flange
    And here is the look I was after
    I am sure it's not for everyone, but I have had this idea in my mind for a long time, so happy to see it coming to life.
  20. alchemy
    alchemy
    A painted torque tube? Pish!
  21. Little Terry
    Little Terry
    Holy smokes! That looks great.
    Once you start chroming it can be hard to know where to stop.
    porkshop, brEad and Stogy like this.
  22. NealinCA
    NealinCA
    It will get plated in time. I need to get brake lines and E-brake cables routed, as I think I'll need to weld a tab or two to the torque tube. Then I'll pull it apart again and send the torque tube, headers and a few other things for plating.
    31chevymike, brEad, Squablow and 5 others like this.
  23. Tim
    Tim
    from KCMO
    Pipes look great! Did you make a Y for each side or did you keep one straight run and one branched off with the bend more like a h ?
    loving the updates :)
    31chevymike and Stogy like this.
  24. NealinCA
    NealinCA
    The outer pipe is straight off the header, the inner pipe is attached in an "h" pattern.
  25. NoSurf
    NoSurf
    Oh my that's gonna sound goooooooooood.....
    31chevymike, Tman and Stogy like this.
  26. Uncle Bob
    Uncle Bob
    from Salado, Tx
    Neal, happy to see you use the proper early '60s nomenclature we used in the day for those pipes; scavengers. It may have been known differently elsewhere, but in the day, in Southern California, that's how we knew them.
  27. hotrodA
    hotrodA
    Any help with this? Thanks, Neal!
  28. NealinCA
    NealinCA
    We haven't addressed that part yet. It is still in mock up stage. Not sure what the final plan of attack will be.
  29. F-head
    F-head
    Looks great Neal
    Cheers
    B
    Stogy likes this.
  30. First, I'm one of the four that are following your build...second, while I may have not weighed in much, you're continuing to rock it! Last, I love this photo...it has the feeling of one of the early a colorized photos from an early magazine.
