Technical Muncie 5 speed
Discussion in 'The Hokey Ass Message Board' started by Jelliford, Oct 23, 2023.
  1. Jelliford
    Jelliford
    Any help on identifying the transmission from the attached picture of the tag on top of the housing would be appreciated. I bought it as a 5 speed that came from a Chevy S10 with a 4.3 engine. I've looked and googled and came up empty with any definite information on what the transmission was used with and what the gear ratios might be. I also tried searching the post on here, but "Muncie" only seems to find 4 speed stuff and when you add "5 speed" it only muddys the search more. Thanks in advance for any help you can give. Transmission 1.jpg
  2. Budget36
    Budget36
    I don’t know about tags and such, but fairly sure it should be a T5.
  3. DDDenny
    That's because the only "real" Muncie is a four speed!
    Who's bar code is that?
    May have better luck if you posted a photo of the transmission.
    Deuces likes this.
  4. Oneball
    Oneball
  5. That's probably a NV3500 5 speed transmission. I believe Muncie plant is a supplier. I have one at home, has integral bellhousing and came from a 2000 S10 Extreme.
  6. Jmountainjr
    Jmountainjr
    Looks to be a NV1500, so not a T5.
  7. In_The_Pink
    In_The_Pink
    This is correct. '96-'99 NV-1500.
    Does your transmission's integral bellhousing look like this from the front?:
  8. pprather
    pprather
  9. gimpyshotrods
    gimpyshotrods
    That's the GM 60-degree V6-8 pattern!
    Algoma56 likes this.
  10. gimpyshotrods
    gimpyshotrods
    Wrong case vent.
  11. Jelliford
    Jelliford
    Yep that’s what mine looks like. I took a chance on it, but looks like it’s not what I need to go behind my 350. Thanks
  12. Ericnova72
    Ericnova72
    from Michigan
    Your first post said that it came off a S-10 with a 4.3.....the 4.3 is not a 60° V-6.
    Anything that bolted to a 90° V-6 4.3 will bolt to an SBC.
    I believe that it is the NV-3500.
    Post a picture of the bellhousing face.
    1934coupe and 427 sleeper like this.
  13. 38Chevy454
    38Chevy454
    Correct, the NV3500 is what was used behind 4.3 V6 (and 5.7 V8 in other trucks/vans). The trans in OP's is the NV1500, used behind the 4 cyl S-10. Both 3500 and 1500 are integral bellhousing; the 3500 having the std chevy V8 bellhousing pattern. Both do not have the traditional separate bellhousing and trans like the old school Muncie 4 speeds, or 3 speeds.
    The NVs also have hydraulic clutch, not traditional clutch fork for throwout bearing.
    Okie Pete and Algoma56 like this.
  14. In_The_Pink
    In_The_Pink
    I think the NV-3500 would be a good choice, especially as S-10 T5s are getting more difficult to find. The NV-3500 is stronger than a non-WC T5, and bolts right up to the traditional SBC block, too. https://www.dieselhub.com/trans/nv3500.html
    If you Google search the code or part number on the sticker/label, you should get a fairly quick idea of what the trans is from and/or fits behind.
  15. 38Chevy454
    38Chevy454
    FWIW, GM used the NV3500 behind the Vortec 350 V8s in full size trucks and vans. Also behind the 4.3 V6. So should hold up fine with a reasonable driving technique and limited street tire traction.
    Tman likes this.
