Technical How to: Hot Rod Shock mounts
Discussion in 'Traditional Hot Rods' started by chaddilac, Oct 22, 2023.
  1. chaddilac
    chaddilac
    Here's a little how to on early F1 shock mounts and using them on any hot rod!!
    The style I'm using are 1948-1952 F1 Pickup shock arms, but Dodge also made some from 48-60s that are very similar!
    Check it out!
    -Brent-, Tim, ramblin dan and 4 others like this.
  2. ramblin dan
    ramblin dan
    Good video. I've planned on running those front shock mounts on my project and collected a few pics over time. a3e1f1b2321b06f4a50ee1c042efb37c[1].jpg E2B490BC-A654-4FC6-AEAA-157A52092A81.jpg f1 shock mount dimensions.jpg f1shock mount dim.jpg f-100 ford modified shock mounts.jpg shock mount.jpg s-l16001AD4VT20.jpg stock shock f100 ford mounts.jpg
    alanp561, RodStRace and chaddilac like this.
  3. 31Apickup
    31Apickup
  4. travisfromkansas
    travisfromkansas
    I just added it to my watch later!
    chaddilac likes this.
  5. the oil soup
    the oil soup
    from Tucson,AZ
    The ‘48 thru ‘53 Dodge trucks are B series, ‘54 thru ‘60 C series and ‘61 thru ? are D series, the B series definitely used that style front shock mount. Nice how to video.
  6. Dak Rat
    Dak Rat
    from NoDak
    I used the Dodge version on my '32, they are shorter than the Ford units. Still require them to be heated and bent a little to get the right angle for the shocks.
  7. jeff.l.hecht
    jeff.l.hecht
    Bob Drake repops the F1 mounts, I got mine from Summit for 80 bucks shipped if you don't care that they are reproduction. Still very good quality.
  8. -Brent-
    -Brent-
    Nice work, Chad! Fenders do complicate the mounts a little, don't they? Especially fabbing with them on! They do look great.
    I squished my axle narrower so the steering hoop came close to the shock body and that needed some TLC, too.
    20200701_132105.jpg 20200701_132052.jpg 20200701_132134.jpg 20200701_133121.jpg PSX_20200706_082923.jpg
