Hot Rods Picked up an advertised ‘48 Ford -is it?
Discussion in 'The Hokey Ass Message Board' started by fairlaniac, Oct 26, 2023.
  1. fairlaniac
    fairlaniac
    from Denver, PA
    Got this for $100 today. Guy bought it from an online auction and had not removed it. Had to be gone by 5:00 pm today. I’m still not sure why I got it? Anyhow, I ***ume this might be the VIN? It was on the driver side dash. What do I have? Looks like some numbers might be illegible?
    Thanks!
    Doug
  2. BJR
    BJR
    47 or 48, not a 46.
    Jim Bouchard likes this.
  3. Jim Bouchard
    Jim Bouchard
    Looking at the tiny pictures, the exterior door handle suggests’47-‘48 Ford.
    The dash, looking through the window does not look like a’46-‘48 ford dash. I cannot really see it though. I would make a wild *** guess and say the number on the dash goes with the dash from another car as ‘46-‘48 Fords did not have numbers like that on the dash or anywhere else besides the frame.
    The vin number on your car should be on the driver’s side frame rail top near the steering box. It will have a star stamped at the front and rear of the number.
    seb fontana and Carter like this.
  4. Tim
    Tim
    from KCMO
    I don’t know that the number on the frame really tells you much though. It’s a 47-8 either way. Not a lot left for me to really pin it down further
    and yeah not a ford dash that I’m
    Familiar with
  5. Marty Strode
    Marty Strode
    It was the deluxe model with power steering !
    prez and Jim Bouchard like this.
  6. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    The bodies were pretty much the same from '42 - '48. Same tail light openings and use the same lights for those years, too. The dash is not correct for that body. The VIN does not go with that car. Even if it were a state issued new VIN, it should be stamped or tagged on the A pillar or the firewall and stamped on the frame. Clean and look closely where the left frame rial attaches to the front cross member. Thats where the original VIN was stamped. Often illegible, though. It could maybe be a Mercury body, too. (?)
  7. rusty1
    rusty1
    ...well worth more than 100 bucks, one rear fender's worth that...
  8. woodiewagon46
    woodiewagon46
    from New York
    If the gl*** is original you might get some info from the Bugg's on the gl***.
  9. fairlaniac
    fairlaniac
    from Denver, PA
    This was primered over on the firewall. Looks like NOR stamped? What might this tag be? Thanks!
    Doug
  10. razoo lew
    razoo lew
    from Calgary
    That tag has nothing to do with vehicle serial number either. As others said, the serial number was originally on the frame near the steering box, and on the engine bellhousing. It was not on any body tags.
