Technical Can you post a link to a quality battery disconnect?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Oct 28, 2023.
  1. Budget36
    Budget36
    I need one for non-automotive, but I recall some threads saying “this one, not that one” etc.
    Getting tired of cleaning things up and charging a battery.
    Thanks.
    Tman likes this.
  2. '29 Gizmo
    '29 Gizmo
    from UK
    The one i use. Simple and effective
    3quarter32 and Budget36 like this.
  3. Budget36
    Budget36
  4. '29 Gizmo
    '29 Gizmo
    from UK
    You can find them on ebay or amazon. Just type
    Side Post Battery Disconnect
    Budget36 likes this.
  5. RICH B
    RICH B
    The only battery switches we found worth installing on trucks were Cole-Hersee. Now this was 15 or so years ago; so I can't say the same quality exists today; but I would start there if I was looking for a switch now-a-days.
    '28phonebooth, Tman, ClarkH and 3 others like this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    Screenshot_2023-10-28-16-52-02.png Agree with Rich B , 25 years with Cole Hersee
    rockable, mad mikey, Tim and 6 others like this.
  7. Ebbsspeed
    Ebbsspeed
    @RICH B
    The link 2OLD posted says it's rated at 40 amps. Are you guys running starting current through these, or just using them to disconnect everything except the starter?
  8. Budget36
    Budget36
    Good question/point.
  9. denis4x4
    denis4x4
    from Colorado
    Anything that’s NHRA and SCCA approved. Another vote for Cole-Hersee.
    Budget36 and Truckdoctor Andy like this.
  10. CSPIDY
    CSPIDY
  11. Mr48chev
    A Quick car master disconnect switch is only rated for 140 amps Or the one below it is rated at 300 amps.
    My 25 ft Bayliner with the 350 in it has one of the Perko disconnect switches that works great but they are designed for 2 batteries and are rather large. It might get confusing with one battery. Screenshot (231).png Screenshot (232).png Screenshot (233).png
  12. We use Cole Hersee at work on trucks up to class 8 and sometimes 4 batteries. It’s the only one I would use.
  13. Bandit Billy
    Bandit Billy
    I use this on all of my cars. Rated for an alternator that puts out up to 125 amps, 4 poles to not just disconnect the battery but everything else. It will kill a running engine in case of emergency.
  14. deathrowdave
    deathrowdave
    from NKy
    Cole Hersee in my 32 125 amp continuous , 600 amp intermittent . 30 years old still working as new . Buy the best once or buy the copy 3 X .
  15. RICH B
    RICH B
    Pretty sure the Cole-Hersee switches we used were like 2000 amp intermittent. Some fleets spec'd them in the negative cable; I don't remember the reasoning right now.
  16. Kerrynzl
    Kerrynzl
    Mike, I use one of these on my trailer winches and my race cars [Ford used the same for OEM on my FR500C race car]
    I throw away the stupid cap !
    Underneath the "boot/sleeve" I drill a tiny hole in the groove and screw in a grub screw [so the Key cannot be removed]
    I pack a bit of dielectric grease around the key and slip the boot back over [and it lives outside 24/7]
    Here on my old trailer
    This is a "must have" on a trailer winch with wireless remote [sometimes the remote will have a mind of it's own]
    This is the Factory Ford Battery Cut Off Switch [it is identical to the ones I use above]
    I did the grub-screw mod on this as well
  17. BamaMav
    BamaMav
    from Berry, AL
    Had several class 8 semi trucks with the Cole Hersee switchs Never had a problem out of any of them. Some were inside cab mounted out of weather, others were mounted on a frame rail.
  18. miker98038
    miker98038
    Just fwiw. I’ve used a number of the simple ones like 29Gizmo used. But on one vehicle, a stock LT-1, I’ve had 3 fail. I’m lazy and cheap, so I carry a wrench in the console to remove it when necessary, hook up the battery and start the car. Why just that car I don’t have a clue. I’m using them for seasonal storage, no rules requirements.
  19. My '50 Chevy truck had one already in it when I bought it. I haven't paid attention to what brand it is but I like the fact that it's there. It so happens that the truck also came with no door locks so the power disconnect feature gives me a certain degree of comfort. At home, the truck is always parked inside but there are often times when I want to drive somewhere that may require me to have to walk away, out of sight of the truck for a while. The disconnect is the type that has a "paddle" key that you remove and slip in your pocket. Everything is shut off: no lights, no horn, no start. The location of the port for the key is well hidden by the nap of the carpet. There's no clue where it is or if it's even in there at all.
    I have a short list of things I'm fixing my own preferred way. I guess I'd like to have key lock doors someday but for now, I'm not sweating it too much.
    mad mikey, loudbang and Budget36 like this.
  20. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I use the same one as @Kerrynzl does... I like the fact its for weather protection as well.. works very well.
