Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
    This all started a couple of years ago when I built a second race car. You can’t have too many race cars can you? Apparently you can! I’ve just not got the time or energy to run two race cars so one had to go. What to replace it with? I started looking at 40s/50s Chevys and Pontiacs but then one day this popped up and I decided it was the one. Yep it’s got too many doors and it’s a Ford in a frock.
    The interior looked great
    And the underside is tidy compared with what we’re used to due to road salt over here.
    It seems pretty unmessed with so should be a great starting point not having to fix a bunch of Bubba’s doings.
    It’s hopefully now making its way across the pond, just in time for winter to arrive! Which will give me the chance to get it sorted. Im just after a nice cruiser/mild custom to use as a car, go places with the Ms and with limited budget this time around there’ll be no 427s or AOD swaps. Plans as it stands are:
    Protect the underside.
    Engine seems pretty leaky so plan is to pull that and give it a going over. Already found an alloy manifold and a 4bbl Autolite from a Thunderbird, need to look at a cam swap and the rest will be dependant on condition.
    I’m not sure about the 14 inch wheels, tyres are pretty old anyway. I like 15 inch steels but by the time you’ve bought them, painted them and got caps you might as well have gone alloys. If it wasn’t for the upkeep I’d be leaning towards polished Supremes or Torq Thrust.
    The stance isn’t right but I can’t work out it it’s too low at the back or to high at the front.
    Keeping myself busy during the wait surfing eBay/forums for any bits that I can use. And keeping telling myself that a Mercury isn’t really Ford!
  2. I’d drive it
    As is
    with a big ole cheesy grin
  3. guthriesmith
    guthriesmith
    Looks like a nice, unmolested car to enjoy. Congrats!
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Great pick.
    Like the plan.
    chryslerfan55, Oneball and Spooky like this.
  5. El Caballo
    El Caballo
    from Houston TX
    Handsome car, it’s a highway car (if you can afford to feed it). Nothing sounds quite as sweet to me than a cammed FE, get the dual exhaust for it and you won’t regret it. Very nice score.
  6. Mr48chev
    Yuppers, that car just flat does not need or want a lot of modifications. Dual exhaust with nice sounding mufflers and maybe swap intakes for a bit more grunt along with changing the timing gear and chain if there isn't do***emtation that they have been changed lately. Any thing over 60,000 miles I would change them for peace of mind. Truthfully outside of pressure wash and scrub and paint back correctly I wouldn't do a lot under the hood. Make sure that the belts and hoses are in good shape or replace them and work on reliable more than fast.
    Still it isn't a race car or custom as it is just a nice cruiser that you can load family or friends in and go off down the road in comfort. Wheel change to 15 inch? only if 15 inch tires in the correct size are a lot easier to get than 14 inch tires are. I'd find some cl***y looking hubcaps and call it good.
  7. I’d cruise the $&@“&@$ outta that!! I’m not even sure I’d change the camshaft, if I pulled it to reseal it (I would!!) I’d put a 4V with electric choke on it with nice, quiet dual exhaust. Personally, I would use the stock exhaust manifolds after taking them to my large belt sander. That is the exact type of car I’d be looking for if I didn’t have 9 million other things going on.
  8. ClayMart
    ClayMart
    "Ford in a frock" LOL! Never heard that before. Though I have heard people refer to a Pontiac as just being a Chevrolet with lock-washers!
    Why so anxious to change out the cam, at least if it's still running good? With all the grief that many folks seem to have breaking-in a new flat tappet cam and lifters I think I'd leave well enough alone. Or do you Brits still have high zinc oil readily available everywhere? :confused:
  9. 05snopro440
    05snopro440
    I'd lower it a bit (mostly front), put on some 15" wheels, and cruise the **** out of it. That's a great looking car!
    anthony myrick and Oneball like this.
  10. Oneball
    Oneball
    It’s got a dual exhaust on at the mo so that’s covered although it’s welded to the existing down pipe. For cost I want to keep the existing exhaust manifolds but am worried about taking them off one is definitely leaking so there isn’t a choice, but the bolts in the head look tricky!
    I’ve got a 4100 off a Thunderbird, bit of a bargain hopefully, odd description on eBay so got it for less than the gasket set for it cost me. Rebuilt it this week so was thinking of going to a similar spec cam to the T-bird if I’ve got the engine out wasnt thinking of anything nutty. Run an additive for break in and then VR1 like the race cars. With a 3.0:1 rear end it’s going to need some low down grunt.
    I guess I always think 15” are better. There’s more choice in 15” tyres but perhaps 14” with a bigger white wall would be good too.
  11. That is a fantastic carburetor, pretty much exactly what I had in mind. Great score!
    Oneball likes this.
  12. El Caballo
    El Caballo
    from Houston TX
    If that 4100 doesn’t work out, Summit has their own brand of 4100 clone, M2008. I had one on my 1978 F100, no issues.
    Oneball likes this.
  13. bobss396
    bobss396
    4 doors were always a bargain, nobody wanted them. So I would grab up a nice clean one when it came around. Cops never gave them a 2nd glance and they were great sleepers. I had a '66 Caprice 4 door that surprised a lot of people.
    lemondana, Algoma56 and Oneball like this.
  14. Car is dang near perfect.
    I miss my old 352.
    The best FE I ever had
  15. Oneball
    Oneball
    4 doors also means the Ms has somewhere for her “clean” bags :confused:
  16. theHIGHLANDER
    theHIGHLANDER
    What a tease. No more pics?
    Nice car...
  17. Oneball
    Oneball
  18. williebill
    williebill
    That car is beautiful. Got A/C, too. Perfect.
    34 5W Paul, Steve Ray, Deuces and 4 others like this.
  19. bobss396
    bobss396
    I would daily the **** out of that.
  20. bobss396
    bobss396
    I had an oil belching 1964 vintage 352 that ran amazing well considering. I had another in better shape with a 3-speed behind it, that was in a Country Sedan.
  21. Oneball
    Oneball
    The guy I bought it from asked what I was going to use it for, when I said I was going to use it like a normal car he seemed a bit shocked.
  22. El Caballo
    El Caballo
    from Houston TX
    I had a 1968 Galaxie 500 with a 390 that I daily drove from 2001 through 2008, it's what they were made to do.
  23. FrozenMerc
    FrozenMerc
    Be careful, soon you will be turning it into a custom....
    The other cool thing, is where ever you go, you are about guaranteed to be the only one driving a '62 Merc, especially on that side of the pond.
    Mine didn't start out nearly as nice as yours, but it finished up OK....
  24. Oneball
    Oneball
    I know! The engine is the slippery slope for me! I guess the great thing is it’s an up and running car already.
    I read your build thread a couple of weeks ago. Such a fab looking car. Are you happy with your camshaft choice?
  25. T. Turtle
    T. Turtle
    Congrats on getting this oh so clean car. Oh and given that we're in the UK and Europe we don't know about that 4-door stigma anyway...
    Oneball likes this.
  26. Oneball
    Oneball
    You say that but you just wouldn’t look cool in a 4 door Marina ;)
    Hopefully the car will be here end of the month. We thought it’d be safer to post old paperwork a bunch of stuff but somewhere between USPS and Royal Mail they seem to have lost it :(
    chryslerfan55, Okie Pete and Ned Ludd like this.
  27. 57Custom300
    57Custom300
    from Arizona
    Nice car. Kinda makes you want to go out and buy a moredoor. Question about your carb. It looks like the lever and link to the rear barrels are missing. Also the pivot for the lever that operates the rear barrels looks like it's been drilled out. Not a total loss though. They used to make an aftermarket part that you installed on the rear barrel linkage that eliminated the function of the vacuum actuator at the rear of the carb. Essentially made it a mechanically operated secondary. Don't know if they are still available but you can ck it out. Last one I had to make myself. Maybe it's just the way you took the Pic or you just haven't installed it yet but I don't see them.
    chryslerfan55 and Oneball like this.
  28. Oneball
    Oneball
    Thanks, it’s all there it’s just the angle of the pic and I think the pivot is shiny so it looks like a hole.
  29. Oneball
    Oneball
    Well the parcel isn’t lost, it’s in Ghana!
  30. 'Tricky' is the polite term for those bolts. The last one I had with leaking manifolds, all but four broke between the two sides. Be prepared to pull the heads to have the broken ones extracted. That's the FEs one major maintenance flaw. And if it is leaking, it's a good idea to have a light machine p*** done on both the heads and manifolds to ensure a flat surface so the leak doesn't come back. Reinstall with grade 8 bolts, and torque to spec in small increments to avoid warping.
    And if you do pull the heads, give some thought to installing some higher-compression pistons. More compression will really wake that 352 up, with not only more power but better fuel economy. I realise this is getting out of the lo-$$ realm, but if you have to tear it down that far....
    VERY nice more-door!
    chryslerfan55, 61Cruiser and Oneball like this.
