Projects 1951 Ford Shoebox build
Discussion in 'Traditional Customs' started by Crenninger, Oct 29, 2023.
  1. Crenninger
    Crenninger
    So, im going to be using this to track my build a little easier, i have posted a few questions on this car so far. so here we go!! from the beginning. purchased this car back in Dec,21 with a plan of having it running in a year for a car show in Tombstone AZ in Nov and well that didnt happen. missed it again this year(show is next weekend) life got in the way and didnt want to rush.
    here are a few picture's of how i got the car
    Chopped 3"( i think)
    shaved door handles and gas door(i hate)....
    Ford 8" from a Granada
    lowering blocks in rear
    lowering spindles
    20220206_143543.jpg 20220317_180454.jpg 20220321_162721.jpg 20220329_104952.jpg 20220329_105000.jpg Screenshot_20211218-105540_Facebook.jpg Screenshot_20211218-105546_Facebook.jpg Screenshot_20211218-105549_Facebook.jpg Screenshot_20211218-105553_Facebook.jpg
    slim38, winr, guthriesmith and 6 others like this.
  2. Crenninger
    Crenninger
    First thing i did was take a surface conditioner tool to the rust and puddy... a afternoon later and a dozen cand of primer, at least it is not rusted anymore... now a few holes to fix..... later..
  3. Crenninger
    Crenninger
    Helped a friend pull a 400 sbc from his 78 k20 so he can throw a Diesel in the truck ... my fee? a 400 sbc engine... and a Th350 51k milage on the engine i know it will upset alot of people... BUT its free and a engine that is free is the engine for me
    Moedog07, winr, guthriesmith and 6 others like this.
  4. Crenninger
    Crenninger
    new Master cylinder installed, all new wheel cylinders and brake lines.... and yes.. i did forget the fitting once on a flare
    winr, guthriesmith, coupe man and 3 others like this.
  5. Crenninger
    Crenninger
    and this makes it up to today, i had a old block and empty trans case i used to mock up the shoebox central mounts, ill need to cut the crossmember and notch it, going to be very tight at the oil pan.
    ffr1222k, winr, guthriesmith and 4 others like this.
  6. Greg Rogers
    Greg Rogers
  7. bobss396
    bobss396
    Subscribed :cool:
    Crenninger likes this.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    I’m in…
  9. What you doing with the front seat out of that car?
    I also have a 51, Gonna do a "G***er" style build
  10. '49 Ford Coupe
    '49 Ford Coupe
    Congratulations! I bought my 49 coupe which I named The Judge back in 2011. Luckily the body was in very good shape and had been primed with epoxy primer.. It took me 8 years nearly every day to get her where she is now.
    However I decided to do***ent it in a different way.. so that I could organize the subject matter.. I had two reasons to do it that way. So that in the future I can remember what the hell I did, and when I'm gone the next owner will be able to figure out what the hell I did...
    The website is organized in galleries with a specific subject for each gallery.. it's best to just scroll a gallery rather than tap on a given picture because you lose the narrative that goes along with the photograph. For the included videos you have to tap on those to play them but then hit the back ****on to get back to the gallery.. for those who are interested the link is in my profile, or you can Google "1949 Ford Coupe Paul". Perhaps you can get some ideas here and there for your build!
    63Biscuit, seb fontana and D type like this.
  11. Crenninger
    Crenninger
    I'm not sure yet, debating on just re upholster it. I was given a full roll of red vinyl....
    Okie Pete likes this.
  12. Crenninger
    Crenninger
    Didn't do anything to amazing today, just worked on degreesing the sbc400 and removed the factory oil pump to install the chevy 2 pump, tho I behave a problems..
    Mounting the pick up tube. The bracket doesn't line up with the mains in the 400, probably will have to cut the tab off and figure something else out.
    Took some measurements to check crossmember clearance.
    And no.. the oilpan is not staying purple
    guthriesmith and Okie Pete like this.
  13. bobss396
    bobss396
    You have to drill and tap a hole in the block web for a factory-ish installation of the Chevy II DSCN0031.JPG DSCN0032.JPG DSCN0034.JPG pick up tube. Fun to do on a newly ***embled short block...
  14. Crenninger
    Crenninger
    I don't think I can do that, the 400 has bigger mains, I don't have any room.
    I was thinking about cutting off the bracket. Bolting it down then rewelding it to the tube
  15. bobss396
    bobss396
    One think to watch is that one of the rods may hit the pump body. Bolt it on loose and give the crank a spin. That pump is made for a 3.25" stroke, no bueno with my 3.48" stroke.
  16. Okie Pete
    Okie Pete
    Very Kool . Building Your Car with what You can scrounge up.
  17. guthriesmith
    guthriesmith
    Very kool! I will be following along. :cool:
  18. Crenninger
    Crenninger
    I didn't think of that, looking at the pictures I see what you mean, I'll double check tonight.
  19. Crenninger
    Crenninger
    That is the plan, been going to are local swapmeet, if I can't find it there or locally I'm trying to not buy it. Only exception so far was when I splurged got the wiring harness online.
  20. Crenninger
    Crenninger
    Thank you :) most progress will be on weekends. except this coming up weekend, I'll be at Tombstone AZ for a carshow I volunteer at
    guthriesmith likes this.
  21. ModelAMitch
    ModelAMitch
    Very cool, keep do***enting the process for us lurkers!
  22. Crenninger
    Crenninger
    Well... crank does hit oil pump.... new problem. Need to figure out how to make that work or find a new oilpan that will work or figure something else out to clear tie rods
  23. Jalopy Joker
    Jalopy Joker
    as has been said many times, nothing is easy. '51 front-end is one of the best lookin. might want to do some more wheeling & dealing to get a 350. search online for Steve's Nova site that may have info on whether or not a 400 ever used with Nova pan
  24. Crenninger
    Crenninger
    i did some measuring, if i notch the stock pan in the back 1" deep and 1" tall it will clear and back on track :) im going to clean the pan up and do some cutting and tac welding to make it clear. at best. problem fixed... at worsted i get to practice welding and improve then it still wont leak :p
    then sell the chevy 2 pan/oil pump
    Jacksmith and Okie Pete like this.
  25. SuperKONR
    SuperKONR
    from Earth
    That's a sweet car, looking forward to seeing it come together! Don't blame you for using a sbc, cheaper and much easier to find parts no matter what people try to tell you...
  26. bobss396
    bobss396
    This is what I had to go for pump clearances. I just cut and tried it until it worked.
  27. bobss396
    bobss396
    Look at '55-57 Chevy oil pans that have tie rod clearance. It was too iffy in my case, I still may have had to alter it.
    https://www.summitracing.com/parts/...MIhazGyduiggMVmU1yCh0jvwNOEAQYCCABEgLSMvD_BwE
  28. Crenninger
    Crenninger
    Won't work for me unfortunately, it's hitting right where th strainer tube goes in. Good idea tho
  29. Crenninger
    Crenninger
    I haven't gotten more into getting the engine fit, BUT I did get the gauge rebuilt converted to 12v and cleaned up! Along with the dash.
    Tho I need to do some research on changing the milage to match the engine.
  30. Fat47
    Fat47
    We used to use an electric drill on the speedo to run the milage back. You can contact Rusty of Speedometer Service here on HAMB to get a professional opinion.
