Art & Inspiration Yikes! I don’t think I’d do it that way
Discussion in 'The Hokey Ass Message Board' started by nochop, Oct 29, 2023.
  1. nochop
    nochop
    from norcal
  2. Max Gearhead
    Max Gearhead
    from Wisconsin
  3. BJR
    BJR
    That's usually reserved for a Camaro parked next to a mobile home!
  4. CME1
    CME1
    WOW ! Thats a disaster waiting to happen!
  5. Joe Blow
    Joe Blow
  6. 1952henry
    1952henry
    Ha, I know you couldn’t do that in ND, the wind would have it in the neighbor’s yard lickety-split.
  7. jimmy six
    jimmy six
    Got to get it high enough to fix the rust without bending over. I’d put 4 anchors in the concrete and a strap for and aft and go to work. No big deal.
    427 sleeper and leon bee like this.
  8. Okie Pete
    Okie Pete
    The blocks should be turned on edge . They are stronger that way.
    427 sleeper, pwschuh, X-cpe and 12 others like this.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Not to throw shade, but,,,
    I need more informstion
    427 sleeper and Spooky like this.
  10. El Caballo
    El Caballo
    from Houston TX
    I guess I’m getting old, seeing things like that makes me concerned about safety.
  11. wheeldog57
    wheeldog57
    Like @Okie Pete said, cement blocks are MUCH stronger with holes facing up. I'm scared for this guy, his family, and anyone else who happens by
  12. scotts52
    scotts52
    Not at all saying it's ok, but that weighs a lot less than the mobile homes I've seen that way. Lol
  13. DDDenny
    I don't much care about that guys' safety, because he obviously doesn't either.
    It's that nice 55 sedan I'm concerned about!
  14. larry k
    larry k
    Are “ yah “ feelin lucky punk ? Well are “ yah “ ???
  15. lostn51
    lostn51
    from Tennessee
    This is what I’m wondering about… how the hell did they get the damn thing up there so high to begin with?!?
  16. seb fontana
    seb fontana
    from ct
    Probably photoshop to get a rise.
    427 sleeper, Spooky, nochop and 2 others like this.
  17. Doublepumper
    Doublepumper
    from OR-WA, USA
    Mmm...OK...now what?
    427 sleeper likes this.
  18. ClayMart
    ClayMart
  19. gotta56forme
    gotta56forme
    from Seattle
    Ooohhh... driveway Jenga... Place your bets!
  20. RMR&C
    RMR&C
    from NW Montana
    I'm not seeing a problem?
    427 sleeper, hrm2k, Chicster and 3 others like this.
  21. lurker mick
    lurker mick
    Why is there no shadow from the body on the ground? Looks to be a photoshop to me.
    Mick
  22. HOTRODPRIMER
    HOTRODPRIMER
    The shadows on the far side of the concrete blocks look real enough to me, with that said it does look dangerous.
    I guess most of us have pushed out luck at one time or another, it looks sketchy but the body was balanced on 4 jack stands and two 2" x 6" boards on top of the jack stands.
    Once the frame was out of the way I added two more jack stands in the rear, it sat like this for several months. HRP
  23. Slopok
    Slopok
    Hold my beer! :eek:
  24. Los_Control
    Los_Control
    from TX
    Would be better if the blocks were installed correctly. They really have no strength lying sideways.
    If one block is weakened or has a crack and it fails .... lose one lose the whole load.
    Concrete blocks are designed for strength straight up and down. For building they would run rebar through the center and fill with concrete. Or even mobile homes no concrete but they are installed properly .... not sideways.
    Will hold the weight of the car fine if installed properly ..... the way it is I would not touch it with a 10' pole.
  25. gene-koning
    gene-koning
    The 1st point is that with the position of the cement blocks, the frame likely was not rolled out from under the body as it now sits. The blocks would be in line with the tires on the frame. That would mean the body was sat on the blocks after it was removed from the frame. Yes, the blocks would have been stronger if the holes were facing upward, but the reality was, that body may have only been on the blocks for a short time frame, maybe just long enough to spray the bottom, or maybe long enough to get a different frame ready to transport the body to. Cement blocks are a great, and cheap temporary stand as long as you are not working under them.
    427 sleeper and nochop like this.
  26. nochop
    nochop
    from norcal
    Got none, thought it would be a funny post
  27. nochop
    nochop
    from norcal
    I robbed the pick off of fb
  28. Lone Star Mopar
    Lone Star Mopar
    What the hell, somebody tell em he's missing a lug stud before someone gets hurt.
  29. Joe Blow
    Joe Blow
    loudbang, Okie Pete and nochop like this.
  30. Bandit Billy
    Bandit Billy
    It isn't apropos to our hobby or the topic of hot rodding but it is important for safety's sake to mention that
    mobile homes (doubles and triples) are supported from the frame that runs under the center of each section of the home (like a railway car) to a concrete pad with hold downs. The concrete block wall around the parameter is a wind shear wall to keep air out from under the home and prevent rodents from taking up residence. These walls are not structural and in fact bear no weight, there is a weatherstrip between the blocks and the bottom of the home.
    Concrete blocks are a foolish way to support weight like that Chevy.
    Toms Dogs, 05snopro440 and nochop like this.
