Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. I do not envy you the sore muscles you will have when you are done. Until then, rest well and dream of flatheads and four speeds.
    Just Gary and Chevy28 like this.
  2. brEad
    brEad
    Fantastic work on your dash! Really a step above everyone else.
    Chevy28 likes this.
  3. Chevy28, your attention to detail in the "unseen" places is the real testament to your craftsmanship. You would never be comfortable driving your roadster had you not taken the time to detail those areas as carefully as the "seen" areas. Your eye for design is incredible, especially with the three windshield post feet that subtly mimic the spearhead shape of the cowl reveal. You are building at a very rare and high level. Beautiful work.
  4. HelminenHotrods
    HelminenHotrods
    from Finland
    Too kind words ! Thank you !:)
    Okie Pete likes this.
  5. HelminenHotrods
    HelminenHotrods
    from Finland
    The dash has an slightly round shape to follow the shape of the gauge, so i had made that little step for switches/knobs. It also gives more 3d factory kind-of look IMG_5899.JPG
    The switches are also DIY. Using different parts to make it work and look good. The scripts are lazer marked to aluminium and pressed to shape.
    The horn switch i had to do fully from ground up, becauce i didnt find any pull-opereted horn switch. IMG_5964.JPG
    IMG_5962.JPG IMG_5952.JPG IMG_5977.JPG IMG_5951.JPG IMG_5982.JPG IMG_5943__01.jpg IMG_5976.JPG IMG_5946.JPG
  6. patsurf
    patsurf
    what exactly did you do to make the horn switch?--wow!
    Stogy and Chevy28 like this.
  7. Squablow
    Squablow
    The custom made stainless dash end trims are incredible, I would not have believed those weren't a factory stamped part if I hadn't seen it here. Extremely nice work.
  8. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Somehow I did not catch this thread. Only viewed the pics.
    Sorry if you have already told us bui...
    One question.
    How Did You learn to make Magic
    05snopro440, Spooky, Stogy and 6 others like this.
  9. Finnrodder
    Finnrodder
    from Finland
    Thats some beautiful work there!
  10. Outback
    Outback
    from NE Vic, Oz
  11. HelminenHotrods
    HelminenHotrods
    from Finland
    I'll get back to it once i remember to shoot some photos !
    In the meanwhile, here's a video of the windshield :
    Deutscher, dwollam, harpo1313 and 5 others like this.
  12. NJ Don
    NJ Don
    I like the parallel sides!
  13. brEad
    brEad
    That windshield is absolutely gorgeous!
  14. Okie Pete
    Okie Pete
    You are a Craftsman, amazing work
  15. hfh
    hfh
    from Western MA
    That’s a beautiful windshield!!
  16. HelminenHotrods
    HelminenHotrods
    from Finland
    Heres the diy pull-operated horn-switch
    Simplified : the nylon-plastic insulates from the switch frame. And the screws where wires mounts, connects together when pulled and touching the metal circular part. IMG_20230815_212039.jpg IMG_20230815_212132.jpg IMG_20230815_212055.jpg IMG_20230815_212222.jpg IMG_20230815_212141.jpg IMG_20230815_212240.jpg IMG_20230815_212313.jpg
  17. brEad
    brEad
    Simple and effective switch! Nice work!
  18. oliver westlund
    oliver westlund
    Well....this is shaping up into my favorite roadster. You really are a helluva fabricator and hot rodder. Color me impressed! Givin me tons of ideas for my 30
    05snopro440 and Stogy like this.
  19. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you brother ! Inspiration is the key !
  20. HelminenHotrods
    HelminenHotrods
    from Finland
    Here's how i did the u-bolt eliminator.
    Because of the notched frame, and 3 inch channeled body, the radiator space is really limited.
    IMG_20230406_160439.jpg IMG_20230406_170819.jpg IMG_20230406_181548.jpg IMG_20230406_181603.jpg
    Chopped/channeled 32 grille shell:
    IMG_20230406_140515.jpg IMG_20230406_141431.jpg IMG_20230406_152613.jpg IMG_20230406_152656.jpg
    Deutscher, dwollam, hfh and 12 others like this.
  21. Outback
    Outback
    from NE Vic, Oz
    Very interesting approach to the front spring clamp!
  22. oliver westlund
    oliver westlund
    Has the front spring clamp been done this way before? My concern is instead of a pair of u bolts, now two welds are keeping the spring attached and the crossmember is absorbing the impacts in a different way. Not trying to be a naysayer just never seen that done. If it works its a neat idea!
  23. HelminenHotrods
    HelminenHotrods
    from Finland
    I haven't done it before myself but i have seen cars build with these type "weld-on u bolts".
    There are kits for sale in speedway etc or :
    https://welderseries.com/store/Front-U-Bolt-Eliminator-Kit-p51247671
    I think it will be fine. But i understand your concern, and it does feel kinda stiffer when bolted down because there is nothing to flex like in traditional u-bolts
  24. Stogy
    Stogy
    I love this place...great stuff Markus...thanks for sharing your journey in Hotrod with us...
  25. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you !
    Great to back on hotrod build after getting distracked to an 1958 vespa build o_O:D
    Not hamb material but there you go : IMG_20230505_210745.jpg IMG_20230523_214821.jpg IMG_20231003_182856.jpg IMG_20231003_183026.jpg
    Next step on the roadster is drivetrain. First mounting wheels on and getting it back on ground to really get a good view. IMG_20231007_194746.jpg
  26. HelminenHotrods
    HelminenHotrods
    from Finland
    The radiator "module" i build earlier. I will get back to it more :
    BigJoeArt, Okie Pete, 2Blue2 and 7 others like this.
  27. clem
    clem
    Been done plenty of times previously.
    I can’t see how anything changes in regards to the crossmember absorbing impacts differently, as nothing structural is different, (apart from a little heat from the weld and we tend to weld things now rather than using rivets).
    The only difference is that every time you loosen a U bolt, you are ‘technically’ supposed to throw it away and start with a new one.
    By using this method ‘technically’ - you only have to replace the 4 bolts, which may be easier to fit and cheaper and easier to source.
    05snopro440, BigJoeArt, Stogy and 3 others like this.
  28. HelminenHotrods
    HelminenHotrods
    from Finland
    Windshieldframe process thrown together
    Barn Hunter, dwollam, brEad and 5 others like this.
  29. HelminenHotrods
    HelminenHotrods
    from Finland
    The roadster was outside of the garage first time since being pushed in as an tudor.
    Good thing is it looked bad ***, and proportion looks good.
    Bad thing is i have to re-do rear c-notch etc. The stance was too much *** up. This build has chanced so much from the start as an rolling bones styled tudor, to an Helminen style roadster so more work a head. IMG_20231013_184545.jpg IMG_20231013_184638.jpg
    Heres the problem, at ride hight : IMG_20231020_221235.jpg
    And here's the solution, work in process : IMG_20231020_185432.jpg IMG_20231023_184643.jpg IMG_20231025_192944.jpg IMG_20231026_202826.jpg IMG_20231026_202759.jpg IMG_20231029_194714.jpg IMG_20231029_194530.jpg IMG_20231029_205846.jpg IMG_20231029_204615.jpg IMG_20231029_204709.jpg IMG_20231029_204653.jpg IMG_20231029_204639.jpg
  30. Okie Pete
    Okie Pete
    Beautiful solution
    HelminenHotrods, Outback and Stogy like this.
