Technical Banjo rear end rebuild
Discussion in 'Traditional Hot Rods' started by alumcantandthd, Oct 31, 2023.
  1. ANYbody within a 100 miles (couple of hours driving time) radius of north central WV, have the knowhow, tools, etc to completely rebuild a banjo rear end?
    Thanks.
  2. krylon32
    krylon32
    from Nebraska
    They're few and far between. We used to have a really good one in Kansas. When he built them they ran forever. He did one for a friend which used a Winters V8 center with the original 39/40 early Ford parts. I think he has 40K+ miles with no problems. Also the Hot Rod Works guys are hanging it up.
  3. WiredSpider
    WiredSpider
    Michael at Third Gen automotive in Tn does a good job but probably too far for you
    Desoto291Hemi likes this.
  4. JohnLewis
    JohnLewis
    Model A Parts and Service SUPPLIERS (mafca.com)
    Skim through the Model A Club of America's Parts and Suppliers List. They have a short list of shops in there that offers rebuild and restoration services. Might find one in there within your certain proximity.
  5. gimpyshotrods
    gimpyshotrods
    It looks like they found some potentially interested buyers to continue the business.
    Nailhead Jason likes this.
  6. I found out I have a early '32 rear end, if that helps narrow down a rebuilder.
  7. Tim
    Tim
    from KCMO
    Any reason you can’t do it yourself? Rebuilding a stock model A - which is basically an early 32- banjo is dang simple
    Andy likes this.
  8. Kiwi 4d
    Kiwi 4d
    Early 32 with the round TT flange rather than the later scalloped TT has the weaker model A type unsupported pinion . What power are you putting to this?
  9. Bone stock 283.
    Tim likes this.
  10. Budget36
    Budget36
    I rebuilt a ‘36 PU rearend using a Model A book a fella lent me.
    Been 20 or so years, but hardest part was getting the pinion out if I recall. I bought a small bottle Jack from Kragen (that’s how long ago it was) to push it out.
    I’d done a D44 before that and didn’t have issues with that rear, so I was “highly experienced “. ;).
    My point is if you have mechanical abilities you can do it as well and save a lot of $$.
  11. ydopen
    ydopen
    tractorguy and The Chevy Pope like this.
  12. Tim
    Tim
    from KCMO
    Was just about to post that exact same link lol
  13. ElJayM
    ElJayM
    Yes. I own a machine shop in Pittsburgh and this is no problem.
  14. Nailhead Jason
    Nailhead Jason
    @koppy is outside Norfolk VA, He can take care of it for you as well as @ClutchDumpinDan he is in Fredericksburg VA. Known both of these guys for years, and great guys that are very skilled and have tons of experience with building hotrods in their own shops.
    koppy and ClutchDumpinDan like this.
  15. Dan Hay
    Dan Hay
    I rebuilt a 40 Banjo and to my knowledge it's still going strong. It's been about 8 years and who knows how many miles. It's not hard, read a lot, and go slow. The most difficult thing for me was finding a machinist to turn down the outer wheel bearing race on the bells so new races could be pressed on. You need a big lathe to spin that axle bell. Also, the axle seal inside the bell is a booger to get on, but other than that not hard.
    warbird1 likes this.
  16. I agree, but to some who does not have the tools or who does not know the tips and shortscuts, or has rebuild one, plus failing eyesight, it can be a daunting task.
    ThosD likes this.
  17. ydopen likes this.
  18. I sent you a 'start a conversation' about arranging a procedure to get you to rebuild this rear end for me, please.
  19. koppy
    koppy
    from VA
    Happy to help if you need. Can rebuild/modify to whatever your needs. I can do in house machining for hot rod works kits as well. I'm located in Yorktown VA. 814-594-0813
    Ben Kopp
  20. Thanks. I'll keep in touch,
    koppy likes this.
