Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. My girls '60 Lark has a 259 and that thing is torquey, the a/t starts off in second and it pulls just fine. Plus it gets the best MPG out of all the running cars.
    Stogy, Six Ball and Tim like this.
  2. Tim
    Tim
    from KCMO
    @1oldtimer that’s awesome. I’ve heard of guys putting the 3 speeds in second and turning overdrive on and letting it bounce back j and forth on its own for in town.
    Stogy, 1oldtimer and Six Ball like this.
  3. Six Ball
    Six Ball
    from Nevada
    In my son's wagon 2nd over was perfect for around town. It had a 427-1 rear end.
    With the cam gear driven the cam sets lower in the block and the cylinders are a little wider. I've heard that accounts for the low end torque. I do know it makes the distributer turn the other way.
    You are right it is the T90. I'm doing that to the T86 I'm using in my roadster. Some are a closer fir than others.
    The shorter stroke would be like the difference in a 327 & 350. I always liked the short stroke small blocks better. I thong I have a pickup bell housing around too. I haven't chased Strugglebuggy parts in quite a while.
    Stogy and Tim like this.
  4. Tim
    Tim
    from KCMO
    I figured this swap still kept you interested in the drivetrain aspects haha
    Stogy and Six Ball like this.
  5. Six Ball
    Six Ball
    from Nevada
    I'm still sticking with the 153 in my roadster for now, at least till I drive it. Then there is a 283 that will almost bolt right up, a 331 Caddy, and a pile of Studebakers, and since it will have a Stude transmission already.:rolleyes:
    Tim likes this.
  6. Tim
    Tim
    from KCMO
    For now I think I’m just going to move the entire drivetrain over to the deuce rails sitting next to the A
  7. Tim
    Tim
    from KCMO
    So while I wait for it to not be 18 degrees - brr!- so I can move cars around I thought I’d add this photo. IMG_0365.jpeg while much larger than a flathead and considerably larger than a chevy I keep finding that the header solutions for flatheads look pretty close to clearing what I’ll end up with and the distributor needing about chevy clearance for the distributor. Though the stude doesn’t have the distributor in quite the same spot.
    I have to imagine the giant caves some people
    put in an A firewall are wanting quite a lot of room between the fan and the radiator. I’ve run them very tight the last few cars and while taking the water pump off and then pulling the fan off it, or removing the radiator all together then pulling the fan isn’t for everyone I’d rather do that than lose foot room in an already small car.
    brEad, drdave, Stogy and 3 others like this.
  8. 05snopro440
    05snopro440
    Yeah I think that's it. I am going to install my 283 in my 28 RPU as far forward as possible to minimize the firewall intrusion. I'm 6'2", every inch makes a big difference.
  9. Tim
    Tim
    from KCMO
    @05snopro440 I could also see an automatic transmission needing more room than the stock lower provides and guys figuring if I have to cut it I may as well cut a bunch and have more room.
    I also found in all this playing around that the lower the motor was the more room I had available.
    The cove in my lower firewall is fairly centered, possibly even goes towards the p***enger side a bit. With the distributor off set to the drivers side I think I may cut a vertical line and remove about an inch of width and scoot the cove over a bit just to make the clearance around the distributor more uniform and the shape more on purpose looking.
    hoping I can move cars around this week and then after I get the engine cleaned up I’ll tear into it.
    brEad, Stogy, Six Ball and 2 others like this.
  10. 05snopro440
    05snopro440
    Yeah for sure. I'm doing an auto but it will not have any more room than necessary. On something like an A it's almost easier to pull the engine and trans if anything major is needed. My perspective, anyways.
    Stogy, Six Ball, Thor1 and 1 other person like this.
  11. I forgot to add, the hot ticket is to get a '59/'60 distributor for it. Those were Delco units and used the Chevy points, cond, rotor and cap. It also uses the same spark plugs as a Flathead (I have some NGK ones for both cars).
    drdave, Stogy, Algoma56 and 3 others like this.
  12. Tim
    Tim
    from KCMO
    That’s a solid recommendation thanks!
  13. Tim
    Tim
    from KCMO
    Yeah it really is some times. I recall pulling a motor and swapping in the new one in a buddy’s model A and driving before we hit dinner time.
  14. Six Ball
    Six Ball
    from Nevada
    Maybe I should have posted todays finding over here so others could see and make corrections if I'm wrong.
  15. Tim
    Tim
    from KCMO
    Been nosing around seeing what’s out there for starters. I found one questionable source for a mini gear reduction starter and found a seemingly legitimate part number for the specific starter I need. IMG_0384.jpeg
    Delco 531608 and 1107115 are the two stock options for this combo. I’m ***uming conv means conventional aka manual. So the 531608 is possibly the 4 speed starter such with an 1/8 inch shim works for the 3 speed with over drive setup.
    the biggest thing I’ve had to reiterate when looking for this stuff is that the 6 volt and 12 volt starters are completely different outside of the tooth count on the drive gear and the bolt on flange.
    the 6 volt not only has a different style cover but the guts are a slightly different style and has a much larger shaft. The drive gear is physically bigger the drive gear has a roughly a .15 bigger diameter. No parts exchange between the 6 and 12 volt starters.
    The work around if you want to use a 12 volt starter - with the correct length nose cone as 3 speed, 4 speed speed and auto are all different lengths- is changing the flywheel for one off a 12 volt motor.
    56 and newer 12 volt starter = 56 and newer flywheel.
    was surprised to find they made so many different variations given the engine remained basically the same for the entire run.
    It’s as if Studebaker saw Fords endless interchangeability and standard tapers and bolt sizes and said let’s do the opposite of that. Lol
    oh well it’s a fun rabbit hole to have dove down. Gonna try to start cleaning my motor and trans up today. Fingers crossed
  16. Six Ball
    Six Ball
    from Nevada
    Interesting that the '61 V8 & 6 are the same.
    Wait till you get to the OD parts.
    Are you going to stay with 6v or run your 6v starter in 12v? The 6v solenoids for the OD are easier to come by. We'll talk about those if yours doesn't work.
    Tim likes this.
  17. Tim
    Tim
    from KCMO
    I had planed on running it 12 volt and then maybe a voltage drop to run the OD solinoid on 6.
    I’ve run a few six volt starters as is on 12 volts just fine, but I’d probably have @Austin kays Dad rebuilt the starter 100% and have him set it up for 12.
    on a stude note I’m looking at this giant oil breather stand and trying to see what all the flats and holes are for IMG_0392.jpeg IMG_0393.jpeg I’ve seen the oil filter bracket bolted to the p***enger side but I’m not sure where the hoses connect to.
    the flat spot on the drivers side the only thing I’ve seen there is a gl*** bowl fuel filter but most the time it’s empty or holding a carb return spring.
    I do see a hole routed to the hole near the bottom drivers side, mines blocked with the plug with a slotted head. I would ***ume it was a vacuum source?
    many reason I can’t make a shorter breather neck out of pipe if all I’m using it for is a breather and oil fill?
    Thor1, Stogy and Algoma56 like this.
  18. Six Ball
    Six Ball
    from Nevada
    Is that right over the fuel pump lobe on the cam? That flat looks like an uncut fuel pump mount to me. Could be driven with a rod like a flathead. Maybe for some AG or industrial application. We had one with a sheet metal timing cover. The only one I've ever seen. The engine was blue. I'll have to look and see if any of mine have that kind of breather stand.
    Thor1 and Stogy like this.
  19. Tim
    Tim
    from KCMO
    It’s like that on every picture that comes up when I Google studebaker 259. Got a line on a local stude club gonna see if I can find some local guys to trade info with.
    Stogy likes this.
  20. Tim
    Tim
    from KCMO
    Ok went snooping and found. One with a fuel pump where you mentioned and where I thought I was seeing only a filter! Could be a slick trick if you were out of room for the lower mounted pump.
    also a few photos of the filter bracket bolted to it.
    seems the oil for the filter comes out of a small port in the front of the drivers side head and in threw the top hose of the filter then out the lower.
    seems to be some debate of where it goes from there but the two routes I’m seeing are into the fuel pump boss which would line the push rod and the other is a boss in the pump stand/ breather tube which I believe to be the hole I see blocked with a slotted plug. The oil going down this tube would apparently drain down over the timing gears- no chain on these- and back into the pan. IMG_0405.jpeg IMG_0406.jpeg IMG_0407.jpeg IMG_0409.jpeg i did see one other style breather tube that was similar height but no where near as beefy looking. I’ll see if I can back track and find it
    Thor1, Stogy and Six Ball like this.
  21. Tim
    Tim
    from KCMO
    Found it. Looking at the valve covers it’s possible a later stude not sure that makes any difference
    Thor1 and Six Ball like this.
  22. Tim
    Tim
    from KCMO
    Looks like Tom and Diana Branch both run a full length stock breather but chromed and Tyler runs a shortened or fabricated one IMG_0416.jpeg IMG_0415.jpeg IMG_0414.jpeg IMG_0413.jpeg IMG_0411.jpeg
    also that’s a mopar 318 air gap intake cut and welded to some flanges on Tyler’s set up with the single 4 barrel.
    guthriesmith, Thor1 and Stogy like this.
  23. Tim
    Tim
    from KCMO
  24. Coming in late again, my girls '60 Lark has the fuel pump looking boss and the hole below it with a pipe plug. Early fuel pumps on the oil filler and a return for the oil filter on drivers side of the oil fill tube and oil filter holes on p*** side of fill tube.
    More tips as I remember them,
    **Get the stock fuel pump with the gl*** filter on the bottom, rebuild it with a Now and Then Automotive kit (ethanol resistant). The Carter replacement pumps leak oil after awhile from the arm pin and the pin comes out, thankfully the stock fuel pump bolts keep the pin from falling out.
    **If you're rebuilding the motor, have the machine shop bore out the freeze (core) plug holes out to fit in SBC cup plugs. The stock disc plugs REALLY **** if your block doesn't have 100% of the stop intact (a lot don't).
    **Make sure they clean out the block REALLY well (or you do if not rebuilding). Not sure about the older motors but around '60 era there could be some casting sand still left in the block.
    brEad, Stogy, Thor1 and 2 others like this.
  25. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Tim;
    To clean out the block, I found that using a "Driveway" tip on a pistolgrip hose end works to dislodge some stuff, also various long screwdrivers, thin prybars, coathangers & thick welding rods bent into needed shapes/angles, all used to s****e/poke/dislodge old junk, rust, past sand/core-wires. & there was a load in there. Afterwards, a good blockcleaner & flushing run thru the cooling system helped dislodge even smaller stuff, although I'd temporarily mount a coolant filter to capture stuff. Propylene glycol helps to keep coolant system scrubbed clean. I did this in near-wintertime, in the Lark - lots of "fun", not to mention messy, but never had any overheating issues afterwards.
    Glad you chose a Stude mill. & continue listening to your wife - she has good taste, & sense. :D .
    Marcus...
    Stogy, Thor1, Tim and 1 other person like this.
  26. Tim
    Tim
    from KCMO
    All good information guys! Thank you!
    im curious how much bigger the chevy cup shaped plugs are than the stock stude ones. I’m curious if there’s not a indext chart where you could find an existing one by size but given how “thrifty” I hear Studebaker guys are if there was a way to do it without machine work they’d have found it lol
    Stogy likes this.
  27. Tim
    Tim
    from KCMO
    I missed the part number but these Dorman br*** expansion plugs seem to be in favor. 1 1/2” for future reference. IMG_0419.jpeg Also a ford 289 has a very shallow 1.5” plug that I guess works on the later motors but I’m not finding a consensus on early. They do recommend red thread locker either way IMG_0418.jpeg did find this on the drivers club so thought I’d leave the address showing in case someone wants to follow bread crumbs
    redzula, Stogy, Thor1 and 1 other person like this.
  28. Tim
    Tim
    from KCMO
    Love it when buddy’s come through! I’ve been trying to find a match, or current code for, 1930 ford duchess blue for the entire length of this monster thread. Well Ethan came threw with a dead on match! 4ADD2784-8268-4AD4-A6B9-B443D0F5C7D5.jpeg 31E6C7EF-05BA-4D47-BCA7-1ED27ACAAA7B.jpeg D148A33D-A9E2-4073-BA93-FD7D00AD44F9.jpeg 4E4C1D9B-210E-475B-88E8-2E3B226FB571.jpeg this is all the same card in different light. Super stoked!
    brEad, n847, drdave and 4 others like this.
  29. Those last two rods up above are Diana (Tudor) and Tom (Gold roadster) Branch's cars
  30. Tim
    Tim
    from KCMO
    Yup, I mentioned that I believe. I actually took the photos of Toms car a couple weeks ago.
    While your here Trent you know of anymore stude powered hotrods? I’ve found a few mocked up but outside of Dean Moons 34 and the Branches cars nothing driving to be found.
    Six Ball likes this.
