Technical ***November 2023 Banger Meet Thread - Shopping Season***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 1, 2023.
  1. Jiminy
    Jiminy
    Link to previous month: October 2023 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. pkhammer
    pkhammer
    So, I need you guys opinion. I know that is opening up a big 'ol can of worms but here goes anyway! I have an opportunity to buy a '29 Speedster from an estate. It was built from a Rootlieb kit which costs more than what I can buy the completed speedster for. It hasn't been run for a year a two so it will need a little tinkering to have up and running. I think the car looks goofy with the fenders and bumpers and radial tires so all of that would go away. Tires and wheels would be replaced with stock Model A wires and bias rubber. Add a few decals here and there and maybe some hop-up parts to the engine.
    In the end, can it be made into something cool or will it look goofy no matter what?
    Dannerr and Outback like this.
  3. Rex_A_Lott
    Rex_A_Lott
    I like it. I think just changing over to some big and little tires would do a lot for the looks of that one. I've always ran the 16" wheels, you have a lot more tire options. If you switch to A model wheels you're pretty limited. Good luck.
    Old Dawg and pkhammer like this.
  4. Dan from Oakland
    Dan from Oakland
    Buy it and have fun!!!
    Dannerr, Old Dawg and pkhammer like this.
  5. denis4x4
    denis4x4
    from Colorado
    Looks like those are T fenders and 16" wires. I built a Rootlieb kit and I used a one piece hood top with leather hold down straps. Lots of fun. Buy it.
    pkhammer likes this.
  6. pkhammer
    pkhammer
    Yes, I agree that the one piece hood top with open sides would be better. I could also fabricate a side exit exhaust to run up the p***enger side for a racy look. If I buy it I could sell the fenders, splash aprons, bumpers, headlight bar, headlight visors, radiator stone screen, hood and possibly the wheels and tires. I notice one of the wheels is a K-H bent spoke type but the other three are regular '35 Ford 16" wires. A set of bias ply 7:00-16 rear and 6:00-16 front might give it a better look. I have a set of original 16" wires laying around.
    I found an issue with the ***le, the serial number is 1 digit different than the engine number. I figure a DMV mistake that didn't get caught. The estate said they'd get the DMV to fix it.
    I think I can buy it for around $5k.
    Jiminy and Outback like this.
  7. Present
    Outback likes this.
  8. 282doorUK
    282doorUK
    Yep do all that de-goofing but go for the tallest skinniest wheels and tires you can find, if they make it look too tall maybe drop it down a few inches. Maybe loose the windscreen too, then it would have a proper vintage look to it.
    Just my thoughts, buy it and you can't go far wrong whatever you do, have fun.
  9. 2023RMMR.Kris.jpg My plate isn't full: but I'm face down in it with nowhere to race!
  10. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    From what I understand, the main factor limiting performance on the Ford banger exhaust system is the stock muffler.
    If I'm not doing Bonneville or anything like that, is there any practical difference in driving experience between something like the totally open Geardrive lakes header, factory manifold w/ better muffler, factory manifold w/straight pipes, etc...
    Outback and 282doorUK like this.
  11. Stovebolt
    Stovebolt
  12. Outback
    Outback
    from NE Vic, Oz
    Love your race car!
    I'm here, nothing to report, but I did park my A at the bottom of the back steps so I could look at it from inside the house, it took my wife 4 or 5 days to mention it! Haha IMG_20231014_095129086_HDR.jpg
  13. hotrodA
    hotrodA
    Yep, lose the fenders, boards and bumpers first. They make it look out of proportion and an afterthought. Than the tires. Then lower the headlights and ditch their visors.
    Any speed parts?
  14. pkhammer
    pkhammer
    Appears to be a stock banger so a head, downdraft carb and header might need to be added. A fully synchro trans/overdrive would also be on my wish list.
  15. ZerroHalfcup
    ZerroHalfcup
    I don't have a ton of experience but I cut the muffler off mine and ran a torque tube back to in front of the rear axle. Everything else is stock. I'm sure a downdraft intake would make a difference paired with it, but I can't tell a real difference with just how I did mine, other than it just sounds a bit cooler.
    Only my experience but I hope it helps
  16. wheeldog57
    wheeldog57
    Question for the banger guys and I'm sure it has been covered already. I have a stock model A engine and I want more HP. Everything I read says buy a head. Can you mill a stock head and get more oomph? If so, how much do you remove? If not, why?
    Thanks for any information, Ron
    Outback likes this.
  17. Dan from Oakland
    Dan from Oakland
    If you want to go the easy way with a new exhaust / intake, these guys make pretty ok stuff and the prices are very reasonable in my opinion.
    http://lakeheaders.com/model_A_Banger_intake.html
    to wheeldog57- don't bother trying to mill a stock head to get more compression, as the results are not very productive given the amount of material that needs to be removed.
    Look into buying a head from Jim Brierley or Dan Price. Jim's head is a new design, and Dan's is the Thomas Head.
    wheeldog57 likes this.
  18. railcarmover
    railcarmover
    top is a Winfield red head,7.5 to 1 compression
    bottom is a stock A, 4.2 to 1
    you can see by the combustion chamber design the stock head can’t be effectively milled
    G Baese likes this.
  19. railcarmover
    railcarmover
    Street driven hopped up flatheads don’t spin fast enough to gain benefit from exhaust extraction..in other words it doesn’t really help it breathe better, even with a header.. reduction in back pressure over stock? Yep, that helps as far as I know.
    the stock A exhaust manifold is one area that was improved by Harold Hicks in engine development, he was brought over from the Tri motor plane project when engineering couldn’t develop more than 22 horse with their design. It’s a sound design and works well.. it also offers heat transfer which helps in anti icing and vaporization of fuel for driveability.
    Most aftermarket exhaust stuff is for looks and sound..’shiny and loud’ is important to me and a header looks cool.. but it doesn’t do much. But I’m not as skilled in speed as others here, so take my **** with a grain of salt..
    Tumblin' Dice, Outback and G Baese like this.
  20. alchemy
    alchemy
    Anyone ever milled a stock head, then recut the small piston relief back in? Or has anyone ever filled some of the pocket with br*** like they used to do before it was common to buy a new head for higher compression?
  21. Outback
    Outback
    from NE Vic, Oz
    This is a great question!
    I happen to have a head that's been sliced in half to give a top & bottom. I should be able to measure the thickness of the top of the combustion chamber. Might take a few days.
    alchemy likes this.
  22. railcarmover
    railcarmover
    Reckon plug reach and position would be an issue. Balance the chambers by cc’ing the chamber, basically fill it with water and count the cc’s it takes to fill it. And braze away..
  23. IMHO
    The stk head is not worth working on
    If you machine too much off the deck it will not have enough material to adequately seal on the gasket.
    Yes you could braze up the chambers following some proven designs or just locate an aftermarket one
    considering that these improved heads have been made since the 1930’s they are out there, just have to look
    John
    Outback likes this.
  24. I'd consider a Burtz head over messing with an original.
  25. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Stay around 6-1 ratio with a stock bottom end to keep things happy. Upgraded head, Downdraft intake and Mallory distributor is my go to for hop up on bangers without internal work. This really wakes them up.
    I agree, headers don't make a hill of beans for these gals. Best bang for the buck on looks is the Yapp split Y.
  26. Dan from Oakland
    Dan from Oakland
    By the time you buy the brazing rod and the gas to keep that ****er hot enough to fill in a head and then resurfacing it when it warps all to heck and back, you will be half way to buying a high compression head.
    Of course the entertainment value of doing it yourself is priceless.........
    CSPIDY, johnneilson and Outback like this.
  27. Outback
    Outback
    from NE Vic, Oz
    For those of you who build strong street motors, keeping the babbit what are/is your go-to hi-comp head? & Why?I'm sure this has been discussed before? Somewhere...
  28. That's the first thing to go!
    Outback likes this.
  29. Outback
    Outback
    from NE Vic, Oz
  30. First to go is Babbitt
    As for head original iron Winfield
    Aluminum Brierley or iron Lion
    If you can find a Brumfield grab it
    J
    Outback and Stovebolt like this.
