Always check bolt lengths! STUPID MISTAKE
Discussion in 'The Hokey Ass Message Board' started by mikhett, Sep 30, 2006.
  1. mikhett
    mikhett
    from jackson nj
    OK im rebuilding my 62 ford 390 fe engine. Just gotta install intake & rockers and damper.I order ss hex head bolts from BOLT LOCKER on E-Pay.I go to install them w/o measuring them.They look a lil short but i figger he couldnt send the wrong size! WRONG.When torqueing down the bolts two bolt hole threads "pull up"& have to be heli-coiled! .I go out back and pull the intake bolts off a 352 i had an sure enough there 1/4 " longer w/o washers.I used washers with the new wrong size ss bolts.I call the guy back after VENTING and he says "NO PROBLEM ILL SEND YOU 2-3/4 bolts there two sizes 2-1/2 & 2-3/4"!He didnt say that when i ordered them.They say you learn from your mistakes. Well this has been a learning process. MIKE
  2. TagMan
    TagMan
    It's a lesson we've all had to learn at one time or another.......measure twice, cut once !!
  3. angryj976
    angryj976
    from alameda
    been there, done that. it ****s ***!
  4. KY Boy
    KY Boy
    Ahhhh. Arent FE's fun? You did get the rocker shaft bolts in the correct locations didn't you? If not, no oil to the top end.
