Most of these gauges will have some dings in the bezels Oil Pressure all 2 1/16" N.O.S. 200 psi. brass back date code H6 1964 June 15.00 Black Tail 100 psi the black tails are made around the 1990’s on 15.00 Coffin pointer 80 psi I can only see the date in the code K = 1966 15.00 Sweep needle 100 psi date code W11 1977 Nov. 15.00 Ampers all 2 1/6” N.O.S. in the box 30 amp. black tail 20.00 Sweep pointer brass back 60 amp. date code R2 1972 Feb. 20.00 Coffin pointer 60 amp. Flat glass, large logo ran from 57 to 60 or 61 25.00 SW 2” 60 amp flat bezel 25.00 Water Temp 2 1/6" Black tail 240 degree electric water temp 20.00 N.O.S. Transmission Pressure Gauge 15.00 2 5/8” gauges Oil Temp 325 degree with 60” cap tube date code Q7 1971 July 35.00 Sun Tach model IT-466 12 volt 8 cylinder with the transmitter i can not guarantee the condition of the transmitter 50.00 Temp Sending unit and switch 362B sending unit 100 to 240 degree 15.00 N.O.S. 334AD sending unit 100 to 280 degree 20.00 N.O.S. Temperature switch 20.00 Oil sending unit p/n 353-z 12volt 80 psi if the date codes are the same as the gauges it is E-8 1961 Aug. 15.00 3 pole brass ignition switch 20.00 9 gauges for 1 price all of unknown condition 35.00 1 30 amp gauge 2 Champ lighted fuel gauge 3 20 amp. Rear mount looks to be SW 4 APCO 30 Oil has same can and bezel as the 60 amp SW 5 SW 2 1/16 80 psi oil rear mount 6 Rochester Mfg. 20 Amperes 7 Model T or A Ford 20 amp gauge 8 Suntune Fuel level 37 Vintage dash or gauge lights $3.00 ea. or 60.00 for all Switches// 7 on off, 3- 3 pole 3 position, 5- 6 pole 3 position, 2 pole ignition switch and 1 horn or ignition start button 50.00 for all Hurst Indy gear shift handle 15 ½” long will need thread work 20.00 BUYER TO PAY SHIPPING I NO LONGER SHIP INTERNATIONAL //MONEY ORDER ONLY // NO PAYPAL
