History Racing a historic flathead dragster
Discussion in 'Traditional Hot Rods' started by ukgav, Jan 17, 2023.
  1. ukgav
    ukgav
    This was pretty cool.
    Dean, the owner, sent over these pages from the August 1973 copy of rod and custom magazine that featured coverage from that years antique nationals.
    That year saw Charlie trailer the dragster from Cincinnati to California to compete. A journey that took him 3 days and which bagged him a $25 prize for the ‘longest tow’.
    Whilst there he also set low et of the meet with a 10.65 which should have seen him take home a further $100 except there was a rule that this needed to be set before 12 noon.
    Unfortunately he also went out out in round 2 with a slow reaction time.
    Pretty incredible that he was lifting the wheels and running those times with all early Ford running gear. Most of the other flathead dragsters were already fitted with more modern trans and rear ends.
    The car ran a bigger motor than it does now at 306ci. Exact details are a little sketchy but Dean believes it ran 450 thou lift on radiused lifters and a ‘special’ Isky ground cam.
    Apparently he also preferred to run 21A rods, fairly low compression at around 8 to 1 and swore by 48 carbs.
    Whatever his speed secrets were yet certainly worked.
  2. ukgav
    ukgav
    So here is an update on the Charlie Bang Special
    Dean, the owner, is getting a kick out of us racing the car and people having a chance to see it so agreed to us having another year of fun!
    To this end, earlier this year, I went over and pulled the trans to confirm if the clutch was the culprit of our slower e.t's
    Not every day that you get to wrench on an original 60's digger sat next to a 50's Indy car!
    Safe to say the clutch had seen better days!
    The car uses a stock 10 inch flatty clutch so a new kit was ordered from Rock Auto and I had the flywheel skimmed.
    While I was at it I deleted the radiator and fitted a smaller battery in order to lose the unsightly box up front. We also picked up a pair of Hurst recap slicks as the whitewalls we were running were rock hard. These were a smaller diameter so time would tell if they would help or hinder.
    With the car back together we entered the Dragstalgia event in July and had decided to up our game so had T shirts designed and printed. These have proved very popular.
    The car went well although now running a clutch that had some bite getting it off the line took some getting used to but we were excited to see a little air under the front wheels on launch. As suspected the smaller slicks resulted in sacrificing some top end speed but it was made up with quicker 60 foot times. Best e.t was an 11.8 by Pete so comparable with our previous best.
    We also had Pete's killer sport coupe as tow car which resulted in us winning best appearing car of the event. Damon had now caught the racing bug and has plans to build a car along with Pete. Race transport was now handled by the box van he had bought.
    With the car in one piece after the event thoughts turned to the next one which would be the Hot Rod Drags again in September. The only work carried out prior was to replace the HT leads as they were pretty old and brittle.
    I also put together an info board detailing the car's spec and history as people are often intrigued by it.
    Pete had also decided that tow cars aren't cool enough and wanted to push the car instead. He knocked up a push bar and fitted a board to the front of his model T modified which just so happens to run a blown, overhead converted, dry sumped etc etc 4 banger! Needless to say the combo drew plenty of attention over the weekend!
    14cdaaa0-0b44-471e-8361-abfefa13a29b.JPG 06872cb5-85a0-4865-ace2-5a1f3256cc6f.JPG
    We had a busy weekend as not only were we competing in our usual Wild Bunch cl*** which runs a dial in format but we also decided Damon should get some seat time and race in the resurrected Flathead Meltdown.
    The car ran well again with me and Pete both running 11.8's and Damon, getting used to the car, eventually ran a 12.8.
    Unfortunately half way through Sunday the clutch once again threw in the towel and started slipping BAD. Damon managed to nurse it through to the win in the meltdown final slowing to a 14.9 but we had to retire the car from further compe***ion.
    All in a great weekend though as we collected our trophy for best appearing from the previous event, won the Meltdown compe***ion cl*** and also set fastest flathead e.t of the event.
    Plans now are to look at a better alternative to stock Ford clutch parts and fit these over winter and have some more fun next year.
    The subject of methanol has been discussed!
    Baumi, Toms Dogs, Speccie and 12 others like this.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Now this is about as cool and as much fun as you can get. I want to play in your sandbox!
    Thanks for sharing. That engine wound up sounds amazing.
    Tow Truck Tom likes this.
  4. CSPIDY
    CSPIDY
    Gi-ddy-up
  5. wheeltramp brian
    wheeltramp brian
    For a clutch recommendation. I went through A couple of store stock clutches in a couple cars that just seemed to be junk or chattered. Ended up getting one from fort wayne clutch And it's awesome.
  6. RodStRace
    RodStRace
    Tow Truck Tom and Toms Dogs like this.
  7. roseville carl
    roseville carl
    Absolutely love this thread. See isn't this better than cackle cars, and just think of all the memories you guys are getting!! Wish you guys can make it over the pond to Eagle Field the Flathead V8/6 Cylinder Clash is a great fit for you!!! Course I'd love to get over there and run with ya but that probably won't happen anyway "Keep em between the Whites" and enjoy.
    Oh and I'm going to steal some pics ok......
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Amen
  9. 29Sleeper
    29Sleeper
    from SoCal
  10. ukgav
    ukgav
    Feel free to use any pictures you like.
    It would be great to play with some other flathead dragsters. At the moment there are just 2 actually racing in the UK and that other one hasn't run this year. There are another 2 or 3 in the works though so next year may see a slightly increased field.
    What sort of E.T.'s are you guys running over there?
  11. ukgav
    ukgav
    Thanks. Fingers crossed we have cured the caliper issue as they have been fine this year.
    We would love to attend the Antique Nationals but the cost of shipping the car to the US would be very prohibitive.
  12. patsurf
    patsurf
    do it like burt did...
  13. RodStRace
    RodStRace
    Amazing how Irwindale is still going. I was crewing for a nostalgia SS car years back and it was "this is the last year" every year. I hope it can continue, always had a great time there.
  14. roseville carl
    roseville carl
    Mostly 1/8 mile at Eagle Field around 7 flat at 96 mph, and 1/4 mile times 11.3 at 117
  15. 29Sleeper
    29Sleeper
    from SoCal
    The shopping center deal fell through. I heard they are bleeding money with only their Thursday race nights @ $40 a car isn't covering their costs. Once it closes they'll have to start running Pomona to keep the street races down. The noise restrictions at Pomona are the main reason it's not used more often.
  16. ukgav
    ukgav
    Not bad going for an old Flatty.
  17. roseville carl
    roseville carl
    For a home built It suits me fine and I don't break too much on it between runs. Have fun and stay Flat!!!!
  18. ukgav
    ukgav
    With race season just around the corner it was time to, once again, remove the clutch from the Bang dragster and ***ess the damage. Well, if the last one wasn't worn enough we certainly made sure this time!
    Not wanting to repeat this process every 15 or so runs we decided an upgrade was needed. Pete resurfaced the flywheel and also machined it for a steel insert. Meanwhile the pressure and friction plates were sent to Orca Clutch in Hants who couldn't have been more helpful. What they returned was a 6 pad sintered friction plate using the flathead centre and a refurbished pressure plate. Interestingly Wayne at Orca was surprised that Charlie had obviously built it with 3 different springs pressure's so that it has a bit of a 'progressive' nature to it. Another one a Charlie's secrets revealed it seems.
    A couple of weeks back I went over and refitted everything, while doing so and out of curiosity, I pulled the intake off the as we hadn't looked inside the motor before.
    Bare in mind that when Dean commissioned Charlie to rebuild the car there was no real intention at the time of it ever racing again and that the flatty needn't be anything special but it seems Charlie couldn't resist a bit of porting while it was going together.
    So it's all back together and we will wait and see how the clutch performs in a couple of weeks.
    loudbang, Toms Dogs, Petejoe and 5 others like this.
  19. ukgav
    ukgav
    Back together and a quick test hit on the street confirmed everything seems to be working.
    ottersea, Baumi, loudbang and 5 others like this.
  20. RodStRace
    RodStRace
    Ahh! the ol' test the race car on the street! Love it, brings back memories of similar hi-jinks!
    With the harsh nature of road law over there, it's good to see a bit of the hooligan still exists and it looks like no harm was done.
    Baumi likes this.
  21. ukgav
    ukgav
    Only to my head as it hit the cage when I drove over the bump in the road!:D
    ottersea, loudbang and RodStRace like this.
  22. Cool ****! Love those built flatties!
  23. ukgav
    ukgav
    Back from another successful weekend of racing with the Charles Bang Special.
    With me and Pete racing the car in the Wild Bunch cl*** and Damon in the hot seat for the Flathead Metldown compe***ion it was once again a case of hot lapping the car to make sure we got to run with each group.
    Friday was a RWYB/test kind of day and after the first run we found the new clutch was biting well but the old Hurst recaps not so much so I went to a local tyre shop and had the pair of Hoosiers Damon had brought fitted to the mag wheels. Pete had the first run straight after and the results were dramatic! The car pulled a huge wheelstand with Pete keeping his foot in to run a 11.8.
    The rest of the weekend was a case of experimenting with launch RPM to try not to repeat that amount air under the front end but to carry the wheels for a bit and maintain momentum.
    By the end of the event Damon had put a new PB on the car, for us, of 11.666 seconds at 116mph. We also won trophies for the meltdown compe***ion cl*** and fastest flathead of the event.
    Next run out will be Dragstalgia in late June where we hope to keep chipping away at the times and try to match what Charlie ran in 2004. We may also have the car on methanol by then.
    JamieUC, lurker mick, Oneball and 3 others like this.
  24. ukgav
    ukgav
    Another cool picture and a couple of video clips.
  25. nutrocker
    nutrocker
    Love the 2nd to 3rd gear change wheel lift mid track.
  26. ukgav
    ukgav
    Next up was Dragstalgia at the end of June where we once again joined the rest of the wild bunch at, what is now, the biggest 'traditional' style drag event of the year.
    The newly christened 'Proper Charlie's' drag team turned up with not only the Charlie Bang Special but also Pete and Damon's new car. With the blown banger and running gear from Pete's T, added to a bunch of parts Damon has been collecting, a six week thrash saw 'The Charlie Bang'er' early rail job debut.
    The plan was just to run it in RWYB on the Friday but the chief starter had other ideas due to the lack of roll over protection. The plan all along is to fit a roll hoop on the car but the first iteration didn't meet expectations in term of style and was duly cut off with time running out to fabricate another. So, somewhat disappointing but not totally unexpected, it meant the car was now put into action as tow vehicle.
    Friday and Saturday saw extremely hot temperatures and a heavy head wind which meant performance was down with the car posting times in the low 12's. With the weather looking a little more favourable for the Sunday we decided to post our dial in time somewhere in the middle of where we usually run and where we were running. 11.99 seconds.
    Amazingly the gamble worked and over the three runs that count we somehow managed to bag third place in wild bunch compe***ion. Not only that but an earlier run had seen Pete reaching for the sky again which also meant he won the showmanship award from the wild bunch and best wheelstand of the event from the organisers!
    The real highlight though was having flathead racing legend Ken Cooper back at the track, after a couple of years away, with son Bradley racing their 'Back to the past' dragster. It was great to have the two cars lined up and we matched raced 5 times over the weekend with the Coopers breaking back into the 10's again on one run.
    Hot on the heels of Dragstalgia came MPH vintage drags. A complete departure from Santa Pod, this was an 1/8 mile flag start race on an old, some what bumpy, unprepped ww2 airfield.
    Not strictly open to compe***ion cars, we contacted the organisers a few weeks earlier who pitched the idea of us running both rails as an exhibition element of the event before and after the main hot rod grudge racing. Happy to get some runs in, especially on the blown banger, we jumped at the chance.
    So while I ran the Bang car and Damon got to grips with the rail job, Pete took his A sport coupe along to embarr*** some overhead valve motors!
    So Saturday morning saw both cars start the event off with a couple of side by side runs to warm up the crowd. Surprisingly the Hoosiers hooked up pretty well on the bare surface and the car seemed pretty settled over the bumps. the banger too sounded happier on some new plugs and ran well.
    In the afternoon we just had to line up with our friends in their 'Chinese Bandit' flathead altered, a car first built in 59. Charles' car is mere pup having been built in 63!
    The guys have put a lot of work into getting the bandit running well but it wasn't quite enough as I lifted the wheels out of the hole and took the win. The race made for some great pictures and video.
    Pete meanwhile had made it to the top 8 compe***ors of the day, the only flathead to do so, who then went head to head to find a winner. Unfortunately he pulled the eventual victor early on and was knocked out.
    Sunday arrived and so did the rain. We thought the event would be called but the organisers were happy for racing to continue in singles on the now damp track, even the rails!
    Flathead dragster, on slicks, in the wet? What could go wrong? We put two more, somewhat, exciting runs on the car in the unfavourable conditions before deciding discretion was the better part of valour and packing away. One of the trackside photographers showed us one of his shots that showed the car still lifted the wheels on the 1/2 shift in the wet!
    In all a great event and one we hope to attend again.
  27. nutrocker
    nutrocker
    Nice words Gav. Great times.
  28. Baumi
    Baumi
    That car deserves to be out and racing! Well done!
  29. Oneball
    Oneball
    Great write up, the wet pic is fab. When you out next @ukgav ?
  30. roseville carl
    roseville carl
    Absolutely LOVE IT!!!
