Technical Best electric window kit - 1955 second series chevy truck
Discussion in 'The Hokey Ass Message Board' started by Jasper234, Nov 5, 2023.
  1. Jasper234
    Jasper234
    Hi
    Has anyone had any success with a good quality electric window conversion kit with regulators for a 1955 chevy second series truck?
    I need new regulators and power units would be handy
    Thanks
  2. Last edited: Nov 5, 2023
  3. krylon32
    krylon32
    from Nebraska
    Another vote for Nu-Relics. I wonder if they're still in business? I checked their site and everything is out of stock. I used to see them at the NSRA nats at Louisville but don't remember seeing them this year?
  4. Put me down for Nu-relics. Way better than the others.
  5. Jasper234
    Jasper234
    H&H cl***ics are listing them for the truck with the fancy switches that use the stock internal window handle. I looked at Nu Relics website, and they show no stock. H&H are $656. Think I’ll contact Nu Relics and see whether they reply. Never heard of H&H!
    Thanks for the guidance guys!
  6. pprather
    pprather
  7. Bob Lowry
    Bob Lowry
  8. Jasper234
    Jasper234
  9. Budget36
    Budget36
    That looks and reads like the same kit link posted earlier ?
    edit: I see they add a set of crank switches. Kinda misleading in the first link posted but see it uses a more modern style switch set.
  10. Budget36
    Budget36
    I kinda like the first one better, with the dual switch setup you can roll the p***enger side up/down from the drivers seat.
    Now where to hide the switches at?
    X-cpe likes this.
  11. fabricator john
    fabricator john
    from venice fl.
    got to remember that the switches that use the stock handle while slick and nice are only for one door you have to reach across to roll down the p***enger window ,, however you can remedy this by double wiring the motor on p*** door and using a 6 pole center sprung toggle under the dash to keep the switch hidden just have to remember not to work both simultaneously it will pop a fuse as both switches are current reversing i fuse them individually so one or the other and your not stuck in the rain . its not likley but it could happen ,,
    fabricator john
    miss you dad
