Technical 40 rad hoses with SBC
Discussion in 'The Hokey Ass Message Board' started by olskool34, Nov 4, 2023.
  1. PONTNAK123
    PONTNAK123
    i.rant likes this.
  2. PONTNAK123
    PONTNAK123
    these hoses make installation a breeze
  3. olskool34
    olskool34
    Yes if my sway bar was not in the way unless this hose tucks up fast in front of the sway bar.
  4. olskool34
    olskool34
    Found this pic on the web. Looks just like the issue I have. Looks like he notched the front crossmember. IMG_7896.jpeg
  5. olskool34
    olskool34
    This is what I ended up doing in case anybody is interested. Pulled out the V fender brace and put a curve it it to miss the hose. Cut a small arc out of the front crossmember to allow clearance as well. Grabbed some hose pieces I had laying around and taped up a mock-up hose. A Gates 20345 matched the mock up and it is in. Everything has plenty of clearance, nothing touches. I did not want to raise the radiator as it has brackets on the side that a factory brace connects to that runs to the V brace. IMG_8011.jpeg IMG_8013.jpeg IMG_8014.jpeg
    teach'm, hotrodA and Crusty Chevy like this.
  6. I started to respond to this then thought, "but why?"
  7. Mr poopy pants
    Mr poopy pants
    IMG_1898.jpeg IMG_1898.jpeg IMG_0802.jpeg IMG_0801.jpeg IMG_2946.jpeg IMG_1898.jpeg IMG_1898.jpeg IMG_0802.jpeg IMG_0801.jpeg IMG_2946.jpeg
  8. Do the same thing you did on top. 2 short sections of rubber connecting hose and a tube built to do the job. You can always make an oval section in tight spaces without flow compromise.
  9. Buckster
    Buckster
    I have a 1940 Ford with a Chevy engine. It has a Walker radiator with a 90 degree lower connection which is fabricated so it leans back towards the engine. What hose will fir that application?
