Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. I think the wheelie bars are still too low. It didn't feel like it pulled the wheels at all.
    398490362_348168464236176_8325459078313140694_n.jpg 398576288_348168264236196_469149794539272430_n.jpg 398721085_348167864236236_5655177300125432200_n.jpg
  2. jim snow
    jim snow
    Welcome back. Snowman ⛄️
    Dog_Patch likes this.
  3. enloe
    enloe
    from east , tn.
    The only time I got to ride in a hemi was in this little coupe.
    Dog_Patch, catdad49 and saltflats like this.
  4. Welcome back. Great too see your back racing with Quick and Dirty. The ramp truck rules with the new paint.
    chryslerfan55, Dog_Patch and catdad49 like this.
  5. Haha I still remember that!
    Thanks a lot man!
    enloe, 427 sleeper and chryslerfan55 like this.
  6. saltflats
    saltflats
    from Missouri
    Good to have you throw us a bone again, and thank the Lord it wasn't a turkey bone. :D
    Dog_Patch, loudbang, enloe and 2 others like this.
  7. enloe
    enloe
    from east , tn.
    I looked for you today in Ringgold at the races
    JalopyJimbo likes this.
  8. I had an issue at the November finals where the fuel pump over ran the floats and hydraulic-ed the engine. Broke 2 rocker arms so by Ringold the new rockers were still not here. We made it to Shadyside and Knoxville. Planning to go to Mooresville next, then Knoxville again.
    Oneball, catdad49, rottenpop and 10 others like this.
  9. AmishMike
    AmishMike
    Glad to see u back. Gasser first connected me to southeast gassers lov em. Surprised hydraulic motor broke rocker arms, usually bends rods. I am sure u checked everything else
  10. Yeah there was a bunch of stuff that needed attention. I ended up putting in a new set of Molnar rods and getting the crank turned. @402BOSSMAN went through the heads because one seat was sinking. Too many 9000+ rpm excursions and the bearings were wasted - it was probably 1 or 2 passes from kicking a rod out. This season the rev limiter is on 8000 and staying there.
    The fuel problem was my fault. I never ran carbs before so I had the fuel pump on its own switch and I left it on in the pits. I thought the starter had stuck and kept trying to crank it over. I'm thinking it was pushing against liquid and finally broke something. The push rods are like telephone poles so they weren't bending.
    lumpy 63, catdad49, slayer and 5 others like this.
  11. 427 sleeper
    427 sleeper
    What made you switch over to carbs?
  12. AmishMike
    AmishMike
    Understand, cylinder full tried to start valves tried to open, snap. Now that makes sense. Tks, love your gasser. Due to you try to follow SWGassers
  13. I just got tired of always messing with the injection. It would change the idle RPM as the engine heated up. So after a burnout it would be at 4000 and wouldn't come back down. It would overheat from the high idle. The pumps would slowly get weaker through the season so keeping track of what pill to run was difficult. With the carbs you just hit the start and off it goes. I will say that it ran with way more power on injection but A/G is running 5.20's now and I'm not keeping up so I went to carbs to take some of the trouble out of racing the thing.
  14. It lost almost 1/2 second compared to the injection. Jimmy loaned me some better carbs to try out. Haven't tried them yet though. Race carbs can get pricy!
    loudbang, SilverJimmy and 427 sleeper like this.
  15. And early Hemi speed parts are cheap ? :D
    Dog_Patch and 427 sleeper like this.
  16. Haha I figure they're still making carbs and not making hemi speed parts so carbs should be belly button cheap?!
    milwscruffy and 427 sleeper like this.
  17. Roothawg
    Roothawg
    That sounds like the butterflies were sticking, possibly too large for the bore. Never heard of that being an issue. Also, the pumps should last longer than a season. Strange indeed.
  18. saltflats
    saltflats
    from Missouri
    He does have to run gas not alcohol.
  19. Roothawg
    Roothawg
    Yeah, I figured that. We do also. We converted to alcohol one season, but I kept falling down in the staging lanes. They asked me to leave.
    Edit###Well, we used to. I haven't done dick in the last 8 years.
    saltflats likes this.
