Technical Correct hose clamp
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, Nov 9, 2023.
  1. Timothy Murphy
    Timothy Murphy
    I’m building a ‘32 Ford roadster per the early 1960’s look. I have a 283 with tri-power connected to a Muncie. what would be the correct hose clamp style for that era? Thank you.
  2. squirrel
    perhaps the Wittek Sure-***e?
    There were several other brands as well.
  3. nochop
    nochop
    from norcal
    Okie Pete and williebill like this.
  4. alanp561
    alanp561
    [​IMG][​IMG][​IMG]
    And, don't forget these
  5. squirrel
    Tower clamps ****, they always ****ed, didn't guys start using worm clamps as soon as they could? :)
  6. Years ago I worked at an American Motors dealership. They (a**** others) used so many of those damn clamps I bought the tool to cut them off so I wouldn't have to try and undo them. I don't use the tool very often anymore but for awhile it was one of the busiest tools I owned. :)
    chicken, vtx1800, VANDENPLAS and 4 others like this.
  7. solidaxle
    solidaxle
    from Upstate,NY
    Speaking in terms of Corvettes of that era.
    Upper and lower rad hoses were secured with tower clamps.
    If you want to get crazy, Wittek tower clamps were dated by quarter and year.
    Example 3/63 = 3rd quarter of 1963.
    Heater hoses were Corbin or screw type.
    Screw type clamps were used to secure the hose to the fitting on the water pump and intake manifold.
  8. saltracer219
    saltracer219
    Said no Hot Rodder....ever!
  9. harpo1313
    harpo1313
    from wareham,ma
    Tower clamps= always on the hunt for blood.
  10. Mr48chev
    Screenshot (309).png Ideal hose clamp display.jpg The same Ideal stainless Stainless made in the USA hose clamps that you can still buy today. Usually off one of these display racks that sat on the counter or hung behind it.
    I'd sometimes reuse those spring clamps on Mopars because I had (still have it) the plyers to work with them. Those Tower clamps were just as big of a pain in the *** then as they are now and I usually cut them off. Unless you are **** about a restoration it is either Ideal or the Sure ***e that Jim showed.
  11. Oneball
    Oneball
    The wire types or the stupid tower things were out of date before WW2. It’s a hot rod, a clamp that does up properly will make it faster, you might as well use one.
  12. nochop
    nochop
    from norcal
    He asked for “correct “ clamps…..not good correct clamps lol
  13. squirrel
    The old clamps don't have the hex, they have a sleeve around the slot head.
    here are a few different brands I've collected lately...
    In no particular order...
    Gates
    IDEAL CORP HY GEAR B'KLYN, NY
    WITTEK MFG. CO CHI. U.S.A.
    MURRAY CORP GOLD SEAL TOWSON 4 MD
    Aero Seal BREEZE CORPS INC NEWARK N.J. U.S.A.
    and one generic, no name on it
    Note that the addresses do not include zip codes, which came along in 1964.
    (correct for a period hot rod, not for a restoration).
  14. squirrel
    and lest you think anyone takes the subject too seriously, consider a patent....
  15. KenC
    KenC
    I hated dealing with the wire spring type but they were OEM in the 50s/60s. And they were the original constant tension design. But, you have a narrow range of sizes to choose from.
    But they do look 'period correct' to my eyes, and I still have the pliers.
    alanp561 likes this.
  16. squirrel
    Truckdoctor Andy and alanp561 like this.
  17. woodiewagon46
    woodiewagon46
    from New York
  18. Squirrel set off my interest on these a few years ago from a post..........I found 3 or 4 different sizes still in the boxes. Now I have a few clamps........:D
  19. SuperKONR
    SuperKONR
    from Earth
    I like the tower clamps, back the screw off and tap it down and they loosen right up. Even 30 year old ones at the junkyard come right off in my experience. The worm screw type ones look like **** with the tail portion sticking out and will sometimes strip out before they are tight enough. For 60s stuff I like the wire type with the screw and nut.
    I had a chart somewhere with all the different types and their actual names...
  20. Jack E/NJ
    Jack E/NJ
    from NJ
    My 40-50s hose clamp stock.
  21. There is one answer if you are doing a numbers-matching restoration.
    There are a lot of answers if you're doing a "snapshot in time", old style, build because they used everything and anything. It's simple enough to ignore the new inventions and make a 'pick of the litter' of the old stuff, not too crusty, not too shiny, but just right that matches the overall detail of your engine. See, it depends on if your engine has 12 coats of paint and is detailed like SEMA display. Or is it rode hard like a weekend warrior at the strip in 1957?
    I prefer to hide the knuckles on the underside of hoses but a lot of guys like 'em in your face. So just do it your way.
    Bob Lowry likes this.
  22. DrJekyllMrHyde
    DrJekyllMrHyde
    I love the attention this question has given, thanks for all that (important) information!
    leon bee, The Shift Wizard and nochop like this.
  23. Timothy Murphy
    Timothy Murphy
    Wow, hose clamps are like talking about politics! Thanks everyone
  24. LAROKE
    LAROKE
    McMaster-Carr. Stainless steel hose clamps with thumbscrews for securing the PCV valve. Screenshot (8).png
  25. 05snopro440
    05snopro440
    Agreed. My 62 Bel Air used to have tower clamps. Used to.
    The only way to get some of them apart was to cut them off. I'll never put them on anything I own again.
    Ford52PU, nochop and mad mikey like this.
  26. saltflats
    saltflats
    from Missouri
    Here's the answer for those pesky tower clamps.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
  28. Budget36
    Budget36
    I’ve always wondered about SS hose clamps and why, oh why, did “they” use just steel for the screw?
    Effing screw always rusts up.
    harpo1313 and Beanscoot like this.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    Starting in '62 ,all the places I worked ,we tossed the first 2 & replaced them with worm drives !
  30. Bandit Billy
    Bandit Billy
    I get the whole period correct thing but date coded clamps on hot rods? Soon the corvette guys are going to start laughing at us.
    When I had a stint put a few years back I didn’t ask the doc to use a date correct chunk of copper, I opted for the latest ***anium mesh. I’m only traditional on the outside.
    29A-V8, Jim the Sweep, joel and 9 others like this.
