Technical Correct hose clamp
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, Nov 9, 2023.
  1. nochop
    nochop
    from norcal
    Exhaust repair kit
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    swade41, 2OLD2FAST and Bandit Billy like this.
  3. Budget36
    Budget36
    Well color me dumb as dirt, but I never had the spring clamps come loose on me or cause an issue.
    I used my brake spring pliers to r and r them.
    Texas57 and alanp561 like this.
  4. alanp561
    alanp561
    So, your new handle should be "Bionic Billy"? ;)
    Bandit Billy likes this.
  5. deathrowdave
    deathrowdave
    from NKy
    My old ***mins and Deuce and 1/2 , had a couple of enclosed worm clamps , not sure the brand , but these were best I have ever used . I think McMaster Carr is the supplier
  6. saltflats
    saltflats
    from Missouri
    The spring clamps should be replaced if removed when replacing the hose.
    osage orange likes this.
  7. rusty rocket
    rusty rocket
    I’d like to find a few dozen of these types for use on 3/8” fuel lines. 6C538595-89BE-45D3-A1A4-807E51503EBF.jpeg 05ED040D-13AB-4A8F-B26D-0FF490F56DD4.jpeg
    1971BB427, -Brent-, mad mikey and 2 others like this.
  8. BamaMav
    BamaMav
    from Berry, AL
    GM was still using those stupid tower clamps into the 80’s. Just replaced a heater valve on my 82 Vette, held in place by a damn tower clamp. Worm gear clamps went back on it.
    2OLD2FAST likes this.
  9. nochop
    nochop
    from norcal
    Rusty, I’d like to three of those (on the bottom) style for 2 barrel 94 air cleaner
  10. rusty rocket
    rusty rocket
    Steiner tractor has big ones but not small ones that I would like.
    deathrowdave and nochop like this.
  11. Pretty sure when I pulled the original engine in my 53 Bel Air that had sat since 73 and had been pretty much untouched under hood before that it had all worm clamps
  12. Those look a lot like my hose clamp cutter pliers. Mine have red handles ... but otherwise the same.
  13. swade41
    swade41
    from Buffalo,NY
    Wouldn't wire twist be era correct
    1940Willys likes this.
  14. Bandit Billy
    Bandit Billy
    My 442 has that style clamp like your top pic. They hold tight, don’t leak, easily removable and they are stainless steel so the polish up nice.
    I sold a little 62 nova a few years back and made “tower clamps” for it.
    I should patent them
    Squablow and saltflats like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    swade41, X38 and Bandit Billy like this.
  16. Bandit Billy
    Bandit Billy
    I didn’t say it was a “tower”ing achievement :cool:
  17. In_The_Pink
    In_The_Pink
    While not quite the same, these might be a good option, provided you aren't using them on a high-pressure fuel line: https://www.grainger.com/category/p...ng-clamps/spring-tension-clamps-for-tube-hose
    Just buy a few extra for when they slip out of the pliers and launch to the other side of the garage. :D
    FWIW, I've never had an issue with Corbin clamps, but they aren't very user friendly, even when used with the specific pliers. If you go with the worm-gear type clamps, spring for the all-stainless steel version, usually marked with an "all SS" on the barrel section.
  18. RodStRace
    RodStRace
    Just to toss out another part of the whole process to connect rubber hose to metal ****** ***embly; traditional cars rarely dealt with pressures over 5-10 PSI. Most locations used a minor barb or ridge.
    So what do you use to ease installation while not being too slippery? Dry, a bit of WD-40, spit, silicone lube, grease?
    One guy noted that this would have been researched by the factory where this task is performed many times on every vehicle. If you have tried to slip off an OE installed hose even with the clamp backed off, you know that stick. He races cars and wanted that OE security. He tried various things and came up with Isopropyl alcohol. It 'lubes' during ***embly, then dries to create a snug fit.
    BTW, towers ****, and the spring clamps always twist, even with the correct pliers. I understand that rubber shrinks over time, so a screw clamp can lose tension. The modern flat spring ones require a special tool to remove and install, pliers are often not able to access them. I think this is one area where the best solution still hasn't been found.
    nochop likes this.
  19. Oneball
    Oneball
    You should be able to find some off a WW2 Willys jeep, theres plenty demand from the rivet counters.
    nochop likes this.
  20. Model A Gomez
    Model A Gomez
    I think that's going a little too far on a "period correct" hot rod. I've built a couple of flathead powered Model A's and try to use mostly period correct parts including a generator but never worried about hose clamps!
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    According to who ???
    GlassThamesDoug likes this.
  22. saltflats
    saltflats
    from Missouri
    Says the mechanic that doesn't want a comeback.
  23. 29Sleeper
    29Sleeper
    from SoCal
    Factories in period always used the cheapest fastest way to install clamps - spring & tower. Those generally got tossed when the first owner changed a hose to a worm drive. Any poor hot rod builder in the 60s would be going through his dad's junk box digging out those hard to use factory clamps for his car. The 30 cents he saved was a gallon of gas.
    joel likes this.
  24. A 2 B
    A 2 B
    from SW Ontario
    I have always saved any clamps that I deemed re-useable and have ac***ulated a few bins full; bought a variety of several dozen new ones at a yard sale 30 years ago and bought one of these wire clamp tools years ago that I have not used yet.
    If they do the job, they are not only good, they are good enough.
    29Sleeper likes this.
  25. solidaxle
    solidaxle
    from Upstate,NY
    Worm gears clamps IMO clamp down the tightest. The OP wanted period correct, if you have proper size hoses towers should work fine. I have owned my "61" for 37 years with the tower type clamps, never had a problem. My car is a garage queen and rarely sees weather so they still look new without rust.
    I use the old thumb screw tower type on my "32", besides looking period correct, they worked a hell of a lot better then the early Ford repop clamps with the sliding tongue. Those are junk.
    Squablow likes this.
  26. spanners
    spanners
    I'd rather be tootling along in my Hotrod with decent clamps instead of on the side of the road trying to stop coolant or fuel leaking because of 'period correct' clamps.
  27. error404
    error404
    from CA
    reported.
    :D
    mad mikey, squirrel and RodStRace like this.
  28. J. A. Miller
    J. A. Miller
    from Central NY
  29. jnaki
    jnaki
    @Timothy Murphy
    Hello,
    In the 60s, there were all sorts of hose clamps for all makes. The wire loop units were good, but were hard to take off or slide back to adjust or unhook the hose if needed. The screw units with grooves were the easiest and most of us took any wire loops off and replaced them with the screw units of varying sizes. The most common thing to do was adjust the screw so it was sticking out facing you when you needed access.
    Some custom guys turned the groove side showing for a smoother look when people saw their motor compartments. That was an extra thing to garner more custom points. If ever a change was needed, a funky screw driver with 90 degree angle was necessary to take off the clamp. But, the polished or chromed mini louvers + adjustable screw or flat wrench sided versions on the shiny strip showing on black hoses looked great.
    Jnaki
    The ones we did not like were the ones that had screws on top for adjustment, but clamped into a clip of sorts. A lot of times, we screwed the down, but somehow they popped up for a reason or two.
    These are timeless and work well. All sizes for all application. There is no period correct clamps for the 60s as plenty of different ones were used, but all fingers could point to those screw in clamps with grooves. Easy on/off, simple adjustments, and plenty of sizes for all hoses... YRMV
    saltracer219 likes this.
  30. Jack E/NJ
    Jack E/NJ
    from NJ
    A 2 B >>>I have always saved any clamps>>ac***ulated a few bins full; bought a variety of several dozen new ones at a yard sale 30 years ago and bought one of these wire clamp tools years ago that I have not used yet>>>>
    Since you seem afflicted with hose-clamp obsessive-compulsive disorder, I suggest this kit might satisfy perhaps one of your deepest desires to have your very own clamp for up to a 16-foot diameter hose should you ever need it.
    Budget36 and A 2 B like this.
