Hot Rods Another Deuce Five Window Gets my Attention
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Nov 1, 2023.
  1. RockyMtnWay
    RockyMtnWay
    Used an oversized Tanks tank on my current sedan project and although I have a set of the reinforcement triangles (and fit them), there’s really no way to disguise the ‘full diaper’ oversized tank so decided not to use them. Kinda regretted that decision as soon as the paint was on as so much of the tank is now so visible on a highboy sedan. :(
    In my defense, car was originally going to be a full fender car.
    Long story short….if you have the reinforcement triangles….use them.
  2. ct1932ford
    ct1932ford
    I did not know they offered them!
  3. ct1932ford
    ct1932ford
    I just contacted Tanks. They no longer offer them. Anyone know where I could get them?? Thanks
  4. ct1932ford
    ct1932ford
    I think I will just make them. Or not!
    chryslerfan55 and tb33anda3rd like this.
  5. Happydaze
    Happydaze
    I'm feeling like I've turned over 2 pages at once! The full fendered black 5w with the great stance, has gone?
    Chris
  6. ct1932ford
    ct1932ford
    Yep, got this one in September. Needed something to keep this old man moving.
  7. nochop
    nochop
    from norcal
    I’ve got a question, is that rail with the deck lid bumpers a stock item? My Avatar was originally a rumble seat car now a trunk car. I never noticed that on other 32’s. IMG_6362.jpeg
  8. nochop
    nochop
    from norcal
    Power of the hamb! Found it upc bc 20038 (answered my own question) thanks.
  9. RockyMtnWay
    RockyMtnWay
    Should be easy enough to make. They are pretty simple things.:)
  10. ct1932ford
    ct1932ford
    IMG_5507.jpeg 72134173675__B6EF87D3-7B66-440A-A7BE-B6A533CC70CE.jpeg IMG_5515.jpeg IMG_5514.jpeg Made a bracket for fuel tank safety vent check valve today, also made tail light brackets and mounted front headlight bar that I finished painting. IMG_5508.jpeg IMG_5510.jpeg
  11. Stogy
    Stogy
    Nice work Hotrodder...;)
    TFoch, brady1929 and ct1932ford like this.
  12. ct1932ford
    ct1932ford
    Thanks!:cool:
    Stogy likes this.
  13. TomT
    TomT
    You did the same rumble-to-trunk kid treatment on the 5-window body I bought from you. Nice work and it’s always good to keep busy …..
    ct1932ford and chryslerfan55 like this.
  14. ct1932ford
    ct1932ford
    I think you bought that from Greg , not me! Thanks Mark
  15. tb33anda3rd
    tb33anda3rd
    keep the green and put red wheels on it.
    TFoch, Tumblin' Dice, swifty and 2 others like this.
  16. ct1932ford
    ct1932ford
    I see a green car and I want to paint it Black!️
    chryslerfan55, BamaMav, TFoch and 6 others like this.
  17. ct1932ford
    ct1932ford
    Working on several things at the same time. Finished off brake lines. Just waiting for tank to be painted.
    Started on front end damper. This car did not seem to need one , but I think the steering will feel a bit firmer. Anyway, I always use one. Working on my signature mounting bracket. IMG_5522.jpeg IMG_5523.jpeg IMG_5524.jpeg
  18. Jim Mothershead
    Jim Mothershead
    Neat-o theme for the build. Nice work.
    Street rods are never finished, that is part of the fun.
    You have grease in the blood for sure......check that black line on your wrist !
    Keep us updated.
    thanx Jim Mothershead, bangin' on old cars since 1957
    Our 5w attached >>
  19. Jim Mothershead
    Jim Mothershead
    Hot Rod Art.JPG love those '32s
    ct1932ford, chryslerfan55 and Stogy like this.
  20. Jim Mothershead
    Jim Mothershead
    Neat-o project.
    Have fun.
  21. ct1932ford
    ct1932ford
    When you buy a car sight unseen you usually get some things that are expected and some things that make no sense. This car is no exception.
    Nice body on car and then the inside of the doors were a mess. So, I completely redo them.
    The frame all finished and painted nice , yet the bump stops on frame over rear axle we’re just hammered flat and painted over. I cut the rivets clean and paint area and install new ones.
    I’m not complaining, I just don’t understand some building practices.
    Back to my upgrades etc..
    Besides bump stops this week I finished steering damper, and started battery holder.
    The battery mount on this car was another not so nice job. With the cut off switch having to be cut into pieces in order to remove it. Must have been installed prior to installing body on frame. :eek: IMG_5510.jpeg IMG_5532.jpeg IMG_5535.jpeg IMG_5537.jpeg IMG_5538.jpeg
  22. The37Kid
    The37Kid
    Cast Front Axle?
    ct1932ford likes this.
  23. alchemy
    alchemy
    Will the bump stops smash the brake lines? Looks like the car found the right guy to clean it up.
    ct1932ford, anothercarguy and Stogy like this.
  24. ct1932ford
    ct1932ford
    Bump stops will never get that much travel to hit . Just looks right. Thanks
  25. Happydaze
    Happydaze
    At the rate you're going at this, unless the to do list is particularly long, you'll be well finished before winter has had a chance to get going!
    Chris
  26. 19Eddy30
    19Eddy30
    from VA
    just asking , Having the vent under , No gas fumes circulating back into ****pit? When I had my vent under both Duces
    Fenders & non with loop ,gas smell , So I ran Vent in side rail upper side about 1 inch before end ,
  27. ct1932ford
    ct1932ford
    We shall see. That rollover check valve needs to be higher than the tank. That is as high a spot as I have unless I put it in the trunk :eek:
    That ain’t happening.
  28. ct1932ford
    ct1932ford
    Super Bell. Same one in my roadster. Both early ones. When they were good.
    oliver westlund, Stogy and The37Kid like this.
  29. krylon32
    krylon32
    from Nebraska
    Great job, can't wait to see it finished.
    ct1932ford and Stogy like this.
  30. ct1932ford
    ct1932ford
    Mounted new kill switch. Will have carpet binding done this week for switch cutout.
    Working on mounting battery. Here is on picture. It will make more sense when you see it finished. I promise :rolleyes: IMG_5537.jpeg IMG_5538.jpeg IMG_5542.jpeg
