Projects Romeo and Juliet - A 1950s Period 28 roadster build.
Discussion in 'Traditional Hot Rods' started by Texas36, Mar 7, 2022.
  1. Nobey
    Nobey
    That looks very professional, great job guys.....Can't wait to see this one on the road.
    chryslerfan55 and Texas36 like this.
  2. ChuckleHead_Al
    ChuckleHead_Al
    Why am I just seeing this, great job so far Trey
    Texas36 likes this.
  3. DaveyJonez
    DaveyJonez
    from Houston
    Looks great!!
    Texas36 likes this.
  4. Texas36
    Texas36
    Thanks Alex!
  5. Texas36
    Texas36
    Not a lot to report this weekend but We got our tire sizes figured out and the frame sitting roughly where it needs to be. I flipped the wishbones and pie cut them to get the caster set.
  6. Texas36
    Texas36
    With our wedding coming up in three weeks and not a whole lot of time in the future to devote to the car, we decided to get to a nice stopping point this weekend to keep motivation high.
    First I needed to get the transmission crossmember fabbed up.
    Just like the engine mount, the trans mount will also get gusseted for strength in the future.
    With the engine and trans sitting in the frame, I was able to figure out the rear end angle and get the spring hangers tacked on.
    Next was to do a little cutting of the subframe to account for the frame step. My dad gave me a hand with this to speed the process up. 57A7B08C-3540-4448-93BD-F72D9ACCA44D.jpeg
  7. Texas36
    Texas36
    With the rear floor cut out and the subframe trimmed, we lifted the body onto the frame. 9DB937FF-43B7-4A60-90BA-CDF7433A47F4.jpeg
    The firewall needs to be trimmed so its a couple inches too far back and as a result the body is about an inch too high in the rear, but overall we are super happy with the way its shaping up. Since this project is going on hold for a bit, having it in this state looking like a real hotrod will keep us motivated in the future when we finally have time to mess with it again. Thanks for following along!
  8. wheeltramp brian
    wheeltramp brian
    She's a roller! Good luck!
    Texas36 likes this.
  9. Texas36
    Texas36
    Man how time flies, but we’re back from Hiatus.
    I got the rear subframe trimmed and the firewall cut out to put the body where it needs to be.
    I then started to rework the firewall to clear the engine.
    70527949372__02AFA53C-9944-45FD-A431-3674E1664E12.jpeg IMG_8284.jpeg IMG_8286.jpeg IMG_8287.jpeg
    When the body comes off I will get the pieces fitting right and tacked in.
    Nailhead A-V8, Tim, Bugguts and 3 others like this.
  10. Texas36
    Texas36
    Time to make some rear body mounts to tie the subframe back together.
  11. Texas36
    Texas36
    Body pulled off and set aside for now.
    Then on to beefing up the transmission crossmember
    Thats all for now. The engine and trans come out next so I can finish the motor mount, boxing plates and miscellaneous frame stuff.
    Nailhead A-V8, BigRRR, Jet96 and 12 others like this.
  12. 48fordnut
    48fordnut
    You did a great job matching the sub frame to the frame.
    Thanks,
    jim
    Texas36 likes this.
  13. brokenspoke
    brokenspoke
    Its coming along really good
    Texas36 likes this.
  14. scoob_daddy
    scoob_daddy
    from Georgia
    looking good!
    Texas36 likes this.
  15. general gow
    general gow
    MODERATOR
    stoked to see this moving along again. gonna be a neat car.
  16. Jeff34
    Jeff34
    Great project! Coming along very nicely! Curious to see how you mount your pedals and master cylinder since I'm building something very similar.
    G_Don and Texas36 like this.
  17. JalopyJimbo
    JalopyJimbo
    from NE Alabama
    Awesome project!
    Texas36 likes this.
  18. Texas36
    Texas36
    With the engine out, I flipped the frame over to get some of the underside squared away. First I finalized my wishbone mounts and got them welded on. IMG_8506.jpeg
    Next I decided it was time to make templates and get my front boxing plates cut out. I brought them out just past the wishbone mounts. I really love the look of inset boxing plates, to me it gives it a more factory-ish look versus flush boxing plates. I also punched some holes in them because racecar. IMG_8515.jpeg
    I think the next item on the list is the very important task of cleaning my workspace :confused:
  19. So you’re saying she got to the umm, bottom of it?
  20. Jeff34
    Jeff34
    Did you use some type of rubber mount for the transmission, or is it bolted directly to the cross member? Thx.
  21. DaveyJonez
    DaveyJonez
    from Houston
    Great job!!
    Texas36 likes this.
  22. Texas36
    Texas36
    Hey man, sorry I havent been on here in a while. The transmission has a rubber mount that will bolt to my crossmember
  23. blackdog
    blackdog
    from Golden BC
    Wow, love what you guys are doing. Looks great.
    Texas36 and chryslerfan55 like this.
  24. Jeff34
    Jeff34
    Thanks! I'm on a similar track.
    Texas36 likes this.
  25. Texas36
    Texas36
    Well, as usual life gets crazy and projects go on hold once again. We welcomed our daughter 2 months ago and between figuring out how to be parents and building our house ourselves, time and money has been tight! But Ive been finding time here and there to get some work done.
    The more I thought about the car, the more unhappy I was with the ride height. I kind of took the easy way out with a basic frame step and spring-on-top setup, and the existing model A crossmember wasn't in very good shape and would need lots of work to fix. The frame will now get a Z, spring-behind rear setup and a flat front crossmember.
    After getting the frame tacked to the table, we cut the front crossmember out and put some pie cuts in it. IMG_0141.jpeg
    rod1, hfh, OFT and 4 others like this.
  26. Texas36
    Texas36
    Reversed the front spring in my press.
    Fixed the nasty hole in the front crossmember.
    I acquired a set of 36 rear wishbones from a friend, but still waiting for a few more odds and ends. Hopefully I’ll be updating soon with some more progress.
  27. Outback
    Outback
    from NE Vic
    Congratulations on the lil future hot rodder :D
    The hot rod is looking good, we often make decisions because the path is more straightforward but as a result miss out on what 'coulda' been, good on you for chasing your goals
    OFT and Texas36 like this.
  28. Jeff34
    Jeff34
    Great to see you back! I like that flattened front cross member.
    Texas36 likes this.
  29. Nailhead A-V8
    Nailhead A-V8
    Goodgradulations! as my 5 yr. old says...:D
    Speedy Canuck and Texas36 like this.
  30. Jeff34
    Jeff34
    When you flattened the front cross member, did you have to cut more off the back side to clear the crank pulley?
    Outback likes this.
