Technical Correct hose clamp
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, Nov 9, 2023.
  1. BamaMav
    BamaMav
    from Berry, AL
    Damn, we’ve been turned into a bunch of restorers!:eek: Correct clamp, correct clocking, date coded….:rolleyes: Some of y’all making this too complicated!o_O It’s a clamp, not a Swiss watch!:D
  2. 05snopro440
    05snopro440
    Whatever clocking means you can get at it to retighten or remove.
  3. 57 Fargo
    57 Fargo
    If I am trying to care that day, I try to install them so the screw is on the bottom or “hidden” side of the hose, most days I just put them where they are the easiest to get at.
  4. alanp561
    alanp561
    Your friendly local HVAC shop should have those large diameter hose clamps. If not, there's always 200 MPH duct tape. I like red myself ;).
  5. Squablow
    Squablow
    I bought some of those repop '40 Ford style band clamps for my T build for the look but they ended up leaking, no matter how tight. They've since been replaced with worm drive clamps. I don't remember where but I found an ad or a patent or something for a worm drive clamp as early as 1938, they're definitely period correct for a right-after WWII era build.
  6. MCjim
    MCjim
    from soCal
    These are always a "nice" touch...
    X38 likes this.
  7. X38
    X38
    :eek::eek::eek:
    The perfect plumbing companion for Garlits fake injection cover over the carb.:D
  8. X38
    X38
    From the land of disappointment: my new Norma clamps don't say 'made in Germany,' instead they say 'made for Norma' whatever that means. :rolleyes::rolleyes::rolleyes::mad::mad::mad:
    They look the same, but it plays with my mind.
  9. twenty8
    twenty8
    That's a joke, right?...... Tell me you're kidding. It's gotta be a leg pull. Surely you're not serious......:eek:
    stubbsrodandcustom likes this.
  10. DDDenny
  11. twenty8
    twenty8
    I do know he was just taking the piss......;)
  12. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I know not really "period correct" But a very good piece I have used when you don't want to trash your hoses on high torque applications. Swedish Style Meatballs are also good. Personally I would just throw Ideal on any build as the parts store stuff is junk. If you want to go above and beyond, give them a nice coat of gloss black and that with the rubber looks stellar but also not period correct. EH.....
  13. AccurateMike
    AccurateMike
  14. yes they did. ^^^^^^
    I can remember dad doing concourse cars in the shop when I was a little guy (late 50s early '60s) that had to have the right clamp, but all the hot rods that went through the shop got worm clamps. At least that was what was hangin on the board on the wall (in various sizes).
    427 sleeper and 48fordnut like this.
  15. MCjim
    MCjim
    from soCal
    Absolutely; sometimes sarcasm is hard to detect in cyberspace.
    427 sleeper and twenty8 like this.
  16. Illustrious Hector
    Illustrious Hector
    No, they're not. As for tower clamps, I've never took one off without twisting it out of shape. They should be subjected to the treatment for bolts with damaged threads, placed on the anvil and smashed.
    das858 and 05snopro440 like this.
  17. BoxCar Tom
    BoxCar Tom
    Oh my God, Is this horse dead yet? Seems to be a gap Sun provided a different version screw clamp to secure their tachometers to the steering column.
    tach clamp C IMG_3021.jpg tach clamp A IMG_3023.jpg tach clamp B IMG_3022.jpg
    427 sleeper likes this.
  18. 282doorUK
    282doorUK
    Because a SS screw will gall onto the SS band and wreck the clamp, just when you put that last little tweek of the driver on it, plain steel won't do that.
    Budget36 and ottersea like this.
