Technical ***November 2023 Banger Meet Thread - Shopping Season***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 1, 2023.
  1. The37Kid
    The37Kid
    [​IMG]The Gravell HAL rolled out of the barn at Lime Rock Race Track here in Connecticut when Jim Haynes owned it. That was in the mid 1970's about 50 years ago time sure does fly by. Bob DSCF6663.JPG DSCF6662.JPG DSCF6664.JPG DSCF6665.JPG
    282doorUK, hotrodA, Outback and 4 others like this.
  2. s.e.charles
    s.e.charles
    i've posted this in the Ford Barn forum, but understand this is a different venue, if this is annoying, please read no further.
    i want to build a 1:24 scale air compressor & water pump, both powered x a model A four cylinder engine.
    Q: how would the coupling be made from the banger transmission to the two devices?
    Q: could there be, perhaps using the factory transmission, a transfer case that would allow power to be used driving one or both pump & compressor.
    Q: would the engine be powerful (in the real world) enough to serve both?
    the entire ***embly will be installed on a reinforced '28 Ford A ch***is.
    i am only interested in creating a plausible 1:24 scale model. if a 1:1 has never been made, there's probably good reason!
    thanks
  3. The37Kid
    The37Kid
    Are you talking about a Smiths air compressor?
  4. s.e.charles
    s.e.charles
    i think that was a brand i saved in my internet search, but i would not be building a replica or a specific brand, just something when it was finished i could say "that would mechanically work in 1:1 scale".
  5. railcarmover
    railcarmover
    If the B is stock it has positive flow to the main bearings. It has to be altered and a relief added for pressurizing. Positive flow is an improvement over the A’s gravity feed, actual pressure is an improvement over flow, insuring a consistent feed of oil to the hydrodynamic wedge. You can actually develop too much oil pressure with an improperly set relief valve, still satisfying the engines need but pouting an undue load on the engine turning the pump, some argue the standard 10 psi per 1000 rpm is too high.
  6. 282doorUK
    282doorUK
    As a Ford newby I didn't realise it wasn't real pressure fed, is pressurising a complicated job? Is there a thread on here showing how to do it?
  7. railcarmover
    railcarmover
    Jim Brierleys book explain the process in detail
    https://www.autobooks-aerobooks.com/product/4-bangers-and-me-color
    You can get the book directly from Jim as well, I just don’t have his email handy.
    It’s a great read and gives the particulars on pressurizing a B. We are all learning all the time brother
    Outback and 282doorUK like this.
  8. Take a look at first page of this thread for Jim’s contact info
    J
  9. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Are there blueprints or detailed schematics anywhere for A or B cylinder heads? I have the urge to noodle around in CAD a bit and a cursory search didn't turn up anything useful.
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’m an unaware of any publicly available information. You could submit a request to the Henry Ford Museum for factory prints…
    If you have a mill, a few measuring tools, and some patience, you could figure out the deck profile. The rest is up to your imagination
  11. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I might look into that. I have been to "The Henry"... hell of a place. It does seem absolutely bananas that there is nothing immediately available for a car with almost 100 years of history behind it.
    Unfortunately, I don't have a mill, or much knowledge of manual machining, but I do have an imagination. I have been playing around with some of the new lidar scanning technology available in cell phones (what a time to be alive...) and I can obtain measurements that way, but the blueprints would save some trouble... and certainly be more HAMB-approved.
  12. joemac05
    joemac05
    You just have to look under the right rock... For example, I just did a quick search for;
    "ford model A engine cad drawings" and now have the cad file of a cylinder block loaded as below.
    GuyW and s.e.charles like this.
  13. Jiminy
    Jiminy
  14. joemac05
    joemac05
    Cool, and from there you can load the model into something like the free version of Fusion 360 and dimension a drawing as need something like this...
  15. Yes, very cool,
    Phil Damon had sent me some a while ago and they were spot on with dims.
    John
    Stan Back likes this.
  16. Phil Damon
    Phil Damon
    from San Diego
    The cylinder block model above is mine. If interested in the cylinder head, I can upload it also.
  17. joemac05
    joemac05
    Well well now, you meet the nicest people on this forum. :) Very well done CAD model Phil. We all owe you a vote of thanks for sharing it.
  18. You should ask to see a picture of Phil’s A mod
    Very nice but that’s just my opinion
    J
  19. joemac05
    joemac05
    Well now Phil, I herby am asking... Pretty please.. :p
  20. Phil Damon
    Phil Damon
    from San Diego
  21. Phil Damon
    Phil Damon
    from San Diego
    metalhead140, Outback, GuyW and 2 others like this.
  22. 282doorUK
    282doorUK
    An interesting new video about banger babbiting.
    akkhotrod and GuyW like this.
  23. 282doorUK
    282doorUK
  24. 282doorUK
    282doorUK
    Thanks, it's so obvious now I know!
  25. Over the years many different configurations have been developed
    Even in recent years there have been some interesting developments IMG_1443.jpeg 61212325169__8E8FEA0E-D948-43A2-82B3-5142F384C19F.jpeg
  26. Steves46
    Steves46
    from Florida
    Any of you guys running a Frog Mouth Scoop? Thinking about getting one for my banger but wanted to see if there were any issues. Thanks.
  27. wuga
    wuga
  28. hotrodA
    hotrodA
    I posted some pics the other day of my Alexander OHV with its new valves and machine work.
    I was digging around in my office today and ran across these pics of my vintage sprint car motor, taken when I dragged it home probably 20 odd years ago. I found it at the Nashville swap meet covered up under a table.
    Here are some specs.
    B block, once had a CRAGAR head, per the owner.
    Built and machined by a long gone shop in Lexington Ky, based on block tag. Wombwell Automotive Parts. https://pergelator.blogspot.com/2016/03/wombwell-auto-parts-company.html
    Babbit mains and rods in good shape.
    Drilled B counter-weighted crank for oil to the rods.
    Pop up pistons for CRAGAR comb. chamber.
    Front drive Pontiac 6 cyl. oil pump for full pressure. Shortened and cam driven.
    Side drive for mag (long gone)
    AR trans with cut down splined AR flywheel with indexed timing marks and stubby shifter.
    All steel plate multi disc clutch pack.
    Big sump oil pan with through tubes for air cooling. There’s a ton of br*** in that oil pan!
    So, using my Alexander head……
    Plan #1.
    Build a replica sprint car. Exhibition only.
    I have Es*** rails, banjo rear with floater axles, new br*** radiator, V8-60 front axle, shortened torque tube, race prepped Franklin steering box, 4 spoke wheel, rear gas tank, F&R springs and shocks, 16” knock off wires, knobby and ribbed tires.
    PLUS an aluminum body, believed to be a Dreyer, with track nose and grille, cowl and tail. Just need dash, hood and sides. Body appears to be late pre-war or early post war, ‘41 or ‘46. Came out of CA. Picture from previous owner.
    OR
    Plan #2.
    Use the Alexander in my roadster, replacing the 59AB with a built banger, but without the hard core race pieces.
    Input and suggestions appreciated!
    Hopefully you enjoy the banger ****.
