Technical Blower snout length on a SBC
Discussion in 'The Hokey Ass Message Board' started by Gavin Tittle, Nov 15, 2023.
  1. Lol,,,,sorry,,,wasn’t implying that at all .
    Just giving respect to Jim,,,,,he’s earned it here !
    Tommy
    mad mikey and 427 sleeper like this.
  2. Gavin Tittle
    Gavin Tittle
    Oh he absolutely has, learned more from his old posts than I could ever say
    427 sleeper likes this.
  3. swade41
    swade41
    from Buffalo,NY
    Is there anyway to plumb the intake instead of drilling the heads
    lumpy 63 likes this.
  4. Fordors
    Fordors
    This picture of your mock up on a SBC is marked to show how the B10 would need to be drilled to get coolant from the heads to a thermostat housing. Drilling the heads is an easier way to accomplish the task, at least to me.
  5. swade41
    swade41
    from Buffalo,NY
    My Enderle is plumbed similar
    I've seen intakes plumbed there and the two lines ran straight into the upper radiator tank
    mad mikey and Desoto291Hemi like this.
  6. Gavin Tittle
    Gavin Tittle
    The B10 has a water port coming up from both sides in the rear, on either side of the distributor, one side has bleeder valve and the other is a 1/2 inch male pipe thread. Could be modified to run off of that fairly easily, currently that’s sounding like the simplest way to get coolant back into the motor.
  7. 427 sleeper
    427 sleeper
    I can understand wanting to use a vintage speed part, we've all done it hundreds of times, but this might be one of those times to use a later model part. The port on the left side of the B-10 manifold was intended for a temp. sender and the one on the right was added by a previous owner for an air bleed, and using those ports for an outlet will not allow proper cooling, the coolant need's to be routed to the front of the engine - through the head's. If you don't want to drill and tap the front of the head's for the crossover and remote t-stat housing, a later model manifold with a water crossover and t-stat housing on the front might be your best bet, and then you can figure the snout length once the blower location and accessory pulley's are accounted for. JMO
  8. Gavin Tittle
    Gavin Tittle
    Yeah, this has been in the back of my head all along.
    something in me hates sacrificing the “cool factor” for something as stupid as functionality.
    I’m not dead set against drilling the heads, just don’t love the plan
  9. 427 sleeper
    427 sleeper
    Just remember, everything is way cooler when it function's properly. :cool:
  10. mad mikey
    mad mikey
    Without a proper cooling system on a blown SBC, you are in for a frustrating and bad time. Not functional friendly and a piss poor performer and driving experience on the street.
  11. 427 sleeper
    427 sleeper
    ^^^^^^ TRUTH ^^^^^^
    mad mikey likes this.
  12. 19Eddy30
    19Eddy30
    from VA
    use your B10 intake , dont be scared to drill the heads on engine & tap ,
    Set of harbor freight pip tabs under $100, not the best but they work.
    Drill small pilot hole 1/8 first , then tape or have someone hold Vac hose while you drill the bigger hole , same when tapping ,, No big deal ,,, Me personally if I hade to do, I would have No problem drilling my 15 deg heads .
    "water gallery" vacuum out after wards
    Thermostat optional, !!!
    make a Y with two #10s to 1-1/4 1-1/2 to top of Rad
    #10s might be to big , Drop to #8s
    You can play with washers to speed up or slow down flow ,,
    This is part of
    Hot Rodding /Racing
    427 sleeper and mad mikey like this.
  13. crf500
    crf500
    i have the complete isky polished blower setup for that b 10 intake. idler bracket. water pump pulley. whole bit!
  14. 427 sleeper
    427 sleeper
    Is it for sale??? :rolleyes:
    INVISIBLEKID and mad mikey like this.
  15. crf500
    crf500
    sure its not cheap. i paid up for it
  16. Gavin Tittle
    Gavin Tittle
    Yeah I understand this, have owned plenty of questionably operable cars. I have no intention of half assing this, drilling the heads seems to be the best option, I’m pretty committed to this manifold because I just can’t be bothered to buy another one, and have no interest in a modern one
  17. Gavin Tittle
    Gavin Tittle
    This is tempting, but given that this started as a “spare parts” blower build, and the B10 happened to be priced right and fit the time period. I’m sure you want more than I want to pay, and that’s perfectly fair
    I copied this from another thread and saved it on my phone for that "someday that I might need it".
  19. Gavin Tittle
    Gavin Tittle
    And now I’ve saved it, the pattern continues. thank you
  20. Hollywood-East
    Hollywood-East
    Here's a couple shot's of the stuff needed for the Drag intake, It was combined with isky drive set-up..
  21. 19Eddy30
    19Eddy30
    from VA
    That style of pulley , I do not how hard to find, But with a lathe & mill can be
    Duplicate & in different sizes if Originally Not made with a tooth count needed,
    Machine from solid stock ,
    or take a modern pulley , cut center out & machine a new center , weld in , face it off & tapper ,,,
    I have made odd ball thing for my self ,
  22. Hollywood-East
    Hollywood-East
    Here's a sbc I'm putting together myself, Blower is a hemi , Hemi/sbc are the same as far as pulley reference, give or take depending on your V KIMG6355.JPG KIMG6356.JPG pulley count, May need a shim to get out farther if two pulleys are needed..
    swade41 and mad mikey like this.
  23. Hollywood-East
    Hollywood-East
    This is a V 671, only showing to give ideas.. Used a late 60's/ Early 70's truck alternator mount KIMG6357.JPG KIMG6360.JPG
  24. 19Eddy30
    19Eddy30
    from VA
    what brand intake ,
    I Do not recall seeing a intake with thermostat housing offset for 6:71 8:71 intake
  25. swade41
    swade41
    from Buffalo,NY
    Looks like a modified Offenhauser intake
    mad mikey, lumpy 63 and 427 sleeper like this.
  26. Hollywood-East
    Hollywood-East
    Like Swade said, the V series blower intakes were modified Dual quad
  27. Hollywood-East
    Hollywood-East
    Well... I looked to see what the Weiand 7136 (thermostat) intake was going for new..
    Discontinued !
  28. Gavin Tittle
    Gavin Tittle
  29. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I would not drill the holes per the diagram you have until you moch up all your stuff and see just where you have room and don't have room. Using Hollywood-Easts picture, you can see that there are a lot of things that you need to avoid interference with to make it work. Also, instead of an NPT thread, you migh want to use a JIC fitting...maybe one with a swivel so you can clock the fittings well. Also it would allow all fittings to be a silver color to match the tube.
    mad mikey and saltflats like this.
  30. swade41
    swade41
    from Buffalo,NY
