Projects The Wee Terry Coupe Build Thread
Discussion in 'Traditional Hot Rods' started by Little Terry, Aug 11, 2020.
  1. ezrodder1
    ezrodder1
    Really cool build! What are you using for the Liscense plate light? Looks nice and compact. I like the way have mounted the plate to the body!
    Stogy and Little Terry like this.
  2. Little Terry
    Little Terry
    Thanks.
    The license plate light is from a UK supplier, but i think they are available from quite a few speed shops etc. Here is a link to it......
    https://www.duksville.com/product/1940s-style-license-plate-light/
    Stogy likes this.
  3. ezrodder1
    ezrodder1
    Thanks for the link!
  4. Tim_with_a_T
    Tim_with_a_T
  5. Little Terry
    Little Terry
    I’ve finished off the fuel cap and filler neck. Got it sitting right to match the trunk header panel angle.
    5410E5E6-735B-472E-9C52-1DF4EADD0CA0.jpeg 6B9CA2F9-AA29-4C33-B749-31A6394B0461.jpeg FF4A8A36-B069-40B6-BE93-620F5712CF30.jpeg BD9F053C-6D56-4753-B470-4B144684D769.jpeg 44B9378B-0E0D-43F7-BB8D-149E2B17B8C9.jpeg
    Deutscher, Outback, brEad and 5 others like this.
  6. Just Gary
    Just Gary
    Great build!
    I just finished going through the whole thread.
    I especially like the dash, and the trunk lid, and the fuel filler, and your girls' laughs during the test ride, and..., and..., :)
  7. 4 pedals
    4 pedals
    from Nor Cal
    That's unfortunate on the gauges. SW used to be a good brand...
    Devin
    Just Gary, Stogy and Little Terry like this.
  8. Little Terry
    Little Terry
    I’ve made a start on a hood top. Still a bit of finishing required but I wanted to eyeball it in place before I decide how it will end up. I plan to fix the two sides via a strap underneath.
    Deutscher, Stogy, vtwhead and 2 others like this.
  9. Little Terry
    Little Terry
  10. redoxide
    redoxide
    nice wee detail Mark .
    Tim and Little Terry like this.
  11. Little Terry
    Little Terry
    Thanks Ian. It’s another area of the project that sounded ok until I did it, then I wasn’t happy with the raw edge of the sheet steel.
    I have also managed to get the pedal surround changed. It looks much better than the slots I had on the previous setup. I made a tweak to the profile of the pedals and made an adjustable clutch stop to keep the majority of the pedals below the floor level.
    B0A62844-171D-4B79-B0C4-067E7CD7B5B7.jpeg 95BE696F-14A9-4E04-B456-AEE6F6438071.jpeg CF35DDB1-C79D-4906-8EDA-C18F0C4BE936.jpeg
  12. Little Terry
    Little Terry
    Still working on wiring…..
    9AEB7B1C-EA39-4F42-9770-8A33689A17E4.jpeg 4DCA76AD-B992-4512-9C36-41E398DA7FE5.jpeg
    And I made up a little alloy collar to go at the base of the steering column where it meets the floor panels.
  13. Tim
    Tim
    from KCMO
    Coming together great! All those non- clocked flatheads would about make me go cross eyed/ crazy but I don’t have to look at it you do lol. Thanks for the update. Dig that collar on the column I think I have something laying around the shop I may be able to force into similar service!
    Little Terry likes this.
  14. Little Terry
    Little Terry
    Made a start on the roof panel. I’m going to try using an old pup tent as a temporary cover, secured with Tenax fasteners. Not looking for 100% waterproof, just something to keep the worst off that can be rolled up and stored in the trunk for emergency use.
    8475FAF8-A3EE-43CF-9426-C0AAE5C2B089.jpeg F8BACBD6-22F4-4919-BBCE-6C2C7F85B5F3.jpeg E26010A5-1123-4C66-94AB-EC6457DB65C9.jpeg 58747174-13AA-4CB1-B892-902578DAAEF4.jpeg 91285975-A241-4D6B-8E70-B8CD838B7CDC.jpeg 8B0F1624-489A-464E-B231-8938B3964ABF.jpeg
    Deutscher, brEad, dana barlow and 4 others like this.
  15. Little Terry
    Little Terry
    Haha, I will try and get them lined up for you, Tim. It has not escaped me, but just one of those jobs that hasn't gotten sorted out just yet! :)
    Tim and Outback like this.
  16. You could re-waterproof that canv*** to improve its ability to repel water.
    Originally it was likely given an oil skin treatment which you can easily redo yourself.
    Here's a YouTube showing the process:
    NOTE: I don't think you need to add the color to it for it to work (but I'm not sure about that)
    Another method to waterproof canv*** is to make it into a "Waxed Canv***" (None the less although this works well on new canv*** it might not be compatible over top of the army's original treatment so perhaps test it on some s**** first.)
    Here's a YouTube showing that process:
  17. Little Terry
    Little Terry
    Thanks Gregger. Those are interesting videos.
    I do plan to re-proof it some way, as it's pretty thin. There is a product over here called 'Fabsil' that is available in a can or a spray for not a lot of money. I was going to try that first. It's not as traditional as dressing as a frontiersman and applying it in the woods, but maybe it will get me a decent result :). I certainly don't want to color the material I have, or even make it too much darker if I can help it.
    Being a country boy, I have been known to wear a 'waxed jacket' from time to time, which is made with a similar material to the second youtube clip. The re-proofing for those coats is also available over here in spray form.
    We (read: my wife) are going to fold a hem on it and I have some 1.1/2" cotton webbing on the way to help strengthen the seams where the Tenax fittings are attached. We may also lay some across-ways in line with the wood roof bows to protect them from rubbing through.
    brEad and Outback like this.
  18. There is a lot to like in this build. A big thank you for laying it all out for us in pictures, words and videos. It means a lot to a bunch of us, as you have heard. Keep up the good work and enjoy.
    Little Terry and Outback like this.
  19. Little Terry
    Little Terry
    Thanks for that - it means a lot that you have mentioned it and to have the support of this forum. It's hard to know how many folks are even looking at this thread. But laying bare what I am doing somehow encourages me to try as hard as I can to make a decent job of it (by my standards).
    brEad, daylatedollarshort and Outback like this.
  20. Outback
    Outback
    from NE Vic, Oz
    For every comment there will be dozens of readers & folks who are 'following' (I hate the term "follower's" in the social media setting) along. Your's is another thread I look forward to reading when it pops up,
    I have thought about utilizing doped fabric is a number of different application's. Your canvas insert is a cool feature
  21. Little Terry
    Little Terry
    This one is for you Tim….
    brEad, Bandit Billy, Outback and 4 others like this.
  22. Tim
    Tim
    from KCMO
    Haha, so much better
  23. Little Terry
    Little Terry
    I have made a bit more progress on the insert with the help of my resident seamstress. It will need a couple of tucks at the front corners.
    Deutscher, brEad, tr_rodder and 8 others like this.
  24. Tim
    Tim
    from KCMO
    Good stuff
  25. Outback
    Outback
    from NE Vic, Oz
    Moving along nicely!
  26. loudbang
    Don't worry about likes what is important is VIEWS that is the number of times someone clicked on your build but never made a reply. 41000+ views is nothing to sneeze at
    brEad, Little Terry and Gipper like this.
  27. Little Terry
    Little Terry
    It’s nice to finally have some decent weather. I have been playing about trying to get the motor set up. Still getting a bit of a stumble as I set off, but otherwise ok. Could be ignition as changing jets doesn’t seem to make much difference.
    brEad, 4 pedals, 282doorUK and 8 others like this.
  28. the pinstriper
    the pinstriper
    from duxford UK
    Spot on that good Sir
  29. Great build thread, car is really coming out nice,
    Outback and Little Terry like this.
  30. MMM1693
    MMM1693
    This car is just f---ing outstanding!
