Early 283 Chevy Small-Block Questions
Discussion in 'The Hokey Ass Message Board' started by JimA, Sep 13, 2006.
  1. JimA
    JimA
    I have a '58-'59 era small-block that came with a stick that I'm converting to a 200R-4 Automatic trans. I wondered if anyone knows which flexplate I need and where to get it? I have the trans and torque converter- just need the flex-plate and starter.
    Also was hoping someone had a direct answer as to where I can find a set of chrome OE-style pulleys? I'm amsuming these engines originally used a "long" water pump and I'm keeping it relatively stock- just dressed up a little.
    I noticed people selling these parts list them as '64-up, and do not include the earlier engines. Is this because they used a different harmonmic balancer set-up than the '64-up engines? Does it affect which flex-plate I need as well? Thanks Jim
  2. Jim, as far as I know early-water pump pulleys for long pumps are the same (except for the 1-belt or 2-belt part), and the same for the crank pulleys. I dont think theres much diff between what youd find in the Summit book versus what you find at Krack Auto. 265/283 used the little no-balancer hubs on the crank and the pulley bolts on the same pattern. If you want some old crusty originals Im going to a Model A swap Sunday and can look there.
    Homie
  3. Normal Norman
    Normal Norman
    from Goshen IN.
    Jim, Those are internally balanced,in other words use the standard flex plate w/168 tooth ring gear and starter for the year of engine.(there are some differences in starter bolt pattern. The external balanced engines are 400 sm.blk and big blocks. I'm not sure which ones or if its all of 'em. Your 283 came with a short pump so just buy pulleys accordingly. There are no "bolt up" differences. The only problem you might run into is the 200r4 trans might require a smaller flywheel. The Camaros and some others use that trans. and have a 153 tooth ring gear. You can do all that but will need a mini starter with a combination bolt pattern(100.00 or less). Normal
  4. JimA
    JimA
    I have originals on my engine- was hoping there was a set ready to go I could bolt-on when I clean up the engine. Thanks, Jim
  5. JimA
    JimA
    Thanks for that tip! Jim
  6. snap too
    snap too
    from lost wages
    Those engines were internally balanced and the crank flange bolt pattern should take a later flex plate , however ,it would be wise to see if the nose of the convertor will fit and that your block has the starter bolt holes drilled into the bottom of the RH ear .GM made several diameter changes in flex plates and you have to match the proper starter nose to it.
  7. Terry
    Terry
    My pulleys for 283 came from Summit.
  8. Royalshifter
    Royalshifter
    Moderator
    Kragens carries the chrome pulley's.
  9. Lucky Strike
    Lucky Strike
    Finding chrome pulleys for the 283 is no problem, I've actually been looking for an original steel / black paint crank pulley for mine, and it is harder to come by than chrome. the PAW catalogue has what you are looking for. Let me know when you decide to s**** the old pulleys and I'll take em.
  10. my '60 283 has a short water pump. i don't think your going to find a chrome water pump pulley real easy (unless some resto places have one). the water pump pulley for the generator is about 1/4" deeper then the alt pulley (i believe it's for gen only). those pulleys you can't run with the large 4 bolt main balancers of the late 60's/70's. the crank pulleys are the same through the years (can't get a picture because my photoshops ****s). if you want to cheat a little you can run the pulley (black one) that makes the w/p turn faster, it's from a 70's van. the step pulley in the picture is the same depth as a single groove alt w/p pulley.
  11. JimA
    JimA
    Also I want to run a Powermaster Alt that looks like an early generator- Anyone have experience with one of those???
    Anybody hear of early 283's that were painted yellow? I just recently found out that all '57 Trucks ran GREY 265's when equipped with a V-8, 283 wasn't available in trucks from what I recently read.
  12. Lucky Strike
    Lucky Strike
  13. arkiehotrods
    arkiehotrods
  14. JimA
    JimA
  15. DRD57
    DRD57
    I've got a set of chrome pulleys I'll swap you for your stockers.
    I've got a 283 that I'm trying to make look new/original.
  16. revkev6
    revkev6
    from ma
  17. Not to steal the thread, but which Harmonic balancer should a mid 70's 350 SBC use?
  18. I was gonna say that the '58/9 SBC used a short pump. I go a '59 in the garage right now awaiting its trip to the machine shop.
    The 200R should have an 11" converter. At least the last one I put in an old hooptie had an 11" converter. And the mini starter was what we ended up using.
    Summit will have what you need in the line of pullies in stock. But I
    personally prefer old crusty one's myself. I just prefer the look of aged chrome.:D
    Whatcha buildin' this time Jim?
  19. 53sled
    53sled
    from KCMO
    I used a gm dealer 305 balancer. it was 45 bucks and worked great, but was a smaller diameter than what the tab wanted. put on a new tab, ready to go. pulleys fit fine.
  20. That's a short pump motor... get a single grooved short pump pulley at any swap meet or from Summit.
    Also, the "yellow" SBC motors were actually chartruse... they were the 265's that were left over from 1956 and installed into the '57's...
    Sam.
  21. JimA
    JimA
    It's the engine for my '56 Chevy pickup- trying to get it running. I need to drive it sooo bad!
  22. 3wLarry
    3wLarry
    from Owasso, Ok
    ...just my .02 cents Jim, but fan belts tend to slip on chrome pulleys. That said, I've got a new set of chrome short pump pulleys(single groove) I'm not going to use on my coupe(went with the stock painted ones)...you can have 'em if'n you want 'em, but you gotta send your stock ones to DRD57...:D
  23. Deuce Roadster
    Deuce Roadster
    Boones has one on his 29 ...
    PM him ... :D
    heres a photo of his ...
  24. WeedsSpeed
    WeedsSpeed
    from Kansas
    The stock 283 balancer should be riveted together so you have to use a pulley that has holes in it so the rivets can go through them if you run a new style pulley it will not draw up tight to the balancer, because of they are not equipped with the holes.
  25. Lucky Strike
    Lucky Strike
    Yep that's right. Sorry. Im running a long water pump on mine. I guess I could switch over to a short pump. I've got a couple laying around.
  26. Weldon 1949
    Weldon 1949
    Homeresque... 265/283 used the little no-balancer hubs on the crank and the pulley bolts on the same pattern.
    Homereaque,
    Do you know the reason for the small no-balancer hub on the early 283? I have a 1964 283 that was connected to a Powerglide. When it goes back in the Elky, it will have a Muncie M-20 behind it. Was the small hub used on both auto and manual trans units? Or do I need to get a real torsional balancer to go along with the swap? Any information is really appreciated.
    Weldon Haltom
    Baytown, TX
  27. Fitzworld
    Fitzworld
    Jim, aren't you going to have to drill and tap the block for the starter to be able to bolt up?
    Good luck
    Fitzworld
  28. 57JoeFoMoPar
    57JoeFoMoPar
    I think '57 was the last year for SBC to not have a starter to block provision, and even in '57 some of the V8s had factory block mounted starters (the Turboglide equipped cars...I had one). 58 was the first year for the side mounts, and i think from then on they had block mounted starters too.
    all small blocks ran a 14" flexplate until 1980, when they switched to the smaller 12.5" flexplate. many of the later 14" flexplates from the 1970s have the same bolt pattern so you can use a factory starter with the later trans. I just pulled the 78 sbc out of my truck last week and dropped in an 86 sbc, the 12.5" flexplate bolted right up to the '78 converter
  29. Gasser57
    Gasser57
    After you drop the 200 trans in, do you have to cut or modify the driveshaft if you're replacing an early glide?
  30. Roothawg
    Roothawg
    Any updates Jim? I am following this one closely because this is the setup I am using for my 50.
