Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Frames
    Frames
    Finish welding on 1950 sprint car frame for my show room. 2023-11-14 09.14.33-1.jpg 2023-11-14 09.14.33-2.jpg Built removable ends to attach to engine stands for painting.
    Okie Pete, Dave Mc, swade41 and 7 others like this.
  2. Lone Star Mopar
    Lone Star Mopar
    Nice ! Did you add the extra bracing on the lift feet ? Ive never noticed the gussets & flat braces on one before.
  3. saltflats
    saltflats
    from Missouri
    We have a Challenger brand at the shop that has those. Nice trip hazard if your not carful.
    Tickety Boo likes this.
  4. El Caballo
    El Caballo
    from Houston TX
    IMG_9621.jpeg Made it home safely. Cleaning it up before it takes a nap until I get home again for Christmas.
    simplestone, Okie Pete, Voh and 14 others like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Just finished replacing the tired black carpet in my corvette with red salt and pepper
    6AECF507-386F-4818-BAEA-56F7C22CAB8F.jpeg D0FAAEF1-2979-48D9-ABDD-4DDBEB2E7D90.jpeg
    Spent a fair amount of time s****ing old contact adhesive off the floor, also I put some dynamat insulation on the toe board but I forgot to take a picture of that. Hopefully it will be a little cooler inside...
    Thought about using one of these *****in Hurst shifter boots but I thought of it too late, I had already cut the opening for the factory piece and the hole was too wide to use this. I tried to put the cut carpet piece back in the hole but it was too noticeable... oh well
    8B6BF6B4-4F25-49A1-80ED-B28906B07466.jpeg 9B74E46A-6D8D-452F-8F84-48DEF9A3A11D.jpeg 0FAC89DC-F1E4-423E-8978-87C9FFB67057.jpeg
    I did end up decorating the shift plate with some red acrylic
  6. squirrel
    Interesting.
    I fit my main floor pieces to the rear outer corner. So the inner bound edge is laying flat on the floor, not curving up at all. And I left the seats in, so the carpet covers the bolts. Seems to work fine this way.
    Too bad about the hole for the shifter, that would have been kind of modern looking, though? And you'd have lost your ash tray, and we all know how important an ash tray is for storing spare nickels and dimes.
    In the end, it looks great!
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I bought the foam backed carpet, it wouldn’t lay right on the tunnel between the seats so I took them out so I could glue the carpet down there. I kinda agonized over the seat bolts showing but they don’t show much in the end.... put my floor mats back and n CFA99F99-E017-40C6-8AFF-1386DD64A169.jpeg
  8. El Caballo
    El Caballo
    from Houston TX
    Good choice for the salt and pepper carpet, looks way better.
  9. saltflats
    saltflats
    from Missouri
    I made the effort today before the rain shows up to get started on the truss for the carport. Did get the first one up. Had to use a piece of heavy wall tubing to extend the boom for height and to keep the legs from contacting the wall before it was stood up. This won't be a problem with the rest of them. Now that I have a system that won't kill me this should go smooth for the rest of this project.
  10. Lone Star Mopar
    Lone Star Mopar
    Never heard of Salt & Pepper carpet before.. Ive only paid attention to the "loop" & color.
    Alot of work, but man it looks killer !!
    427 sleeper and Moriarity like this.
  11. saltflats
    saltflats
    from Missouri
    When I bought the new leg tubing it was 1/4 inch wall and wouldn't just slide together like the thin wall these cheap carport are made with originally so I'm having to make sleeves to attach the trusses to the legs and the one floor rail that will be against the closed West wall. The east side (by my ba*****t door) will have the base of the legs welded to a plate and anchored to the concrete. This will take care of any trip hazards walking between the legs and also easy to roll jacks, engine hoist and any wheeled carts or equipment. I also welded in some heavy angle to support across the peak of the truss. This used carport has some bow in the trusses from heavy snow load is my guess. It was built with the roof tin in the horizonal direction, my plan it to install in vertical so snow will have a better chance of sliding off.
  12. bchctybob
    bchctybob
    I brought my extra 324 Olds up from LA. I delivered the Vauxhall g***er to Mike VV and didn’t want to drive home with an empty trailer so now the old Olds is up here in NorCal where I can clean it and give it some TLC. No idea what I’m gonna do with it yet.
    Without the rain gear….
  13. lumpy 63
    lumpy 63
    20231121_164905.jpg The rodent is almost done. Probably gunna fire it off on Turkey day.
  14. Dave Mc
    Dave Mc
    I have been working on this 34 Ford Grille IMG_0220.JPG 34 grille1.jpg.jpeg 34 grille2.jpg.jpeg 34 grille mldg.jpg 34 grille3.jpg , now it's back on the wall again.
  15. lumpy 63
    lumpy 63
    20231123_154715.jpg The rodent is alive and well:cool: pay no attention to the high tech zip tie radiator mount:p gotta paint run stand and wire it now.
  16. lumpy 63
    lumpy 63
    BTW Happy Thanksgiving guys!
  17. chevy57dude
    chevy57dude
    @Dave Mc has quite the treasure wall going there. Lumpy - That's a rat everyone can like. Looks tough with the painted VCs.
  18. gene-koning
    gene-koning
    It appears as though a water pump replacement will be the next project on my 49 Dodge pickup, and its coming soon, real soon.
    What should be a 2-3 hour job will likely be much longer. I have to remove the hood to gain access, and then the pump buried down there in a pretty tight working space. It takes 2 people to remove and reinstall the hood without scratching up the paint.
    Pic 1, This is the hood, just before the paint. Front to back is just over 4' long. One guy has to move it from the front center. You grab the hood sides and sort of flop it on. I'm 6'1", sitting in place on the truck, the lowest point on the hood is above my belly.
    Pic 2, The water pump is the lowest pulley in this pic, the fan shroud in front of the water pump is the electric fan that is attached to the radiator, hopefully I won't need to remove it. Everything above the water pump has to come off because all that mess is bolted to water pump mounting bolts (factory engineering, not mine).
    I know you are all feeling sorry for me now...:rolleyes::D 100_0804 (1).JPG 100_1005.JPG
  19. 29A-V8
    29A-V8
    from wyoming
    swade41 and lumpy 63 like this.
  20. 29A-V8
    29A-V8
    from wyoming
    Have the same problems didnt show up until my late 50s Im 71 now and use a hand truck for anything heavier than a 6 pack
  21. 29A-V8
    29A-V8
    from wyoming
    Fixing trans leaks on my 56 Victoria finished resealing the torque converter. Stuffed the trans back in. Pan gasket was leaking as well so here we go pull it too, was stuck hard thought I had a bolt started in case it fell off while I was prying on it, guess what, it popped along with what oil I didnt get drained hit me soaked my best sunday work shirt. what the hell time to call it a day, been snowing all day anyway.
  22. Jkmar73
    Jkmar73
    from Tulare, CA
    Installed the driveline. I ordered it from Strange Engineering. First time I ever ordered one. Fit was perfect. IMG_0965.jpeg
  23. lumpy 63
    lumpy 63
    20231125_102526.jpg Went and picked up my buddy Steves Olds and hauled it back to the shop for some A pillar repair
  24. 67drake
    67drake
    from Muscoda WI
    Chased all the threads on my ‘62 260. Bottoming taps showed up today. IMG_0030.jpeg IMG_0041.jpeg
    Okie Pete, mad mikey, GuyW and 9 others like this.
  25. mopacltd
    mopacltd
    Lumpy, the only pictures you seem post of my brother is his back side. Glad to see it's heading to the shop for the welding and then some gl***.
    lumpy 63 likes this.
  26. swade41
    swade41
    from Buffalo,NY
    Today I moved the rest of the stuff that was in front of the inner garage door to get the Henry J out, because it's ready for the first test drive. To many heavy pieces that's for sure, I was ready to call it a day as soon as I started.
    But I kept plugging away even though my back was crying, decided to move the 57 over to line up with the outside door behind it. I used the cheap harbor freight $7 dollar furniture dollies under the wheels, front first so I could keep the rear wheels chocked.
    Then the back, pretty sure it'll sneak out, after I move all the stuff behind the truck which I did move a portion of that also.
    Let me out !
  27. fastcar1953
    fastcar1953
    Bicycle hanging from rafters. :D Thought I was the only one that done that. Took 2 down but still have one hanging around. Got to love the old bikes.
  28. swade41
    swade41
    from Buffalo,NY
    That bike was a ton of fun at parties here, two drunks trying to make the corner always ended up in a crash and a ton of laughs lol
    I do have a couple old bikes stashed in the loft above the inner garage, that tandem is 7 ft long, maybe longer, it takes up a ton of space on the floor and you need a long bed pickup to haul it anywhere.
    chevy57dude likes this.
  29. alumslot
    alumslot
    Good for you and the first drive. Would you let me know how the less springs on the front axle work. I think I need to remove some on mine and would like to know how it rode.
    Jim
    SilverJimmy likes this.
  30. swade41
    swade41
    from Buffalo,NY
    I'm only going to run it up the block and back, not really a first drive, I won't be doing that until next year.
  31. 29A-V8
    29A-V8
    from wyoming
    Got the transmission in the 56 Victoria just a few loose ends to tie up, then have to replace the wheel cyls on all four corners, wanted to rebuild them but when I inquired of the "lady" at the parts house about rebuild kits she laughs. So I had to buy new cyls. Last time I did this kits were around a buck and a half a piece, cyls are now $22.00. kinda dates me I guess. two things wrong here as I see it #1 is "lady" at the parts house, #2 is guess all you have to be able to do to work at the parts house is run a computer and ask a few questions like what engine and model, computer says we dont have those but you can get theses. They dont even have to look unless you want the part then she tells you something is wrong computer says we have 2 but there is none on the shelf, the computer must not have reordered, but I can have them in the morning. So guess what I wait a day to finish.
    chryslerfan55 and Dave Mc like this.
