Technical 1932 Ford Frame Serial Number
Discussion in 'The Hokey Ass Message Board' started by sodas38, Nov 19, 2023.
  1. sodas38
    sodas38
    I have a 1932 Ford frame that is stamped: 477I3 there are stats at the start and the end. I have not found anything that makes these numbers work for 1932. Any thoughts? The stars and numbers match the type of stamping a you’d see from that era.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. J. A. Miller
    J. A. Miller
    from Central NY
    The letter I represents the number 1.
    Your serial number 47713 fits within the 1932 range.
    Toms Dogs and Tim like this.
  4. krylon32
    krylon32
    from Nebraska
    Why don't you ask your question over on the Ford Barn? David Rehor resident 32 Ford guru hangs out on there.
  5. deucendude
    deucendude
    from norcal
    Obviously it has been tampered with. No 32 p***enger frames had those numbers like that. Star stamps are easy to get. Just a made up number. I am 99.999 percent sure. You will get the same answer on the ford barn. From what I know all p***enger frames started with a STAR then AB, B, or 18. Then production sequence numbers. Original numbers are in three places on top of the left frame rail. You might find them if you start stripping the top of the frame. Inside the firewall leg and half way back and on top of the rear hump.
    lurker mick likes this.
  6. $um Fun
    $um Fun
    from Nor Cal
    Is it the same number on all the correct spots on the frame?
  7. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I had an original Ford frame(32) that had the star at beginning and end,but started with the letter F—-HAMB members said F was for right hand drive. 18 followed the F meaning v8. Number was F18****. IMG_0296.jpeg
  8. FritzJr
    FritzJr
    The serial number was stamped at three places on the top of the left frame rail. Typically, the stamping near the firewall was the only one to get the 18- prefix or the B- prefix. The other two locations merely had the serial number with no prefix.
    deucemac, warbird1, Fordors and 3 others like this.
  9. alchemy
    alchemy
    Yep, Fritz knows.
    Fordors likes this.
  10. sodas38
    sodas38
    Its stamped middle of the frame and the rear, near the hump of the rear axle. The cowl stamping I suspect is no longer visable due to cutting and splicing of old frame.
  11. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Funny Story........
    When I was spending time at a local Aero Club, the guy who owned the building and the airfield was a pilot and an IA inspector. He /the club restored an old Cessna. He discovered that the nearly completed airplane did not have any serial number at a specific location.........it might have been no serial number at any location due to repairs that were made. So he proceeded to stamp the correct serial number at all the correct locations. Had a big smile on his face when he was done.:D
    Then he contacted the FAA to send one of its inspectors out to bring the airplane back into certification. After musing around for a while, the inspector informed him that the factory had never placed a number on these airplanes at the location where he had one...........:eek:
    CSPIDY likes this.
  12. PONTNAK123
    PONTNAK123
    i dont know about other years in vanpelt sales llc serial number information but their 32 info is incorrect.they state 32 v8 numbers are 18-1 to 18-203126 which is incorrect. 1932 v8 ch***is serial numbers were 18-1 thru 18 -212238. the correct information are in these books that are sourced from actual ford production records.these books are early ford v8 as henry built it and production facts book 1932 -1938 by edward francis and beverly de angelis. i have a bonifed 32 5 window that i bought .the person i bought it from owned for 70 years. he bought it when he was 13. i bought it when he was 83. it is serial number star 18 207- - - star
  13. Mr48chev
  14. redo32
    redo32
    If that's the number on the ***le.... Don't worry about it. If the numbers are stamped in the two other places ... Don't worry about it. Contrary to Ducendude statement there are lots of non standard numbers that have been reported.
    Imagine it's 1932, it was your birthday and you did some major partying over the weekend but you're a good employee and show up Monday to make your $5. Your head throbs everytime you swing that hammer. You drop the one and eight stamps, screw it, you continue to stamp until the line moves and you get a chance to pick them up.
    There was 31 ***embly plants in the US alone. Lots of opportunities to mis-stamp that frame.
  15. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Scott, Your number is most likely legit! A lot of the 32 frames I have had do not have the complete serial number in the middle and on the rear kick up. I have found this very common on 18- V8 frames. Your frame is most likely a V8 frame and the complete serial number would be *18-47713* If your cowl number was still intact I would bet that is what it had stamped on it. A lot of the time you will find the complete number in the middle location of the frame but not always. And almost always the rear location is missing the "18". Not sure why Ford did not stamp the complete serial numbers back there but thats what I have found over the years. Your number looks original and legit to me but If you want to look at and compare next time you are coming up my way I probably have 9 or 10 original 32 frames here you can look at.
    big duece likes this.
  16. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    What makes me 99% sure your frame is a V8 frame is the prefix for the 4cyl cars was AB or just B and all 4cylinder 32's started with the number 5 and your first letter is clearly a 4
    Budget36 and big duece like this.
  17. The37Kid
    The37Kid
    There is no way Ford could afford to have the frame numbers stamped one number at a time. Has anyone ever seen the setup that held the number stamps?
    Budget36 likes this.
  18. Budget36
    Budget36
    “Oooo, oooo, oooo” says Arnold in the back of the cl*** with his hand up (welcome back Kotter).
    I actually have, not specifically for frames, but my dad had a letter and number stamp set in a wooden box.
    Maybe 6in x 2in long. There was a slot where the stamp “holder” was.
    Insert the stamps and they were all lined up, then smack them.
    I wonder who he loaned that to? Whoever it was never brought it back.
    bschwoeble likes this.
  19. alchemy
    alchemy
    I think the numbers were stamped one at a time. They are always crooked. A stamp holder would make it a straight line.
  20. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Yes you are correct! In 1932 the numbers were stamped one at a time. I think he is referring to The Gang Stamp set like GM used in the 60's
    PONTNAK123 likes this.
  21. RICH B
    RICH B
    I don't believe I have ever seen a Ford frame number stamping that was perfectly straight like when a holder would have been used.
    PONTNAK123 and big duece like this.
  22. The37Kid
    The37Kid
    I agree, but I just can imagine one guy in the frame section stamping numbers by hand for 8-10 hours and they all came out in order and then went into some master paperwork stack that somehow matched some production records.
  23. rcnut223
    rcnut223
    from wisconsin
    this is correct for the cowl stamping area, the arch are has a stamping that may not have the AB, B or 18.
