Technical desoto 291 fit in a 1933 ford without cutting firewall
Discussion in 'The Hokey Ass Message Board' started by rustymetal, Nov 21, 2023.
  1. rustymetal
    rustymetal
    thanks for any help
  2. So the car is painted before you verified that the engine you want to run will fit without surgery? I'm going with "that is unlikely".
  3. rustymetal
    rustymetal
    i have a flathead for it just thinking
  4. Bandit Billy
    Bandit Billy
    Well, I have no real clue. But they are not very long. I put a 330 DeSoto in my 41 ford PU, it fit with no firewall or floor surgery, with a stock size radiator and mechanical fan. I did use a short SBC water pump from Hot Heads. I am thinking that my truck had a flathead originally, so maybe they are close to the same length? The right valve cover is exactly a 8mm spark plug wire distance from the firewall. It is basically wall-to-wall engine.
  5. nochop
    nochop
    from norcal
  6. Tim
    Tim
    from KCMO
    I think it seems feasible if you are putting the motor and steering in together/ with each other. If you have to place the motor based on existing steering or have to run steering to work around the motor your going to come into less options for placement and clearing your stock firewall
  7. RICH B
    RICH B
    I really like that the chart posted by @nochop includes the numbers for an Allison. You know; just in case.
  8. ERguitar
    ERguitar
    Agreed! I need to stick this on the wall of the shop for bench racing purposes if nothing else. @nochop any comments as to the accuracy of the dimensions on this do***ent?
    lostn51 likes this.
  9. alanp561
    alanp561
    For those of us who don't happen to have a 291 DeSoto laying around for reference, maybe you could add your dimensions to the chart? Who knows, there might be one lurking around the corner. ;) BTW, that's a pretty handy chart, @nochop. Thanks.
    Budget36 likes this.
  10. lostn51
    lostn51
    from Tennessee
    Yep I screenshot the chart and will be blowing it up so I can have it in the garage,
    Thanks @nochop!!!!!
  11. flynbrian48
    flynbrian48
    A 276 fit like a glove in my '29, BUT... It's on a '32 frame, so there's a bit more room between the (stock steel) firewall and radiator. The notch in the firewall looks like it was made to snuggle around the distributor. 8DAC7638-6B79-4C13-9765-EA46BD83E044.jpeg 1C9862D9-081B-4982-895C-67FB99EE8213.jpeg CCB1C63A-4C02-4144-A2A8-412597C6994B.jpeg
  12. nochop
    nochop
    from norcal
    Your welcome. Pm me and I can mail the file
  13. nochop
    nochop
    from norcal
    No, I don’t even remember where it came from
  14. nochop
    nochop
    from norcal
    Pm me and I’ll send out the file for the low low price of…..free
  15. Tim
    Tim
    from KCMO
    That chart is in carnut.com
    Most of the baby hemis are roughly sbc length wise. If I get a minute today I’ll google around and find you a confirmed length
