Projects My GN Cycle Car tribute build
Discussion in 'The Hokey Ass Message Board' started by Ziggster, Dec 5, 2018.
  1. Ziggster
    Ziggster
    Will pull the heads this week or next hopefully and check the piston to valve clearances. Should be ok, but just want to be absolutely sure. That will be the last thing that I need to do to the engine mechanically before I can run it. I just wish my exhaust collectors, etc. were done so I could actually start it. I’ve spent the last two week almost entirely working on my daughter’s car. Just wrapped working on it yesterday. Also I picked a new piece of gl*** yesterday for the cabinet so will get that installed today and do some blasting of parts for my truck.
  2. 64 DODGE 440
    64 DODGE 440
    from so cal
    No piston/valve clearance problems with a flathead.
    Ziggster likes this.
  3. Ziggster
    Ziggster
    Lol! Wasn’t thinking before typing.
  4. Ziggster
    Ziggster
    shivasdad and motoklas like this.
  5. Ziggster
    Ziggster
    Checking was done with Felpro gasket in place - 0.055” thk. Headbolts were torqued to 25 ft-lbs in sequence. Piston to head clearance was about 0.073”.
  6. Ziggster
    Ziggster
    Aside from the valve to head clearances, I also checked clearance between the sparkplug electrode and exhaust valve. Clearance was about 0.128”, but the electrode is on an angle with the valve surface.
    4D20C174-2636-430A-B7FA-28EC0D004929.jpeg 9BD534A0-41E8-4EB9-B8FE-E65366EEAEA3.jpeg 50D5BBF7-F99D-47C6-B6FF-E252D704A754.jpeg
    motoklas likes this.
  7. Ziggster
    Ziggster
    PS head is installed. Sprayed Felpro head gasket with a couple of coats of Permatex Copper Spray-A-Gasket. Applied Permatex High Temperature Thread Sealant to all the headbolts. Torqued in three steps: 30/45/65 ft-lbs.
    D4208A2C-A123-4825-AAA4-40FB948B34CB.jpeg D64FF217-6A50-4BDA-9C73-B381F4CB56B3.jpeg
    C8FDC31F-ADAA-4B49-8F56-788124DB1A86.jpeg 9B17E46F-FE5F-4BB2-94FB-A9C475C667EB.jpeg ACDADA11-DC69-40DB-B92F-6A3208ECCB03.jpeg
    brEad and motoklas like this.
  8. Ziggster
    Ziggster
    Want to check torque on the spark plugs, but then this happened sometime today. Didn’t touch it at all today.
    A3B65929-BD7B-4BF1-B936-2A53070DF49E.jpeg 14742DDF-46F6-486C-8F2B-0213A738E0B9.jpeg
    Stogy likes this.
  9. Phil P
    Phil P
    It was probably time for a cleanup and reorganize :cool:.
    Phil
    Stogy and Ziggster like this.
  10. Ziggster
    Ziggster
    Haha! Fell down last year - my fault. This time it was my kiddo that pulled out all the drawers looking for a some pliers to pull quills out from the dog’s snout.
    Stogy and brEad like this.
  11. Ziggster
    Ziggster
    ****oned up the head on the PS this morning. This means the engine is finally ***embled! Almost 5 yrs in the making. Also got my 2022 dash plaque! It’s a special day for sure.
  12. Ziggster
    Ziggster
    Been a while. Lots has happened to me personally. Youngest is off to university to study mech engineering in Montreal. Oldest moved out and seems to have found her path, and it seems I will be officially going on medical retirement at the end of the year.
    Not even sure where I left off, but I know I had been occupied with rebuilding the T5 and had ordered various parts. Of course, can’t remember a thing about what needs to be done, so have to kinda start over. So, being that winter is here, and my personal life is a little more sorted, I feel I need to get back into it. I’ll be splitting my spare time between this project, and my off-road rig which has to be road ready for travels to the USA south west next summer/fall.
    rod1, Stogy and 41 GMC K-18 like this.
  13. Stogy
    Stogy
    The day the garage had a tremor...:oops:...Glad no one was hurt...at an former place of work I had a 5' tall rolling 10 drawer toolbox that weighed A LOT...one of my colleagues was pushing it out of the way where he needed to access and he was pushing from the back side not the drawer side and a wheel hit a fastener sitting on the floor jamming the roll...I was watching this from a distance coincidentally and watched every drawer roll open and down she went...There was huge boom and vibration through the shop...it even clipped our product on the way down and dinged it...No-one injured luckily and lets say it was a tad more than 52 pickup...most tools survived and I banged out a couple dents and onward we went...I had a safety bar on the box but he didn't engage it...:oops:
    Hope you didn't loose anything in that incident...except a couple subtle expletives...quills in the nose yowser...
    Thoughts your way on life in the fast lane...and yes time to batten the hatches for a little white stuff...
    brEad, 41 GMC K-18 and Ziggster like this.
  14. johnod
    johnod
    I'll be looking forward to your updates.
    Stogy, 41 GMC K-18 and Ziggster like this.
  15. Ziggster
    Ziggster
    Think I’ve figured out that I’m missing parts. Also had a shifter adapter from a Chevy/GMC AstroVan which has disappeared somewhere. Want this to move the shifter from out of between my legs. Watched a few YT vids last night on the T5 rebuild. Seems Tremec ceased making the syncros for the WC version late last year and the aftermarket stuff is no good. Think mine are ok, but will need to confirm. I have a couple of spare units if need be.
  16. Ziggster
    Ziggster
    Was enough to remove the T5 from the engine as it was supported under the MDL hogshead adapter. The trans support rubber mount was just a bit of friction fit against the frame crossmember. Thus time, I’ll be bagging and tagging everything that comes off. Will start be cleaning out all the internal threads on the main T5 body, and removing and installing the front race for the countershaft.
    C16FB89D-CB7E-40A8-9A7E-B7DD77201E60.jpeg A8BA71A9-7AEA-49D6-AE7B-B8C0CD777CEB.jpeg
    brEad and Stogy like this.
  17. Ziggster
    Ziggster
    Decided to check some drawers that I had kept some of my flathead engine parts in, and sure enough, found three drawers filled with the “missing” T5 parts. That’s a relief. Usually it’s not that easy.
    brEad, Ned Ludd, SS327 and 1 other person like this.
  18. johnod
    johnod
    Had to look up " MDL hogshead adapter" :)
    Is that paint on ****** or something else?
  19. Ziggster
    Ziggster
    Decided to borrow one of the drain plugs from another spare T5 trans body because of this.
    Don’t have any 3/8” drive impact extensions, so grabbed a no-name one, and promptly snapped it with my cordless Makita 1/2” drive impact. Did manage to get the bigger out by hand.
    The plugs cleaned up nicely.
    brEad, V8-m and Stogy like this.
  20. Ziggster
    Ziggster
    Front countershaft bearing race is pressed in. Came in a SKF box, but race is from Timken.
  21. Ziggster
    Ziggster
    Plugs installed.
    Stogy, Crusty Chevy and V8-m like this.
  22. Ziggster
    Ziggster
    Made this little adapter to press on the bearings for the countershaft.
    Ned Ludd and Stogy like this.
  23. Ziggster
    Ziggster
    Came across this vid.
    Like his method better for installing the rear bearing for the countershaft than what Paul Cangialosi did on Eric The Car Guy’s channel. He tapped the bearing into place using a punch, while the bearing on the other end of the shaft was seated in its’ race. Maybe ok to do it that way, but prefer to press it into place.
  24. Ziggster
    Ziggster
    Also installed the magnet and retainer clip.
    Stogy likes this.
  25. Ziggster
    Ziggster
    New reverse idler gear installed with shaft.
    Cannot believe how mangled the old reverse idler gear was.
    Stogy likes this.
  26. Ziggster
    Ziggster
    Mocked up the new machined steel rear cluster retaining plate. Will now need to order a shim kit to get the correct pre-load. With the original shim, there doesn’t seem to be any discernible endplay, but shaft seems to spin too easily. According to Paul, there should be a bit of drag. According to Junkyard Dogg’s vid, end play should be between 0.002” and 0.004”, and shaft should spin freely. Interesting.
  27. johnod
    johnod
    Have you prior experience building ******s?
    Always seemed like a job I didn't want to attempt.
  28. Stogy
    Stogy
    Son took car out to party...and didn't say anything at all...:D
  29. Ziggster
    Ziggster
    No. First one. I felt the same way, but after watching Paul’s vids, I decided why the hell not.
    brEad, Ned Ludd and Stogy like this.
  30. Ziggster
    Ziggster
    Checked the play without the shim. Measured about 0.105”-0.106”. Hard to get an exact figure due to wobble of shaft once it moves up. Shim measures at 0.105”, so in theory I have about zero play. Think it is good, so ****oned up the bearing retainer with some blue threadlocker on the screws.
    Noticed two of the screws protruding past the inner wall. Didn’t look right, and noticed the other two screws were shorter, so swapped them out as it seemed the longer screws might hit the gear on the main shaft.
