What exactly do you want to know? This was my dad's car, it has a '32 K member with legs and the torque tube, 8ba, mechanical fan. Firewall had to be recessed a tad. This is running split wishbone up front.
I'm thinking 16 must be a typo? I've got 4.50s all round on mine so that would be a cheap option as I'd only need two tyres and no wheels, sometimes less is more! I wanted to get a closer look at your T but it was always parked by the timing tent instead of the pits.
Yup - typo... I hoover up all the 19's when people fit 16's. I did have 5.00 x 19 Blockleys on the rear originally - probably go back to a 5.50 when the Michelins wear out.
Beautiful car: What does have for rear suspension, frame kicked up or reverse spring eyes etc? Thanks, Steve
Thanks Steve, it's 40 rear with pirches welded on top. It's got a posies reversed eye spring in it, the narrower version. Frame is stock. It had a stock A rear spring in it for a while but it was a little to high in the back, and the spring would bottom against the welded on perches on bumps, so the inch narrower reversed eye fixed both issues.
