Hot Rods My DIY hood louvres
Discussion in 'The Hokey Ass Message Board' started by Tat2Neil, Nov 26, 2023.
  1. Tat2Neil
    Tat2Neil
    from Mesa AZ
    I had to dig out my hood to help me ensure I was mounting my grill shell at the correct height by matching up the body line. Good thing I did otherwise it would have been about an inch too high. But after a little more work it was dead on the money.
    Even though I had no intention of using my hood I wanted to make sure I built it to fit just in case one day I want to change it up. Since I had the hood out I got the crazy idea to try and do my own louvres. Back when I was a teenager circa 2005 and I had to take a hood for my boss to a guy in downtown Phoenix to get louvred and seeing his work and setup had me hooked on needing something with louvres someday.
    After a very short search on YouTube I found a great hour long video on making your own louvre stamp and die and his results looked impressive. So after a few hours with my band saw, belt sander, and a file, I had my tooling.
    I did a few test stamps on an old sign blank and seemed to work fairly well.
    IMG_2986.jpeg Then it took a few hours to make my grid for the layout.
    IMG_2997.jpeg Got to spend a couple hours on Thanksgiving doing the first side, but working off the ground I could only be hunched over for so long. I got out yesterday and finished off the other side. Still need to debur the edges and make a few small tweaks to a couple. They are far from perfect but I’m still proud of em.
    Fun little project! Thanks for checking it out
    Morrisman, hfh, Bumpstick and 99 others like this.
  2. Wow, you did a great job on those!
    Tow Truck Tom, Tat2Neil and Stogy like this.
  3. Stogy
    Stogy
    Nice bit of Handywork there @Tat2Neil...Theres been two Hambers here at least that made there own Louver Punches with admirable results...I know there were others but these two did Tech Threads...All Good careful with the sanding...
    Did you use a cut off saw to slot before punching?
    Maybe the Youtube you saw was Jerry I think he's on there...
  4. KevKo
    KevKo
    from Motown
    That looks great to me!
  5. y'sguy
    y'sguy
    from Tulsa, OK
    not an easy task! Way to make it work for you. A+ for patience and perseverance.
  6. Stogy
    Stogy
    @Tat2Neil are those hand hit. Did you use a Metal Hammer or Dead Blow?
    Six Ball, Tow Truck Tom and Tat2Neil like this.
  7. bschwoeble
    bschwoeble
    Very impressive. Good DIY.
  8. BJR
    BJR
    Now that is traditional hot rodding. Making and doing things yourself. :)
    I do have a question though, how did you line up the stamp and die to punch the louver?
  9. lumpy 63
    lumpy 63
    Hats off to you sir:cool:
  10. Looks like japhandkustoms style, but whatever, it's good.
  11. Stogy
    Stogy
    Jerry did the Cyclone Racer and I think the Rootbeer Colored Deuce 5 Window with his Handmade Hammer style punch...But the Die was a different profile...The principal of making it was similar...He cuts slots before Hammering and I suspect this Hamber did too he just didn't show it...
    Tow Truck Tom, Tat2Neil and Algoma56 like this.
  12. Michael Ottavi
    Michael Ottavi
  13. ekimneirbo
    ekimneirbo
    As you should be........this kind of work was the essence of early hot rodding. Maybe don't dress them up too much so that they retain the homegrown look rather than the professional perfect look..........and get a big smile on your face every time someone asks you who did them. Oh, forgot....you aren't going to actually use the hood......Are you? :p
  14. Stogy
    Stogy
    :rolleyes:...bet he does...;)...heck change it out for a month or two...
    ekimneirbo likes this.
  15. Tat2Neil
    Tat2Neil
    from Mesa AZ
    Thankyou!
    Thank you much! I knew I wouldn’t have the capacity or space for a full size press, so I was very excited to see someone get such respectable results with a stamp and die, and I’m guilty of thinking if I can do about anything I set my mind too. And yessir I would cut a slot first then line up the stamp/die and bring the hammer down.
    Thank you
    Thank you! It was actually pretty fun, especially when you get results that you are pleased with makes it all the better!
    I used a 10# sledge hammer I picked up from Home Depot. Lemme tell ya, after picking that thing up 100+ times and hammering each louvre 4-5 times, my right arm was useless last night ha!
    Six Ball, alanp561, Deadbird and 10 others like this.
  16. Stogy
    Stogy
    How's the ears...:)...there's a job that needs earplugs...;)
    Tow Truck Tom and Shitbox like this.
  17. Tat2Neil
    Tat2Neil
    from Mesa AZ
    Appreciate that!
    Thanks! And first I would cut a slot with the thinnest cut off wheel I could get. Then I have a center line mark on my die, and the back side of the stamp, so I would line those up with the center line mark in my grid and hammer away. Then slide the hood down cut the next slot and re
    Many thanks!
    I only want to straighten out a couple to appease my perfectionist side, but the whole truck is pretty rough around the edges so it fits the aesthetic as is. And yea stogy nailed it, I like it too much now to just hang it on the wall, it’ll probably get used more often than not. Plus the louvres solved one of the main reasons I didn’t want to use the hood because it cast a big shadow over my beautiful hemi, but now they letplenty of light in so it still highlights the crown jewel of my build.
    Six Ball, alanp561, Just Gary and 8 others like this.
  18. Tat2Neil
    Tat2Neil
    from Mesa AZ
    Yup that’s the one!
  19. nochop
    nochop
    from norcal
    F me that’s gonna be epic
  20. lostn51
    lostn51
    from Tennessee
    That’s pretty damn cool, excellent work sir!!!
  21. Happydaze
    Happydaze
    Perfectly imperfect. Really works and looks like it's been there forever. I hope that's the finished look.
    Chris
  22. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I dig it, great work man. Love home made simple things like this where you do it yourself.... Two Thumbs UP!!!!
  23. Jalopy Joker
    Jalopy Joker
    Congrats on a job well done. Thanks for sharing.
  24. guthriesmith
    guthriesmith
    Looks good and another great example to show that we don’t have to have fancy tools to do most of this stuff. Thanks for sharing. :cool:
  25. Very cool. Do you have a link for the video you watched to make your punch?
  26. A Boner
    A Boner
    Fantastic…definitely need to run it with this hood!
    What cutoff wheel did you use?
    Stogy, Tow Truck Tom and Tat2Neil like this.
  27. Crusty Chevy
    Crusty Chevy
  28. Tat2Neil
    Tat2Neil
    from Mesa AZ
    I sure hope so haha! Thank you
    Thank you
    Nailed it, I want the ch***is and drivetrain to look like clean and new, but then have the body be old and crusty and left rough around the edges, hopefully driving peoples attention to the motor as it’s the star of the show.
    It makes me think of the possibilities of different shapes and sizes that could be made, but this simple clean look is my favorite
    I’m definitely working with very basic tools but it’s getting the job done! like the old saying, necessity breeds creativity!
    Much appreciated!
  29. Tat2Neil
    Tat2Neil
    from Mesa AZ
    CrustyChevy beat me too it, that’s the video I watched
    definitely will be running this hood! It was just some cheapo’s from Amazon but I noticed they were a tad bit thinner than most, I can check the brand when I get home tonight.
    Stogy and A Boner like this.
  30. A Boner
    A Boner
    Great video…don’t forget to leave a like on YouTube!
    swade41, Stogy and Tow Truck Tom like this.
