Hot Rods Speedway 22 Circuit Wiring Harness Opinions
Discussion in 'The Hokey Ass Message Board' started by 37fordtruck, Nov 25, 2023.
  1. 37fordtruck
    37fordtruck
    Looking for opinions on the Speedway 22 Circuit Wiring Harness. If you have installed one please share your experience...good or bad. Thanks.
    mad mikey and chryslerfan55 like this.
  2. bantam
    bantam
    I am always way over optimistic on the number of circuits I “use” vs what I thought I “needed” when I bought it. I always have extra circuits/wiring and that just creates more work sorting through the harness to install and then clean up.
    Finished a 22 circuit install earlier this year. Two things I didn’t like:
    1. The way the fuse blocks mounts to the firewall
    2. Something about having to change some things to get it to work correctly with their universal turn signal switch….can’t quite remember the exact problem. Will you have a/c? Electric fan? Etc
    otherwise it’s fine……but having in the past used Rebelwire on the H.A.M.B. I recommend theirs.
  3. bantam
    bantam
    Correction…..I also installed on of their mini wiring harnesses this year. The mini is the one with the flimsy fuse block mounting, not the full size 22.
    mad mikey likes this.
  4. bobss396
    bobss396
    22 circuits is a lot if you don't use most of them. The coiled up wire takes up space under the dash. I run a 14-circuit Kwik Wire in my car and have about 3 leftover.
  5. BamaMav
    BamaMav
    from Berry, AL
    I used one in my car, mostly happy with it. The lettering on the fuse panel doesn’t last very long though, some of mine is already so faded it can’t be read. Wiring was plenty long, but if you have a station wagon would probably need longer. I don’t remember having any problems figuring out what went where.
  6. KevKo
    KevKo
    from Motown
    I removed the circuits I didn’t need. Pop the terminal out of the fuse block, no fuse needed. No need to coil up a bunch of wires under the dash. On my next build I’m putting the fuse block behind a panel in the console so I don’t have to lay on the floor and look upside down to change a fuse.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Wiring is one place where I would not go with the low bidder. Lots of little things can create problems later on, like less that great crimps and even the quality of the wire and connector. I'd use one of the companies that specialize in wiring and know their name recognition depends on good quality. For most of us, troubleshooting wiring is difficult and the few bucks saved at purchase are quickly forgotten.
    hotrodharry2 and wfo guy like this.
  8. krylon32
    krylon32
    from Nebraska
    Me to, spend the extra for a wiring kit from one of the companies that does that as their main business. Some Speedway parts are good but some??????????????
    hotrodharry2 and ekimneirbo like this.
  9. flatout51
    flatout51
    Rebel Wire. American made and the BEST customer service ever.
  10. pprather
    pprather
    I'm most familiar with American Autowire 22 system. It's not inexpensive, BUT one big advantage is each circuit runs from the device TO the panel. You wire the circuits you need, the rest of the wires stay in the shipping box. There is no big clump of wires (some unused) at the panel.
    I hope this helps.
  11. AHotRod
    AHotRod
  12. I believe Ron Francis does this as well.
    I rewired my own. Not "pretty" but effective. If ever I do another fuse block will be in the engine compartment.
    Ben
    Ben
  13. trad27
    trad27
    I put one in earlier in the year and was happy, like said above the circuits I didn't need I cut short at the fuze block. I put my fuze block under the seat and had to lengthen all the wires for the dash and gauges to reach but not there fault as it's designed to go under the dash. Wires clearly marked well with good directions. I really don't like the mounting of the fuze block though, clips into a cheap plastic mount that feels flemsy. All in all I would probably buy it again for a future project maybe just re engineer the block mount.
  14. Ratspit
    Ratspit
    I have to agree with Krylon32. Get a kit from company that builds them. When you have a question on your installation who would you rather call, Speedway or a company that makes their own harnesses? I chose Kwik Wire for my build and it was well worth the extra money.
    hotrodharry2 likes this.
  15. pprather
    pprather
    Many here have used Rebel Wiring product and report helpful customer service.
  16. HOTRODNORSKIE
    HOTRODNORSKIE
    Installed the speedway 22 in my olds mounted the fuse panel behind the front seat so I had plenty of room, wire is good quality and lettered clearly , very good directions all for a good price I will use it again some day.
  17. panhead_pete
    panhead_pete
    Have a small fuse Speedway kit. Looks to be well built and well labled.
  18. X38
    X38
    Oh boy, is it last week already? :rolleyes:
    57 Fargo likes this.
  19. Automotive Stud
    Automotive Stud
    I've used the Speedway 12 circuit kit in three of my cars. They worked out well.
  20. Dangerous Dan
    Dangerous Dan
    I have used 3 of Speedway wiring kits, wouldn't use anything else. Everything included, very good instructions, extra long wires marked every 6in. and half the price of others.
  21. willys36
    willys36
    I always buy a 22 then once the car is wired, and I am sure it is done, I cut off the unused ones leaving a long enuf lead so I can splice a new run into the block if needed in the future. Keep the unused wires coiled in a box for future access.
