Projects '61 Falcon Street/Strip Gasser Build
Discussion in 'The Hokey Ass Message Board' started by brianf31, Nov 14, 2019.
  1. brianf31
    brianf31
    I think I need a tunnel ram to balance out these ridiculous headers.
  2. lumpy 63
    lumpy 63
    Or stack injection:p
  3. brianf31
    brianf31
    Yes!
    Deuces, mad mikey and lumpy 63 like this.
  4. bobss396
    bobss396
    Or a taller-ish stock car style air cleaner.
  5. mad mikey
    mad mikey
  6. brianf31
    brianf31
    I can definitely run a 4" tall filter and maybe a 1" spacer. Here's a 3" filter. Or maybe I fab an air cleaner to fit up in the hood scoop...
    Deuces, brEad, bobss396 and 1 other person like this.
  7. brianf31
    brianf31
    I need to start on an accelerator pedal. I had this lying around but I have no idea on the source. Does anyone know what it came from?
    bchctybob and Thor1 like this.
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
    No and No to these should they pop into your cranium haha
    Just Gary likes this.
  9. RmK57
    RmK57
    Is that a Blue Thunder intake?
  10. bobss396
    bobss396
    A single tunnel ram would be a viable option.
    brianf31 likes this.
  11. brianf31
    brianf31
    Just Gary and lumpy 63 like this.
  12. brianf31
    brianf31
    Yes. It's supposed to be good to 6500 rpm. It should work well on the street.
    Deuces likes this.
  13. RmK57
    RmK57
    I swapped over to try a 4150 base Victor on my 500 BBF. I’m not sold on it and more than likely going switch back to my Weiand Stealth. Part of the issue besides being a single plane high rpm intake is the mis-match on the ports due to the Victor using CJ centers rather than regular 429-460 centres. There is about 1/4” overlap on 4 ports. I’m not about to start grinding away on my heads to correct it either.
    The Blue Thunder is supposed to be a pretty good intake. Could experiment with spacers or trim down the divider to see what works best.
    bchctybob and brianf31 like this.
  14. swade41
    swade41
    from Buffalo,NY
    The velocity stack makes more hp over an open carb with nothing on top, not that I'd run a single velocity stack on any single 4 intake though.
    A single tunnel ram is never a good idea on anything ! Lol
    Deuces, brianf31, bobss396 and 3 others like this.
  15. brianf31
    brianf31
    That's good info. I'll run Kaase P-51 heads which are SCJ style. The Victor intake is pretty much all that Kaase and publishers have run on their published dyno pulls. Interestingly enough, Kaase ran a ported Torker II and it only gave up 30 hp to the Victor.
    Since this car will be 90% street, I'll try this Blue Thunder before I spend more money. The first iteration will have a smallish cam anyway: Comp solid roller 34-770-9 with 236/242 @ .050", .650"/.657" lift. If I can get into the high 10s, I'll be happy. If not, then it's a bigger cam and a different intake.
    bchctybob, Deuces, Thor1 and 4 others like this.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
  17. neilswheels
    neilswheels
    from England
    Liking this, how did you attach them to the window channel, and is there a way of adjusting opening height, or are they either wide open or shut?
    bobss396 and brianf31 like this.
  18. brianf31
    brianf31
    The OEM type dew wipes hold them in the window channel. They are either wide open or shut to minimize parts and weight.
    The quarter gl*** is actually fixed in place and will not lower. I heated and bent an L-shaped piece of Lexan and bolted it in under the window to act as a shelf.
    lumpy 63, mad mikey, Thor1 and 2 others like this.
  19. brianf31
    brianf31
    Thanks alot!
    mad mikey and Jeff Norwell like this.
  20. bobss396
    bobss396
    The TLBT slider get-up always at least looked cool :cool::cool::cool:
  21. brianf31
    brianf31
    Oh, I deleted the lower horizontal channel. the pull strap is bolted straight to the window bottom.
  22. RmK57
    RmK57
    I forgot you had P-51’s, for some reason I thought you had iron PI heads. You’re about 800-1000 lbs. lighter than my 57 so I agree you should be in the 10’s easily. I run 11.00’s with my tank.
  23. brianf31
    brianf31
    That's encouraging. I have a set of PI heads sitting on the block now. I need to sell those to finance some more parts!
    Deuces, Thor1, y'sguy and 2 others like this.
  24. brianf31
    brianf31
  25. mad mikey
    mad mikey
    Looks great Brian, very nice work.:)
  26. 6t5frlane
    6t5frlane
    from New York
    Deuces likes this.
  27. 6t5frlane
    6t5frlane
    from New York
    Love the color. Mad respect for this build
  28. brianf31
    brianf31
    Thanks!
  29. brianf31
    brianf31
    F1 clutch and brake pedals next to an early Falcon accelerator pedal. I have no idea what the accelerator linkage came from but I made it work!
    I'll run a bolt on the clutch pedal to act as a pedal stop for bangin' shifts.
    bchctybob, Deuces, Just Gary and 6 others like this.
  30. 33Doll
    33Doll
    Man! I really want those Auburn Tires now! I think my Pro trac 60's are nice, but slightly too low profile. 33 out 3.jpg
    Deuces, brEad and brianf31 like this.
