Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. hmm, maybe do a bear scratch style instead of a lightning strike?
    chryslerfan55, 64 DODGE 440 and Stogy like this.
  2. animal8324
    animal8324
    from nj
    Pretty cool man
    41 GMC K-18 and Stogy like this.
  3. Stogy
    Stogy
    :rolleyes:...here's one more I did, @animal8324 if any of these don't sit well with you let me know, I will remove them...;)
    It truly is a Monster of a machine...
    Do you ever envision it with a period applicable body? I suspect being a 999 inspired that would be not but I'm curious...
    VANDENPLAS, 2Blue2, Okie Pete and 5 others like this.
  4. animal8324
    animal8324
    from nj
    She's gonna stay naked
    warhorseracing, Boneyard51 and Stogy like this.
  5. Boneyard51
    Boneyard51
    You know you can put a stationary sprocket welded to the frame and take one chain off the wheel and put it over the stationary sprocket, forcing the power through the differential gears and double your speed!
    This was actually done in the old days, two chains on a loaded truck, driving slow. Then unload the truck, break the chain, d**** it over the stationary sprocket and drive fast back to get a load , then hook up the two chains!
    Old technology! Chain drive overdrive! :D
    Bones
  6. animal8324
    animal8324
    from nj
  7. noboD
    noboD
    I am disappointed, hope you don't HAVE to sell.
    Stogy, 41 GMC K-18 and chryslerfan55 like this.
  8. Stogy
    Stogy
    @animal8324, many here just keep moving forward and onto the next adventure...getting more from the build than the open road...I hope you got some miles and smiles out of it at a minimum...
    Congratulations on the Milestone of getting it to a turnkey Beast of a machine and thanks for sharing the journey...anything coming down the road of the distant past?...
    VANDENPLAS, 48fordnut and brEad like this.
  9. animal8324
    animal8324
    from nj
    April Fools I'm still plugging away on her.
    VANDENPLAS, Jet96, Stogy and 6 others like this.
  10. atch
    atch
    Thank goodness...
    Stogy likes this.
  11. j hansen
    j hansen
    Good one!:D
    Stogy and seb fontana like this.
  12. getow
    getow
    Ha. Got me. I was actually somewhat disappointed to hear it was for sale. Keep up the good work, ive been following.
    Stogy likes this.
  13. noboD
    noboD
    That's just mean!!
    Stogy and caseywheels like this.
  14. A one-day-only sale.
    I always miss out.
    famdoc3 and Stogy like this.
  15. animal8324
    animal8324
    from nj
    I would sell it but it would be a presale for the completed vehicle as I want to build it.
    Stogy and brEad like this.
  16. animal8324
    animal8324
    from nj
    Well owning a buisness, being a dad, and depression seem to get in the way of the truly important stuff like building this dope *** speedster.
    I've gotten the chain drive differential rebuilt but when I went to fit it I wasn't able to. I let it sit so long without the upper bracing for the differential notch that she tightened up like a vigin on prom night so I'm in the process of using a porta power to loosen her up like a gynecologist with a speculum.
    VANDENPLAS, pwschuh, Ned Ludd and 9 others like this.
  17. Squablow
    Squablow
    That's one way to put it!
    warhorseracing likes this.
  18. jaspoerty
    jaspoerty
    That's absolutely fantastic! It's truly inspiring to see someone pursue their long-time dream and make it a reality. The world needs more people like you, willing to restore and cherish cl***ic vehicles like this. Keep up the amazing work, and I can't wait to see the finished result of your hard work and love for this unique project! If you need support on any parts, you can check: https://en.tradebearings.com/
    Or global suppliers: https://www.tradebearings.com/
    rod1 likes this.
  19. PackardV8
    PackardV8
    We rebuilt one of those for a local firefighter project and it was quite a learning curve. At the time, I considered several options for a vintage speedster. I kept coming back to the engine wanted to be turbocharged; how to do that with a vintage vibel
    jack vines
    Thor1 and warhorseracing like this.
  20. ratrodrodder
    ratrodrodder
    from Boston
    Jack, I like the cut of your jib! I'm picturing a turbo from a 1970s-era multi-fuel military 6x6, or perhaps from a larger farm tractor.... might take some creative plumbing, but I think it could be done well enough to look period-correct/ish. Something in the 6-10 lbs of boost range, maybe?
    (Knowing little to nothing about what kind of boost one of those engines could handle. They certainly look stout enough to take more than that, but I imagine there's at least one sub-system that might soon become the weak point?)
  21. animal8324
    animal8324
    from nj
    It took a 10 ton porta power but I spread the diff hole out like Ava Divine!
    Now on to the p***enger side chain drive and rear brakes.
    VANDENPLAS, brEad, Thor1 and 3 others like this.
  22. animal8324
    animal8324
    from nj
    Got both chain drives mocked up! The Beast of the Valley could drive right now.
  23. that thing looks so killer, i cant wait for the first video of it driving :)
    Thor1 and 41 GMC K-18 like this.
  24. animal8324
    animal8324
    from nj
    Started working my way from the back to the front for final mock up but need jack stands to get at the rear spring mounts and fittings for the rear brakes so i knocked out a front spring perch. I dig it. 20231126_153923.jpg
  25. ratrodrodder
    ratrodrodder
    from Boston
    This thing looks so awesome.... hope to see it snorting its way around some track soon!
  26. animal8324
    animal8324
    from nj
    Got the other spring perch finished and started on the rear brake lines.
    Anyone got recommendations for holding thelines to the frame?
    VANDENPLAS, Okie Pete, brEad and 4 others like this.
  27. RodStRace
    RodStRace
    If you are going to try outside the box and not use the various methods that are typical, how about leather straps? Wide belt width, loop around the line and a rivet to hold to frame. Something like this curtain rod strap. If you are in horse country, you might find old tack stuff to remake.
    although the front sections look more modern. Whatever you use, make it fit all over.
    VANDENPLAS, SS327, Okie Pete and 2 others like this.
  28. animal8324
    animal8324
    from nj
    First drive kinda! Got it running on it's own tank and battery and went through all the gears!
  29. 51504bat
    51504bat
    Maybe take the shop rags off the carbs?
    SS327, RMR&C, j hansen and 1 other person like this.
  30. animal8324
    animal8324
    from nj
    Lol. Totally missed that!!!
    SS327, Okie Pete and j hansen like this.
