Technical front shock aborber pin/mount point
Discussion in 'The Hokey Ass Message Board' started by Jerry A Smith, Nov 27, 2023.
  1. Jerry A Smith
    Jerry A Smith
    from Tulsa
    I had to discard one of my front shock absorber pins ( for the lower shock mount point on the front driver shock absorber).
    Does anyone have a suggestion on a replacement method?
    method:
    such as, a grade 8 bolt?
    tap the ends of some bar stock?
    it's a 1950 ford truck with the straight axle. right now I've removed the front shocks and gone with some stronger leaf spring, but on a really bumpy road the steering wheel kick can be unnerving. I know the ride isn't going to get better but i want to save the suspension from degrading earlier than it should.
    all thoughts are welcome.
  2. squirrel
    hrm2k likes this.
  3. 1971BB427
    1971BB427
    from Oregon
    Jerry A Smith likes this.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    You need a stud that's long enough to go through the axle. A typical shock stud won't work. Looks like most places are out of stock for them. I'd bet they're out there...some where.
    Might check with Chuck's Trucks to locate one. https://www.chuckstrucksllc.com/
    Good luck!
    Jerry A Smith and squirrel like this.
  5. Jerry A Smith
    Jerry A Smith
    from Tulsa
    Hen's teeth. I've looked everywhere. did not know about Chuck's trucks. thanks.
  6. Jerry A Smith
    Jerry A Smith
    from Tulsa
    1950 Ford Truck. the shock pin, goes through the front axle with a capture thrust washer that prevents the stud pin from pulling through in the case of a bolt failure. it's part 18 in the picture, not 24, 24 is for 53-56.
    If someone had one I wouldn't be asking. Thanks for your response.
    squirrel likes this.
  7. gene-koning
    gene-koning
    Turn the bottom of the shock 90 degrees and weld a couple brackets onto the axle with a grade 8 bolt going through the brackets and the shock in double sheer.
  8. squirrel
    you don't have a lathe, do you?
    Can you weld two bolts together, head to head?
    Jerry A Smith and Moriarity like this.
  9. Jerry A Smith
    Jerry A Smith
    from Tulsa
    if I had one, it wasn't something I ever learned how to wrangle.
    But that is the kind of idea I was considering, but not that specifically. Thanks for that.
  10. RICH B
    RICH B
    Almostdone and Jerry A Smith like this.
  11. Jerry A Smith
    Jerry A Smith
    from Tulsa
    Thanks RichB. those are exactly what I'm looking to buy!
