Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. Stogy
    Stogy
    With modern lights on the front when signalling a headlight goes out and the signal blinks on the side your turning so maybe with both running lights on when you turn the Left signal on the right running light goes out when the left is flashing...
    ....perhaps since your probably using new modules that is an option in the hookup...
  2. Stogy
    Stogy
    Cool Hotrod...Lights look awesome...and all steps are forward today minus a couple burps...
    swade41 likes this.
  3. swade41
    swade41
    from Buffalo,NY
    When I checked turn signals with parking lights on the turns were much brighter like they should be.
    I'll have to go back and look at the schematic to see if it's possible to have the parking lights on in both positions without over taxing the switch circuit.
    mad mikey, 427 sleeper and Stogy like this.
  4. Stogy
    Stogy
    Then you might get the best of both worlds...good luck on the research...
    mad mikey, 427 sleeper and swade41 like this.
  5. swade41
    swade41
    from Buffalo,NY
    So I didn't see anything saying you couldn't use a jumper to taillights, I was wondering if this had that spring thing inside they may get overloaded somehow.
    Or if diverting the juice to two things would somehow create a voltage drop in both directions causing a dim light.
    I guess an extended length of time with the headlights on will show if it's good to go or not, but they look fine on the short test.
  6. Stogy
    Stogy
    Spot on...;)
    mad mikey and swade41 like this.
  7. swade41
    swade41
    from Buffalo,NY
    Next up was mounting the scoop I've always just had sitting on there, the filters sit around a raised ridge and then a standard air cleaner lid about a finger width from the top of the scoop.
    The previous owner of the scoop drilled holes in the top of the scoop so the carb studs would stick through, finishing the top of the scoop is still on my list.
    My idea was to cut a couple carb studs, stick stud through hole, put the nut on a couple turns, slip the rear filter with lid in there, hold nut between fingers and screw the stud down into the carb. The nut would hold the air cleaner lid on and stud would hold scoop on, had to pick the scoop up to find the carb hole.
    Everything was going good until I got to the front ***embly but I couldn't find the hole, what the heck is going on, then the light bulb goes off, me and the previous owner both ran the scoop on a blower.
    Duh, blower and tunnel ram carb spacing are different, no wonder I can't find the hole.
    So my other plan was to always swap scoops whenever I felt like it, so I dig out the Shelby scoop I redid to mount to the hood
    Damn, can't find the one inch screws I had used to bolt it down, found plenty 3/4 and 1/2 inch though, plus I never painted the underside flat black.
    So that was about all I accomplished other than buying and ***embling some wheel dollies.
  8. Stogy
    Stogy
    Is there nuts fastened/Gl***ed behind the flange with bolts up or are there just sheetmetal type screws going up...or do those short bolts go scoop down through the hood then washer and nut?
  9. swade41
    swade41
    from Buffalo,NY
    ****on head machine screws from scoop side down into hood with washers and nuts.
    You can see the 10 holes in the hood
  10. Stogy
    Stogy
    I was thinking its a pretty tight fit towards the rear but there's more room than I think...not lots but enough...perfect
    mad mikey and 427 sleeper like this.
  11. swade41
    swade41
    from Buffalo,NY
    It is tight, that's why the holes don't go further back than they do
  12. swade41
    swade41
    from Buffalo,NY
    I don't think the black paint is going to be dry enough anytime soon to bolt that to my hood, temps took a dive into the 20's, brought it into the house to stink it up. Lol
    For a temporary fix I took the crossbars I made for the original scoop and put them in there to lock it down on the test drive.
    Since I know all the rear lights work and no fuel filler leaks I installed the top panel of the bulkhead
    And the p***enger seat, almost looks like a complete car again
    Then I moseyed over to the cold half (38 degrees) of the garage to put the dollies under the 41, which ironically is supposed to be the temp on Saturday, the big move day.
  13. swade41
    swade41
    from Buffalo,NY
    No move, still raining, not sure when it's going to let up either
    Utter ******** if you ask me
    427 sleeper likes this.
  14. swade41
    swade41
    from Buffalo,NY
    Swapped scoops, paint was dry so I chased down hardware, dialed in a couple carb studs and put some fuzzy cloth on the mounting surface.
    20231129_150010.jpg 20231129_154738.jpg 20231203_131556.jpg 20231203_131645.jpg 20231203_131710.jpg
    Bolted the winch in the floor and gave it a test run pulling the 57 up and letting it down, still works great, it's what I used to originally get it into the garage almost exactly 6 yrs ago.
  15. swade41
    swade41
    from Buffalo,NY
    I'm loving this new stance
    Just one block up and back, short, sweet and rowdy
    20231204_150933.jpg 20231204_151001.jpg 20231204_151240.jpg 20231204_151015.jpg 20231204_150951.jpg 20231204_151300.jpg 20231204_165656.jpg
  16. swade41
    swade41
    from Buffalo,NY
    Doing a Thin Lizzy, making a Jailbreak
  17. swade41
    swade41
    from Buffalo,NY
  18. swade41
    swade41
    from Buffalo,NY
    Washed away the years of garage crud today and put about a mile of driving on it, should be fun next year to horse this thing around.
    20231216_153519.jpg 20231216_153554.jpg 20231216_153851.jpg 20231216_153917.jpg 20231216_160630.jpg 20231216_160906.jpg 20231216_165449.jpg
  19. Stogy
    Stogy
    Congratulations!!...it looks and sounds fantastic...when you were driving out of the garage that front end really is like a face looking out for a place to discover...and away you went...how happy you must be...
    427 sleeper, mad mikey and swade41 like this.
  20. swade41
    swade41
    from Buffalo,NY
    It's pretty cool to drive it again
  21. mad mikey
    mad mikey
    Now that is one fine g***er. WOW!:)
  22. LOST ANGEL
    LOST ANGEL
  23. guthriesmith
    guthriesmith
    Man, that is great! Car looks just right and I can imagine the feeling being able to drive it! :cool:
  24. swade41
    swade41
    from Buffalo,NY
    Thanks guys, 600 hp and 600 tq combined with 4.57 gears should tighten the sphincter a little lol
    Baron, Chucky, loudbang and 3 others like this.
  25. swade41
    swade41
    from Buffalo,NY
  26. swade41
    swade41
    from Buffalo,NY
    I finally suc***bed to buying a plastic chrome dash emblem, I've been looking for a nice original forever and they just don't come up for sale, so I reluctantly did it.
    This vendor previously listed them as a 3 piece set, trunk, dash,door, but I didn't want to pay the price to just get a dash, especially if they didn't fit, he now lists them individually.
    I am happy to say that the studs actually lined up with the stock holes and it doesn't look half bad, the ad always had a disclaimer that some drilling may be required. It didn't come with speed nuts so I made some out of an old rubber hood bumper, I like it.
    4 pedals, enloe, loudbang and 4 others like this.
  27. guthriesmith
    guthriesmith
    I was expecting to see a good launch or something. I hope your neighbor has a good job that has nothing to do with making videos. :eek:
    loudbang and swade41 like this.
  28. swade41
    swade41
    from Buffalo,NY
    Ha ha ha, totally missed it didn't he, you can barely see the car turn the corner at the end of the block at the beginning, I think he was to excited lol
    loudbang and guthriesmith like this.
  29. alumslot
    alumslot
    I bought all 3. the small ones DON'T fit the hood. The big one fits the trunk perfect. I didn't need the glove box. 123a.jpg
    enloe, loudbang, LOST ANGEL and 2 others like this.
  30. swade41
    swade41
    from Buffalo,NY
    I think Corey Penny tried the hood on his YouTube channel and also said it didn't fit but I think he was drilling his own holes in the hood. I want to remember him saying it wasn't curved enough to fit.
    enloe, loudbang and Baron like this.
