Technical Vacuum actuated exhaust cutouts
Discussion in 'The Hokey Ass Message Board' started by Rand Man, Nov 27, 2023.
  1. Rand Man
    Rand Man
    I should know this, but how exactly does this work? I think I should be to find a vacuum port (upstream of the carb) where the vacuum will increase as the throttle is opened. I know the intake manifold sees the deepest vacuum at idle. Seems like I should be able to find more suction when the thing is floored.
    maybe the one in this photo is designed like a waste gate ( opens with an increase in pressure) ? IMG_5574.jpeg
    Deuces and lothiandon1940 like this.
  2. wraymen
    wraymen
  3. rockable
    rockable
    It appears they are using the vacuum reservoir of the brake booster to hold them open during acceleration. At WOT, you have no vacuum. IMO, I would go with electric actuated.
    j hansen and Tim like this.
  4. wraymen
    wraymen
    Pretty cool video showing a work around for the vacuum fluctuation problem.
    lothiandon1940 likes this.
  5. wraymen
    wraymen
    I’m guessing the power brakes work well at any throttle. Don’t have the knowledge to explain why though.
  6. Rand Man
    Rand Man
    Yeah the booster looks like a reliable source of vacuum.
    My Lincoln is currently 6 Volt, so looking for something that doesn’t use a 12V solenoid.
  7. Bandit Billy
    Bandit Billy
    I would rather run them from a toggle or a pedal activated turbo 400 gas pedal switch.
    Toms Dogs likes this.
  8. rockable
    rockable
    Well, the booster has a check valve that holds vacuum in the reservoir when vacuum drops off under acceleration. That is to make sure you have enough boost to stop in emergencies like your engine dying, etc. It will work and since you are 6 volt, it might be the best option. Is the solenoid valve available in 6 volts? You would need that, as well.
  9. Vacuum ***isted power brakes work at any RPM or throttle opening because the 90 degree plastic fitting where the vacuum hose connects is a one way check valve. At WOT when manifold vacuum drops, the check valve keeps the ac***ulated vacuum inside the booster and ready for a brake application. @rockable types faster than I do!
  10. Rand Man
    Rand Man
    Thanks. I can probably find a find a six volt solenoid. I will may go with a 6/12 battery for starting in 12V. That’s next on my list of questions I should already know the answer.
    lothiandon1940 and rockable like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
  12. ClayMart
    ClayMart
    I've got it in my head that a vacuum brake booster should have its own dedicated supply of manifold vacuum with a check valve inline to the booster. No other vacuum accessories should be connected to that vacuum line. I'd find another source of vacuum somewhere else on the carb or intake manifold and probably plumb in a vacuum reservoir as well.
    Actually it looks like a good place to use a 12v linear actuator and a DPDT switch.
    https://www.amazon.com/Electric-Hig...&hvlocphy=&hvtargid=pla-4584345024930371&th=1
    Or a push/pull choke cable, like shown above.
    :rolleyes:
    rockable likes this.
  13. '49 Ford Coupe
    '49 Ford Coupe
    Why not just use electric operators with an open/close two position dashboard switch? That's what I did years ago and it still works just fine. Sometimes you might want to hear that rumble while you're sitting still. Cutouts are good for maximum horsepower but they are even better for the sound at any throttle position.
    lothiandon1940 and Rand Man like this.
  14. Harv
    Harv
    from Sydney
  15. SS327
    SS327
    Pontiac had an optional muffler for the GTO that did the same thing. Under a high speed blast with low vacuum they would go open.
    Deuces, lothiandon1940 and Rand Man like this.
  16. Oneball
    Oneball
    They are usually set up so that when you apply vacuum (often electronically switched) they go quiet.
    A lot of the OEM systems that are not electronic control and go loud under full throttle are just a spring loaded flap that opens under high flow
    Ned Ludd, lothiandon1940 and Rand Man like this.
  17. Ned Ludd
    Ned Ludd
    Brake boosters work on balanced vacuum. Equal vacuum is normally maintained on both sides of the booster diaphragm. ***ist is provided by admitting air at atmospheric pressure on the pedal side of the diaphragm.
    wraymen, Rand Man and rockable like this.
  18. flynbrian48
    flynbrian48
    You don't need a cutout, manual, electric or vacuum, if you build it without mufflers. You're welcome. F9B36DB0-6360-46ED-9287-6CB386A9F4EA.jpeg
  19. Rand Man
    Rand Man
    I tried that on my coupe. It’s incredibly loud to go down the highway. Something you can get tired of really quick
    05snopro440 likes this.
  20. '49 Ford Coupe
    '49 Ford Coupe
    Actually it was just a spring-loaded ****erfly within the muffler that would open under higher flow conditions. Has nothing to do with low vacuum although that's a coincidental condition when you floorboard it...
  21. SS327
    SS327
    How does
    Nope, it actually had vacuume line run to it. Option did not last long before it was gone. Melted the diaphragms and lines. Then it got a pop off valve type thing. That quickly died too but about 200 of those were produced.
  22. Bandit Billy
    Bandit Billy
    Having had cutouts on a couple rides I have kinda outgrown it. Kudos to you guys keeping the roar alive though. Being able to quiet the car at any speed is a nice feature. I would never do another system that I couldn't regulate from inside the car.
    Late model front engine vettes had a cut out switch that opened 2 more pipes in the back (they have 4) and byp*** the resonators so it sounded throaty. I installed a switch on a buddy's so he could run them loud all of the time or quiet it for funeral processions or sneaking into work late.
    05snopro440 and SS327 like this.
  23. VOETOM
    VOETOM
    from MO
    The VOE Pontiac system used a rod with a "floating" valve that was spring loaded (shut) and a 4" vacuum actuator would pull it open via manual control via the driver. Even at WOT with no engine vacuum, the vacuum canister under the front fender was "charged" enough it could pull and hold the mufflers open.
    I am building 12 more right now. The AVATAR shows a set I built and polished in 2008 or so.
    I also was able to create a vacuum operated engine cutout setup for my father in law's 32 . I'll find images and share them. They work pretty sweetly.
    Rand Man and lostone like this.
  24. lostone
    lostone
    from kansas
    Pontiac did have some that were vacuum, complete with vacuum pull pod on the front of each muffler. Used to have a schematic of the vacuum hose routing to the mufflers in my younger days, don't know what I ever did with it though....
  25. VOETOM
    VOETOM
    from MO
    lostone likes this.
  26. VOETOM
    VOETOM
    from MO
    Rand Man likes this.
  27. VOETOM
    VOETOM
    from MO
    This one also uses a "vacuum reservoir" hidden under the car to operate even at WOT.
    SS327 likes this.
  28. 05snopro440
    05snopro440
  29. flynbrian48
    flynbrian48
    This is surprisingly quiet. Well, maybe "not loud" as opposed to quiet, but it's very tolerable at speed. I think the bends in the pipe baffle it just enough. And, it's small displacement, so that helps too.
    SS327 and wraymen like this.
