Technical ***November 2023 Banger Meet Thread - Shopping Season***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 1, 2023.
  1. Stovebolt
    Stovebolt
    HRA - either option is great - just as long as you enjoy the motor in whatever car you put it in.
    The sprint car towed behind an AV8 would be a sight to behold, just as seeing this motor in your roadster would be
    Outback likes this.
  2. Reddy
    Reddy
    New picture of the Ford at Fast Run three years ago
    Outback, hotrodA and Stovebolt like this.
  3. Reddy
    Reddy
  4. Well, after a little over 20 years of being on the HAMB, I can finally post in the Banger monthly meet thread!
    Picked this up a couple weeks ago from a clubmate in Wisconsin. My son has plans to make a speedster out of it for Old Car Festival next year.
    v/r,
    jason
    Outback and Jeff34 like this.
  5. lahti35
    lahti35
    I picked one up for my '31 from Roadster Supply. It fit the new made Stromberg 97 I have with no issues. I plan to run it facing the rear.
  6. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Wow, this thing sits perfect. What has been done to it?
    Outback likes this.
  7. Reddy
    Reddy
    Here is picture of the engine it is 1928 block mode by Pat Gary's parts
  8. Well this is getting exciting 405715977_10224235787071672_9068933015228245914_n.jpg
    Only one more print, then I'll have to reprint to account for shrinkage. Has anyone experimented with "Ceramic Slurry" shell casting/Lost PLA? I'd love to get this head cast!
    40 Olds, Outback, burl and 2 others like this.
  10. I did investment casting years ago
    Probably not the way to go now
    Look for companies that do 3d core modeling
    Or check with foundries that do prototype casting
    J
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Investment casting slurry would have a hell of a time getting into the water jackets reliably, not to mention the struggle to find a foundry willing to do a one off using your master. I agree that 3D sand printing is the way to go. Won’t be cheap… but it’ll be right!
    Outback likes this.
  12. hotrodA
    hotrodA
    Back to the Alexander OHV
    Can any of you ID this rocker arm stand?
    It came on my Alexander and after diligent searching I’ve come up empty
    The shaft hole ID is .735”
    The bolt holes are .450”
    The bolt hole spacing is 2.350”
    The height from base to center of shaft is 1.525”
    The base looks as if it has been cut off and surface ground.
    Since the rocker arms are 34 Chevy exhaust I researched Chevy, Buick, Olds, GMC, but nothing.
    Does anybody have a Serr CRAGAR and could you check his dimensions? He doesn’t answer emails, apparently.
    I have made some aluminum replacements but I see no way to locate them to the head .(pin/dowel). Or will the stud and nut keep them secured?
    Thanks for any help!
    Bill
    akkhotrod likes this.
  13. Do a search for rocker arms unlimited
    Or rocker arm specialties
    J
    Crazydaddyo, akkhotrod and Outback like this.
  14. joemac05
    joemac05
    Is there going to be a December thread ;)
  15. Kevin Pharis
    Kevin Pharis
    from Califunny
    Rocker Arms Unlimited (used to be Specialties) in Red Bluff, CA. They list new rocker ***emblies for model A overheads on their website. No doubt they can fix up whatever you have too
    http://rockerarms.com/pages/ford.html
  16. hotrodA
    hotrodA
    Great info! Thanks for the help, John and Kevin.
    much easier to order than build
    J
    GuyW, G Baese and akkhotrod like this.
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Even if you do have to build yur own… RAU helped finish this set for my Akron-Hed by hardening and facing the tips, hone the bushings, and supplied the adjuster screws
  19. Jiminy
    Jiminy
