Hot Rods mufflers
Discussion in 'The Hokey Ass Message Board' started by bodymanmp, Nov 7, 2023.
  1. 57 Fargo
    57 Fargo
    I have thrush welded mufflers on the Fargo, I’m very happy with them on a mild 360
  2. MCjim
    MCjim
    from soCal
    Now, here's a topic that has never been discussed before...
    vtx1800, INVISIBLEKID, X38 and 2 others like this.
  3. MMM1693
    MMM1693
    350 CI Brockman Mellowtones in steelpack I have a video on here somewhere. I think it is under thread called Brockman Mellowtones.
    6inarow likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. Bad Bob
    Bad Bob
    from O.C. Baby
    When I bought my Coupe, it had short turndowns, coming right off the Ramhorns. Loud as ****!!! I ran pipes out the back, and it sounded like ****. Put Smithys on there, but it sounded like an 80's Camaro!and the cam cackle was gone. Cut those off...Now I just run 2-1/2" pipe, dumping just in front of the rear wheels. Pretty loud, but quieter than the original set up. But....it sounds like a Hotrod, NOT a Streetrod!!! I've noticed a lot of todays modern Mustangs and Camaros sound like boats or V6's. I'm sure at some point i'll put gl***packs on it.
  6. Acres
    Acres
    from Sweden
    On the Chevy Cherrybombs, and the Buick is running original system = library quiet
    Tow Truck Tom likes this.
  7. In_The_Pink
    In_The_Pink
    I have used and been happy with them, too. They are priced well, sound great, and for what I'm usually running, "losing" three horsepower will never be noticed: https://www.thrushexhaust.com/mufflers/thrush-welded-muffler
    They've always held up well on my DDs, and while they don't last forever under those conditions here in WI, for a non-year-'round vehicle which is usually garage kept, I think they'd be a good choice. I plan to use two behind my Buick 300 when the time comes.
    alanp561 and 57 Fargo like this.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    And they're darn affordable, too. I had a set on an O/T daily years ago. Sounded great and lasted quite a while even with the harsh Michigan winters.
  9. AHotRod
    AHotRod
    Bodymanmp .... I'm using the AP Enforcer gl*** packs on my Coupe now and love them. I had been running 2-1/2" straight pipes for a long time and that was fine, yet a bit tiresome driving back and forth to our Hot Rod Shoppe every day. I chose the 30" long version, and they are just right, I can carry on conversations for the first time in 33 years. They are available from numerous sources, I just used Summit Racing: AP Exhaust Enforcer Gl***pack Mufflers - Free Shipping on Orders Over $109 at Summit Racing
    Hot Rods RULE !!!
  10. bodymanmp
    bodymanmp
    just got a set of spyders neighbor haters,gettin ready to install
  11. lostn51
    lostn51
    from Tennessee
    Well the daily has Dynomax Cat back on it, but the rest of them have the factory mufflers complete with the correct part numbers on them for the specific car.
  12. Jkmar73
    Jkmar73
    from Tulare, CA
    383 sbc with 3” Borla Pro XS.
    Sporty45 likes this.
  13. Deadbird
    Deadbird
    Porter steel packs on my c10. Hard to beat ‘em.
    LSGUN, 302GMC and Tow Truck Tom like this.
  14. SuperKONR
    SuperKONR
    from Earth
    Gl***packs on most of them, both Cherry Bomb and old Blue Streaks. Have some old Cherry Bomb turbo mufflers on a poncho motor that sound great, don't drone like the gl***packs but sound wicked outside the car.
    Duals with NO crossovers for me.
  15. I have 2"x18" cherry bomb gl*** packs I got on a closeout hooked to 55 Chevy 265 exhaust manifolds on a stock 76 350 with Edelbrock carb and intake. Honestly sounds so good I'm waiting to swap to lakes pipes with baffles till I can and head swap. And anyone curious I have insane hearing....as in I never get less than 100% on any hearing test. I know 2" diameter pipe sounds small but it's a low compression 350 MAYBE putting out around 200 hp. But with the current setup it has a perfect sound
    alanp561 and Tow Truck Tom like this.
  16. Auto parts store Cherry bombs, installed backwards for the straight thru sound.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Look at this cars front radius rod , side delivery steering mounting , as close to perfect as it gets !
  18. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Sounds nice, sounds good, sounds good sounds nice
    Nah I ain't senile just what it is.
  19. lostn51
    lostn51
    from Tennessee
    Just a silly question, how many of you guys get the gl*** packs hot and shove a hose into the exhaust pipe so you could break the gl*** to make them sound better? Is that still a thing? My dad said that it was a thing back in the day so it’s got to be traditional :D
    WC145 and sidewayzz69 like this.
  20. Toms Dogs
    Toms Dogs
    from NJ
    Stainless Specialties 21/2 inch bullets! :D:rolleyes:
  21. trevorsworth
    trevorsworth
  22. AHotRod
    AHotRod
    Thank you for the kind words.
  23. gl*** packs. tried smithys but they didn't fit, so i have thrush angled gl***packs :D
    open manifolds vs gl*** packs
    winr, coupe33 and Truckdoctor Andy like this.
  24. corvair turbo launched in 1962, alongside the olds jetfire.
  25. wuga
    wuga
    Porters on 300" aluminum Buick, 259 Studebaker V8 and even duals on the banger. All sound great.
    Warren
  26. SDS
    SDS
    32 Roadster, 327 SBC w/Comp cams nostalgia grind, rear exit exhaust...using 22" Smithy's gl***-packs with 2" exhaust, no cross-over.
    It sounds great and goes with the style of the car.
  27. winr
    winr
    from Texas
    31" gl*** packs, 2.25 inlet/oulet ... tail pipes end right before mufflers
    They are a zillion old and starting to rust, I painted them 5 or 6 years ago but has burned off
    They sound nice but have gotten a bit loud
    Would like to find some quiet mufflers I could slip back into there place
    Any seen any quiet mufflers around 30" to 32" long ??
    Ricky.
  28. 302GMC
    302GMC
    from Idaho
  29. Taboo56Chevy
    Taboo56Chevy
    Flowmasters on the 33
    Dynamax on the 55
    Summit Stainless Gl***paks on Taboo
    winr likes this.
  30. johnnymac1
    johnnymac1
    I used Thrush Gl***packs, built up Chevy 250, cast iron headers, one muffler per header, and coming out the ovals on the rear bumper. Sounds pretty awesome. Really gets noticed over 2500 rpm.
    Hillbilly Werewolf and winr like this.
