Y-Block
Discussion in 'The Hokey Ass Message Board' started by kelgar50, Oct 2, 2006.
  1. kelgar50
    kelgar50
    from socal
    Found a 56' 1 1/2 ton or 2 ton ford flatbed for free complete with a motor.Was wondering if anybody knows what size Y-Block came in these.Motor is complete and was thinking it would be a good rod motor.Also If it is a 272 can it be made into a 312 very easily?
  2. arkiehotrods
    arkiehotrods
    According to my reference books, Ford trucks in '56 came with the 272. P***enger cars could also be had that year with the 292 and 312.
    I had a 55 Fairlane 2 dr sedan with the 272, and I had a lot of fun with it.
    The bore and stroke on the three engines is as follows
    272: 3.62 x 3.30
    292: 3.75 x 3.30
    312: 3.80 x 3.44
    According to the Ultimate American V-8 Engine Data Book, the 272, because it was of a thick-wall design, could be safely bored to 3.830, which is .030 in over the 312's stock bore.
  3. manicmechanic
    manicmechanic
    A Friend of mine was telling me of a hot setup using a 272 crank in a 312 block. Didn't know if any one knew if this was true or not.
  4. 51 wayfarer
    51 wayfarer
    from DENVER
    go to www.yblocks.com they have a ton of info and kits to rebuild or stroke the motor.
  5. jcruz
    jcruz
    from Austin, Tx
    agreed. its worth taking a look at the truck for sure (for free...its a no brainer). some y-blocks came as either "light duty" or "heavy duty", the latter with 4bbl and ram-horns. i'm not sure if y-blocks did in '56 but for my '58 it was an option back then.
    i say keep it.
  6. Sixcarb
    Sixcarb
    from North NJ
    To be sure you would need to have the block sonic tested, we did a 272 and found that a couple of cylinders would be questionable going over the 292 piston size, we ran a blower on this one and needed forged pistons so Ross made us a set that was .030 over.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    312s had larger main bearing journals than 272-292 blocks, so you'd have to come up with special bearing spacers to do the combination you speak of.
  8. manicmechanic
    manicmechanic
    Not real sure if this guy was feeding me a line on that combo or what. Thanks for the input..
  9. Paul2748
    Paul2748
    The supposedly hot set up is using the 312 crank in a 292 block since 312 blocks are getting scarcer. They cut down the mains on the 312 crank to 292 size to fit the block.
