FOR SALE >1933 FORD 3W >Chop was started but needs finishing. >CLEAN ***le with matching frame numbers >Model a rear cross member spliced in for QC like Pierson coupe >1935 ford rear end with welded pinion for posi >1935 ford Torque tube with 1933 ford driveshaft >Original Unsplit 1933 ford wishbone >Original Old drop axle >Original 1933 spindles >Front hydraulic backing plates have had rings welded in and red rolled for earlier spindles >1933 ford steering box >Dennis Lacy hydraulic master cylinder conversion >1933 ford brake and clutch pedals >1933 ford gas pedal >59a Flathead block >Weiand FR heads >Weiand 4x2 intake >1934 Grille and radiator >New Paul Bradly floor included >WWII B17 oxygen tank set up for fuel with hand pressure pump attached >Aircraft single seat >New Firestone 6.00/7.50's on early Ford 16" wheels >Wood bench plus springs included. >Lots of extras from Carpenters etc. >Extra column drop >Three 2-5/8” smooth bezel gauges (temp gauge needs capillary tube fixed) >1934 hood top included >>>STEERING WHEEL and 1933 HOOD TOP NOT INCLUDED. Car isn't an all original patch panel free unmolested car. Previous owner put new rear quarters on a****st other panels. There is no rust anywhere and everything is solid. it needs some ironing out of some panels and the chop finished. I raced it at TROG a few years and haven't messed with it since 2016. $30k obo Text me (JJ) 704-807-9984 email sugarcitydesign@gmail.com
Bttt! Partial trade for a 55 or 57 Chevy 150/210 or a 28/29 RPU projects? Or trade me a 58-64 Impala!
