Hot Rods 1939 ford pickup inner door structure repair
Discussion in 'The Hokey Ass Message Board' started by Curt Wilson, Nov 30, 2023.
  1. Curt Wilson
    Curt Wilson
    I am starting to repair the damage the p/o did to the inner structures of both doors. Looks like they took a plasma cutter to it?
    I need to make a patch panel for the big rectangular section near the top of the door panel area. My question is, does the rectangular recessed area (circled in blue on the red door) serve a purpose? Does something mount on the inside of it? Lastly, if someone could give me dimensions for that recess (or supply me with the patch from an original door [​IMG] that would be greatly appreciated!
  2. ActionYobbo
    ActionYobbo
    My doors dont have that recess
  3. Curt Wilson
    Curt Wilson
    oh really? So is your panel just flat in that area?
  4. southpaw-customs
    southpaw-customs
    I believe that might be a late 46'-47' door. And I think that area in question was for a arm rest. If you look at the cab corner you can see a gas filler hole. 41' and older had the gas tank at the rear of the frame. Later cabs had the tank under the seat.
    The doors on my pickup are solid except for a removable panel to access the window regulator and window.
  5. ActionYobbo
    ActionYobbo
    on the weekend I will try and get some pictures
  6. That's @The37Kid truck, if I remember correctly it was a dump truck cab.
    The37Kid likes this.
  7. The37Kid
    The37Kid
    Great memory! Thanks for the flash back in time, that was a project I should have kept but at the time I needed to pay bills. It was a '39 cab off a farm flatbed with the gas tank under the seat. Merry Christmas! Bob
  8. Curt Wilson
    Curt Wilson
    I can see on my doors the start of the recess where it was cut so I’m thinking it was there.
  9. southpaw-customs
    southpaw-customs
    That's good information. I didn't know that the trucks were different than the pickups.
    48stude likes this.
  10. ActionYobbo
    ActionYobbo
    No pictures. My doors are the same as the red door.
    Curt Wilson likes this.
  11. Curt Wilson
    Curt Wilson
    thanks for checking. If possible could u measure the length, width and depth of the recesses? I would greatly appreciate it.
  12. ActionYobbo
    ActionYobbo
    My doors are in the far end of the storage trailer. If the weather is good this weekend I will pull out the fenders and hood etc. and get a door out and measure it.
    here is the pictures. Top section is around 1/4” deep and bottom section is around 7/16 “ deep
  13. Curt Wilson
    Curt Wilson
    Awesome! That helps a lot! Thank you
